I’m having issues with grub-mkconfig. It’s hanging when it encounters a lvm snapshot. I did let it run for a good 10+ minutes once and it didn’t generate any output, so the error I’m getting is preventing it from generating a grub.cfg. Below the File descriptor leaked message is not an error, based on what I’ve read, but that maybe incorrect. The first error is ‘grub-probe: error: unknown filesystem’
I been looking into this a while. It’s believed that it’s happening because grub is having issues with a read-only snapshot. But I believe grub lets you boot into lvm snapshots, for sure it lets you boot into zfs snapshots. I can’t use lvm if I can’t use snapshots with grub.
Any questions, advice, or guidance you got would be appreciated.
$ sudo lvs
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
home lv -wi-ao---- 30.00g
root lv -wi-ao---- 30.00g
swap lv -wi-ao---- 16.00g
$ sudo grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found Windows Boot Manager on /dev/sdb1@/efi/Microsoft/Boot/bootmgfw.efi
done
$ sudo ps aux |grep grub-
$ sudo lvcreate -L 30G -s -n root_013021_1 /dev/mapper/lv-root
Logical volume "root_013021_1" created.
$ sudo lvs
root lv owi-aos--- 30.00g
root_013021_1 lv swi-a-s--- 30.00g root 0.01
File descriptor 3 (pipe:[1849683]) leaked on vgs invocation. Parent PID 1017585: grub-probe
File descriptor 9 (pipe:[1849687]) leaked on vgs invocation. Parent PID 1017585: grub-probe
File descriptor 4 (pipe:[1849683]) leaked on vgs invocation. Parent PID 1017585: grub-probe
grub-probe: error: unknown filesystem.
/usr/bin/grub-probe: error: unknown filesystem.
Found Manjaro Linux (20.2.1) on /dev/mapper/lv-root_013021_1
[tty2]$ sudo ps aux |grep grub-
root 1016025 0.0 0.0 15664 7128 pts/4 S+ 22:35 0:00 sudo grub-mkconfig -o /boot/grub/grub.cfg
root 1016026 0.0 0.0 7604 4140 pts/4 S+ 22:35 0:00 /bin/sh /usr/bin/grub-mkconfig -o /boot/grub/grub.cfg
root 1017897 0.0 0.0 10416 1676 ? Ss 22:35 0:00 grub-mount /dev/mapper/lv-root_013021_1 /var/lib/os-prober/mount
Edit: I tested this same error happens on Arch as well. I physically unplugged every single drive I have except for /dev/sda and it’s still happening. The Arch wiki has an entry about this erorr, but only for ext4 file systems, not LVM. In the LVM section of the wiki it says to add lvm to the grub default file, that didn’t fix this error.
I’m at the point where there’s no more help I can find online and next step it to start debugging this. It’s something todo with grub-probe and then for some reason it attempts to mount the snapshot, the lvm snapshot is going tho have the same UUID as the filesystem it’s using, I can’t imagine any changes that I could make to /etc/fstab that would help convince grub to read it as it’s designed todo.
