Yes you can use any Manjaro ISO in theory. They should all have the manjaro-chroot tool.
Thatās the point if the Bug is only physical exploitable I think itās wasted time to reinstall grub?
Btw I use LUKS on my workstation
My philosophy is that if thereās an update available to a component of my system, then Iāll update it. Maybe thatās why Iāve found myself being on the unstable branch for so long.
You are absolutely right. My goal was to make a stress on certain points.
thanks,thatāll save me some download time and bandwidth,
but after reading this thread i think Iāll pass for the moment since i donāt dual boot and in order to install Manjaro i had to disable secure boot anyway.
My thoughts exactly!
this is part of the commit
Disable os-prober by default due to security reasons.
+GRUB_DISABLE_OS_PROBER="true"
No idea what the security reasons are?
Reinstall grub was very easy on my System LUKS / BTRFS
Need only these 3 steps in Live Env:
~$ su
root:~/ # grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
root:~/ # update-grub
root:~/ # reboot
I understand they did it on purpose, but why this doesnāt make sense to me. Iām not a dev OK, but I canāt find a reason to have it disabled by default for security reason, especially if now the reasons are fixed. Maybe a Manjaro staff have more explanation but to me it is wrong.
I cannot access to the page.
Private?
You think he is not able to install Chrome remote desktop or TeamViewer even if you text him how to do it?
You may want to edit your post a bit more as thereās more items than those 3 stepsā¦especially for a beginner to follow along to. My post was only for self-reference sake as itās specific to my setup and wasnāt really intended to be copied and pasted by anyoneā¦
Again methinks that a separate thread should be dedicated to it hint hint mods
Everything is possible I can even tell him command to write over the phone. Heās 70+ though and not very computer savy. Thatās not ideal. Anyway not really the point, it was just one example and there are a lot of people like that.
Donāt disregard mailing lists, everyone:
https://lists.gnu.org/archive/html/grub-devel/2021-03/msg00120.html
I plead guilty, I avoid mailing lists usually Thanks for providing more infos
There are more steps than this
https://wiki.manjaro.org/index.php?title=GRUB/Restore_the_GRUB_Bootloader
To explain my confusion another wayā¦
I thought the chroot
step to install grub
was only for users without current access to their Manjaro installation because grub
was broken, and a Live CD was needed in order to āhackā into your own computer to fix grub
on that machine?
Otherwise grub
just needed to be re-installed and updated as root on a working system?
Saw this from https://lists.gnu.org/archive/html/grub-devel/2021-03/msg00120.html
Currently autogenerating config files for multi-boot environments depends on
-os-prober and has several shortcomings. While fixing it is scheduled for the
-next release
Another thing that doesnāt make sense here at all is that without os-prober I didnāt even get proper GRUB. So there was no access to GRUB options, different kernels, firmware, emergency mode (whatever it is called) and so on. This all looked like a bug, all black and the small peak window with āWelcome to Grubā and nothing else, nothing actionable. My guess is, those things were there but not visible.
So how did the GRUB look like for you when this new default was on?
For me, it wasnāt just lack of the Windows options, it was simply LACK OF THE WHOLE GRUB OPTIONS. This went horribly wrong. Luckily, restoring os-prober fixed everything. So why without os-prober GRUB didnāt work correctly?
So far it looks we gave some very, very, very wide stretched security threat, almost none existent for most users, as it requires physical access to it and the āfixā that broke user space without warning. Itās like a classical case of fixing a tiny issue by creating a huge one for most users.
Iām a bit worried that Manjaro devs are mostly silent about this. I just hope they are gathering data till they take voice in this matter.
At the moment, the topic here feels like an irony. First, on a rolling release we have no choice, so calling for the update is unnecessary. Second, the update will most likely mess with brake user-space, because dual boots are a common thing, plus the lack of GRUB options like in my case.
The topic should be: URGENT MANUAL INTERVENTION AFTER GRUB UPDATE. So users could get acquainted with the topic and decide what to do and possibly fix GRUB by restoring old behavior, because the computer wonāt work correctly without it.
If new grub version was set to hidden, itās hiddenā¦ So black screen until system boots.
