Hello,
after the last update gtkhash
stopped working, both the standalone application and the nemo extension, the versions I have installed are:
extra/gtkhash 1.5-2
extra/gtkhash-nemo 1.5-2
The error:
$ gtkhash
gtkhash: error while loading shared libraries: libmbedcrypto.so.7: cannot open shared object file: No such file or directory
and here are some versions and dependencies:
$ pactree -r libmbedcrypto.so
mbedtls provides libmbedcrypto.so
└─gtkhash
└─gtkhash-nemo
$ pacman -Qi mbedtls
Version : 3.4.0-2
Description : An open source, portable, easy to use, readable and flexible TLS library
Architecture : x86_64
URL : https://tls.mbed.org
Licenses : Apache
Groups : None
Provides : libmbedcrypto.so=14-64 libmbedtls.so=19-64 libmbedx509.so=5-64 polarssl
Depends On : glibc sh
Optional Deps : None
Required By : gtkhash
Optional For : None
Conflicts With : polarssl
Replaces : polarssl
Installed Size : 5,39 MiB
Packager : Maxime Gauduin <alucryd@archlinux.org>
Build Date : jue 25 may 2023 13:32:53
Install Date : jue 25 may 2023 18:22:15
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
I’m able to workaround this by creating a symbolic link:
$ sudo ln -s /usr/lib/libmbedcrypto.so /usr/lib/libmbedcrypto.so.7
Best regards.
