GTK Application Style Icons Setting Missing in KDE System Settings
This is my first question so sorry if I do not comply with some guidelines, if you think so, I am happy to fix the cause of matter.
Last time i tried to set the icon theme for GTK/GNOME applications in system settings it looked like this: GTK Icons Option in KDE Settings
Now it looks like this:
So my question is just where do I find/set the GNOME/GTK Icons theme setting?
[filip@filip-linux ~]$ inxi -Fxxxz
System:    Host: filip-linux Kernel: 5.4.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: KDE Plasma 5.18.3
           tk: Qt 5.14.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0 serial: <filter> UEFI: American Megatrends
           v: 1.D0 date: 11/07/2019
CPU:       Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86441
           Speed: 2119 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2057 2: 3739 3: 2193 4: 2170 5: 2062
           6: 2482 7: 2025 8: 2184 9: 2096 10: 3625 11: 1980 12: 2233
Graphics:  Device-1: NVIDIA GF108 [GeForce GT 630] vendor: ZOTAC driver: nvidia v: 390.132 bus ID: 26:00.0 chip ID: 10de:0f00
           Display: x11 server: X.Org 1.20.7 driver: nvidia compositor: kwin_x11 resolution: 1366x768~60Hz
           OpenGL: renderer: GeForce GT 630/PCIe/SSE2 v: 4.6.0 NVIDIA 390.132 direct render: Yes
Audio:     Device-1: NVIDIA GF108 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus ID: 26:00.1
           chip ID: 10de:0bea
           Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus ID: 28:00.4 chip ID: 1022:1487
           Sound Server: ALSA v: k5.4.28-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
           port: f000 bus ID: 22:00.0 chip ID: 10ec:8168
           IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 2.05 TiB used: 24.18 GiB (1.2%)
           ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter>
           rev: SS0328D scheme: GPT
           ID-2: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB speed: 6.0 Gb/s rotation: 7200 rpm
           serial: <filter> rev: 0001 scheme: GPT
Partition: ID-1: / size: 29.40 GiB used: 16.85 GiB (57.3%) fs: ext4 dev: /dev/nvme0n1p5
           ID-2: /home size: 68.40 GiB used: 7.31 GiB (10.7%) fs: ext4 dev: /dev/nvme0n1p6
Sensors:   System Temperatures: cpu: 44.2 C mobo: N/A gpu: nvidia temp: 43 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 52%
Info:      Processes: 277 Uptime: 1h 19m Memory: 15.65 GiB used: 1.79 GiB (11.5%) Init: systemd v: 244 Compilers: gcc: 9.3.0
           clang: 9.0.1 Shell: bash v: 5.0.16 running in: konsole inxi: 3.0.37
KDE devs removed it and applied icons theme in icon settings for GTK apps also.
That is not great.
I know, try changing theme name inside ~/.config/gtk-3.0/settings.ini and restart the session.
Maybe it could work, unless Plasma decide to overwrite the settings.
Plasma system settings has some lacks unfortunately.
