Hello,
Yesterday 2 small packages showed up to download.
I downloaded/updated/restarted my Linux (I’m on Linux Kernel 5.10.23-1).
After my grub Menu just showed up again out of nowhere… it was set to hidden (and its still set on hidden) and the Grub Timeout (Bootmenu) went up to 10sec… i know there was a security reason and there was some changes related to grub 1 week ago.
All my settings in “/etc/default/grub” getting ignored now…
Grubsettings:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=1
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=a44dd3c4-f5f1-4587-8934-6f7413d28d4f udev.log_pri>
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
GRUB_DISABLE_OS_PROBER=false
Would be nice if someone could help me out.
Thanks in advance
EDIT:
I just edited and updated my grub again and the boot timeout changed, i just changed it from 0 to 1 and its doing his job now, but my other OS (Win7) is showed up and also Grub is still not hidden… i don’t want this feature if the security issue still persists.
I don’t need that option for grub anyways, because i change bootoptions inside Bios with F12 hotkey.
Is there still a security problem?
That’s the strange thing… i used update-grub several times now and its just get ignored.
Maybe i just have to edit the line that it won’t get ignored… where ever that problem related too.
I had Timeout=0 before and just after i changed it too 1, its just changed the time from 10sec to 1sec… but i used sudo update-grub atleast 3 times already without any solution.
Thanks… Do you know what happend with the security problem in grub? Is it solved?
This reinstall command is only for EFI installation, right?
Or should it work with MBR/Legacy Boot too?
Im better copy your command if something goes wrong with grub again… just in case
Anyways, i think i just recieved the rollback from the security hole with the last update (2 days ago, can’t remember the package name… iconpackage and something other…), that’s why the bootmenu had to show up again and the reason why GRUB_DISABLE_OS_PROBER=false showed up inside grub again after it got removed.
If you have another OS in Grub menu you can not hide the Grub menu. Setting timeout to 0 is also not valid it defaults to 10 seconds I think. 1 second is valid though.
//EDIT: it is specifically this part in grub.cfg file, when OS Prober is enabled then it forces the menu style and defaults 0 second timeout to 10 seconds
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows Boot Manager (on /dev/sdc1)' --class windows --class os $menuentry_id_option 'osprober-efi-181F-8A30' {
savedefault
insmod part_gpt
insmod fat
set root='hd2,gpt1'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd2,gpt1 --hint-efi=hd2,gpt1 --hint-baremetal=ahci2,gpt1 181F-8A30
else
search --no-floppy --fs-uuid --set=root 181F-8A30
fi
chainloader /efi/Microsoft/Boot/bootmgfw.efi
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
