Grub Warning
History : I had two NVMe drives connected & was having issues so decided to get rid of the one that had windows on it.
Removed it from the system. Rebooted into Manajro, updated grub & got this:
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
Followed by this warning
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
Manjaro is on nvme0n1. So…fix or ignore? I have rebooted & everything went OK.
…or just ignore it.
Thanks banjo. Should have searched first. My bad. :face_with_monocle:
edit: Yep. That got rid of it.
If you don’t want to see it at all (IIRC, this has to do with memtest86, then do:
sudo chmod -x /etc/grub.d/60_memtest86+
Then update GRUB
sudo update-grub
The error should go away on your next reboot.
Thanks merlock. That’s another way to go. I got rid of it by removing the same file>
I think I only saw that warning when updating grub not rebooting. (I updated grub because I got rid of windows.)
Yeah, I just finished reading about your NVMe adventure.
I’m gonna ask a question about your setup over there.
