Already tried removing the RAM, tested each stick by itself in both slots and tested with both sticks in diffrent slots. If we’re assuming that its a power supply issue, wouldn’t a stress test crash too?
- have you desactived Amd gpu Renoir ?
- it should be also memory , because there are not same size Gb and not with the same CL clock , see manual about it
Disabling AMD gpu was the first thing i did, not resolving the issue, as stated previously tested with each stick separately.
I think the wrong drivers are being used. It looks like they are not using the hybrid drivers but the normal ones.
Keyword : Prime
Please post the output
mhwd --listinstalled
This sounds way to HOT in my opinion.
How old is this system? I’m guessing that it was running games fine in the past, is that correct?
Did you change anything after that?
Additional i have to say, there are some default shady bios settings from many Motherboard Vendor’s, which leading to a Overclocking System.
The old times where you have to just load your default settings are history, but im not sure if this issues persist for Laptop’s as i known for PC’s.
It is also worth to check your GPU Temps and not only your CPU.
Also check your CPU Temp, before your system is freezing…
Possible solution is to repaste your CPU/GPU with thermal compound or firstly clean your aircooler and laptop case from dusk.
Downclocking your CPU/GPU could also solve your problems.
That you speaking of Windows 10/11 and Manjaro being installed to the same machine at different times wasn’t obvious at all, but thanks for clarifying.
Yes, the whole system; however, it’s always possible a problem with a game can trigger a crash, either of the game or the system.
There is no simple explanation that you might easily understand, but if you’re asking if that scenario is possible, yes, it is.
We are not… assuming… anything;
but, instead, working through the possibilities.
Rather than wave your stress and test results in the faces of those who might wish to help, please just answer questions as they become apparent.
I have to agree with @Kobold on this point.
Furthermore, overheating ticks all the right boxes when it comes to a machine crashing; especially laptops.
A strong possibility is that your system overheats sufficiently to cause a crash, when playing some games. You have already demonstrated that your system reaches abnormally high termperatures (96 degrees).
If it were a desktop system, the recommendation would be to invest in a better cooling system. With a laptop, it’s not as easy, but I do recommend maximising airflow at all times; that is, never place the machine in a position that might restrict airflow.
There may be other options suitable for you machine; stands with additional fans, for example; you would need to research that yourself.
While we can’t absolutely point the finger at any one cause, given the circumstances you have described; that the crashing occurs only when playing games on each OS you installed; then the obvious likelihood is that the issue has nothing to do with any of the OS in question, including Manjaro.
My suggestion is to seek assistance from your local computer repair store, or via the laptop manufacturer help system.
If no information is forthcoming that specifically links your issue to Manjaro, my suggestion is that this topic be closed.
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
intentionally not using the amd driver. this was the first thing i disabled since the kernel panics started happening. checked the journalctl after a few kernel hangs and/or panics and amd drivers were having issues.
I managed to play Dark Souls 3 for 30 minutes (until the battery drained) with no issues on battery power only. This gave me the idea that when stress testing the usage of components goes up to 100% in a matter of seconds and the power brick handles that easily. im thinking that games/compilating code/shaders ( found out the same errors happen there too), have a gradually increasing power demand and thats when the power brick fails. For example, today it hanged while compiling shaders while the gpu was drawing 16w. Now I’m thinking of buying a new power brick.
System is around 2 and a half years old. No oc is made, my bios is pretty straight forward, no oc options.
I had a similar situation with a Minisforum HX90G. The computer would work great, until I decided to run a game. Then it would play for about 20 minutes, then freeze up.
EVERYONE told me that it was overheating… It seemed the most likely suspect…
But I caught it one day, doing something very simplistic (changing the desktop wallpaper) while I was gaming. When it did this, it attempted to draw more power. As soon as it did that, it would freeze. It wasn’t overheating, it couldn’t draw as much power as it needed to perform the task, and just shut off.
I was able to fix this, by limiting the power draw of the GPU using “CoreCtrl.” I didn’t notice any difference in most of the games… and in my high-end games, only a 1-2 fps… not that big of a deal.
How much did you went down on power? I experienced a hang when compiling shaders and the power draw was around 16 watts on the GPU.
I never had any issues until I was actually “in-game.” My GPU was running full speed. AMD 6600M, with Ryzen 9 5900HX processor. I believe the 6600M has a max draw of 100W, and I set it at a max of 90W with “CoreCtrl.”
The game ran fine, until the background service tried to change the wallpaper, and then it would shut off. So, I turned down the max power-draw 5W, and tested that. It happened again with a different background app this time. I tweaked it down another 5W (10W total), and it worked.
I didn’t see much of a performance difference in gaming, so I just kept it there. Never had any other issues.
Now, it could have been the 6600M, it could have been the power supply, it also could have been the Motherboard… not really sure how to track down the actual problem, but this solved it.
After furthermore testing i found the culprit. The issues were created by the NETWORK CARD. After removing it everything works perfectly fine. After about a week of going back and forth I’m finally playing dark souls again. Thanks everyone for the help.
So i think my guess was right… People should always point where or if they changed anything.
Its good that your system working again stable. But anyways, you still should fix your CPU heat problems or you will face a broken system in future.
The Hardware might be compensating this 96° for a certain time… doesn’t mean it should be ignored.
That’s awesome that you found the issue… but “who’da thunk” it’d be the network card, right?
Given the fact that it’s a laptop higher temps are expected. Yet I’m planning to put a few holes in the case for more airflow. I don’t really remember seeing any network problems to be fair. Before removing the card i reinstalled windows and bsods started pouring like rain. After analysing a few minidumps i saw a small warning on the network card and as a last thing i decided “f it, I’ll rip it out” and it’s clockwork since then, it’s working even better than before to be fair. Ds3 was playing on 90-100 fps now it’s clocked at 144 fps.
However, not the temperature you indicated; if one expects temperatures in those ranges, and does nothing to prevent it, then one can also expect the computer to have a somewhat brief life expectancy.
Of course, preventative maintenance for a laptop should really begin even before it’s purchased; research of options and capabilities; and most importantly, ignoring the salesperson who will gladly sell you a lemon. ![]()
Good to know the issue is no more.
