Hi,
Using lxappearance, I’ve selected Matcha-light-aliz as my gtk theme, but firefox, arandr, geary, and other gtk3 apps are still showing dark themes, even after a reboot. I’ve also selected a light theme in Kvantum (KvAdaptaMaia).
Any ideas?
system info
$ inxi -Fxxxza --no-host
System: Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=954cf137-75f3-4e46-8682-9f013e1bd856 rw quiet
cryptdevice=UUID=4110f216-65f4-48f0-8bbe-81a930fc1c74:luks-4110f216-65f4-48f0-8bbe-81a930fc1c74
root=/dev/mapper/luks-4110f216-65f4-48f0-8bbe-81a930fc1c74 apparmor=1 security=apparmor
resume=/dev/mapper/luks-c6d6abb3-a33a-4e43-b48c-c6131a7cb028 udev.log_priority=3
Desktop: i3 4.19.1 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Portable System: Dell product: Inspiron 5720 v: N/A serial: <filter> Chassis: type: 8 v: 0.1 serial: <filter>
Mobo: Dell model: 023HTX v: FAB1 serial: <filter> UEFI [Legacy]: Dell v: A03 date: 05/04/2012
Battery: ID-1: BAT0 charge: 32.8 Wh condition: 32.8/48.8 Wh (67%) volts: 12.4/11.1 model: SANYO Dell type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325 serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: Discharging
CPU: Info: Quad Core model: Intel Core i7-3612QM bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 L2 cache: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 33535
Speed: 1197 MHz min/max: 1200/3100 MHz Core speeds (MHz): 1: 1197 2: 1226 3: 1203 4: 1396 5: 1251 6: 1197 7: 1295
8: 1591
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0166 class ID: 0300
Device-2: Microdia Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-1.5:4 chip ID: 0c45:648d
class ID: 0e02
Display: x11 server: X.Org 1.20.10 driver: loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 930x285mm (36.6x11.2") s-diag: 973mm (38.3")
Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 107 size: 380x220mm (15.0x8.7") diag: 439mm (17.3")
Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1e20 class ID: 0403
Sound Server: ALSA v: k5.11.2-1-MANJARO
Network: Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel port: efa0 bus ID: 01:00.0 chip ID: 8086:0887
class ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: 2000
bus ID: 02:00.0 chip ID: 10ec:8136 class ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB driver: btusb v: 0.8 bus ID: 2-1.5:3
chip ID: 8087:07da class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 931.51 GiB used: 300.48 GiB (32.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1 size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 030 scheme: MBR
Partition: ID-1: / raw size: 922.71 GiB size: 907.23 GiB (98.32%) used: 300.48 GiB (33.1%) fs: ext4 dev: /dev/dm-0
maj-min: 254:0 mapped: luks-4110f216-65f4-48f0-8bbe-81a930fc1c74
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-c6d6abb3-a33a-4e43-b48c-c6131a7cb028
Sensors: System Temperatures: cpu: 63.0 C mobo: 41.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Info: Processes: 254 Uptime: 18m wakeups: 6 Memory: 7.64 GiB used: 2.05 GiB (26.8%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1148 pacman: 1143 lib: 327 flatpak: 5 Shell: Bash v: 5.1.0 running in: lxterminal
inxi: 3.3.01
