When i start from dmenu a program in terminal it starts in an ugly terminal, i presume it’s urxwt. I checked a bit and i found this, in /sbin/demenu_recency:
#!/bin/bash
# Originally based on code by Dieter Plaetinck.
# Pretty much re-written by Mina Nagy (mnzaki)
# Edited by Chrysostomus to create/source .dmenurc
#!/bin/bash
if ! [ -f "$HOME/.dmenurc" ]; then
cp /usr/share/dmenu/dmenurc $HOME/.dmenurc
fi
. $HOME/.dmenurc
if [ -z "$TERMINAL_CMD" ]; then
if [ "$(which terminal)" ]; then
TERMINAL_CMD="terminal -e" <-- here!
elif [ "$(which urxvt)" ]; then
TERMINAL_CMD="urxvt -e"
fi
fi
Now, i can change the settings easily in ~/.dmenurc, but i’d like to understand where the terminal in the first line is set. My ~.profile ist different and the gui settings as well.
$ which terminal
/usr/bin/terminal
$ cat `!!`
cat `which terminal`
#!/bin/sh
urxvtc $@
if [ $? -eq 2 ]; then
urxvtd -q -o -f
urxvtc $@
fi
And you can find out which package added that executable to the system like so:
$ pacman -Qo terminal
/usr/bin/terminal is owned by i3-arm-scripts 20200312-1
I am on an ARM based machine, so my terminal executable (which is just a simple shell script actually) comes from i3-arm-scripts, but this is probably different for you
I have nearly the same as you, although i’m not on a arm based machine (but an iMac). Only the number of the i3 scripts is different: 20200804-1
[Essentially, since i discovered what is possible with the combo kitty + ranger i’d like to set kitty as the all over default terminal, if that is possible/reasonable (??) ]
