I migrated my system from a different nvme to a new one.
And I upgraded my BIOS.
Now when booting, I get:
error: symbol 'grub_is_shim_lock_enabled' not found.
From what I understand I need to reinstall Grub to get it to successfully boot.
In BIOS I disabled Fast Boot (Not MRC Fast Boot)
disabled TPM
disabled CPM
disabled secure boot (and set one secure boot setting to custom)
on my ASUS mainboard.
In Grub menu, I “detected” the following efi boot loaders:
/efi/manjaro/grub64.efi
/efi/boot/bootx64.efi
I once used manjaro-chroot but I don’t think it works with btrfs and its auto-snapshot system that I enabled.
can I go by this tutorial on Fix grub on btrfs partition | panticz.de :
# mount the btrfs root subvolume
mount /dev/sda1 /mnt -o subvol=/
# (optional) set the default subvolume
btrfs sub set @ /mnt
mount /proc /mnt/proc --bind
mount /dev /mnt/dev --bind
mount /sys /mnt/sys --bind
chroot /mnt
grub-install /dev/sda
update-grub /dev/sda
# activate first partition
fdisk -l /dev/sda
Have you read the wiki, myself…
I just discovered with Manjaro Wiki
It was updated too
Solved, if anyone wants I can post the exact commands I ran.
If this thread is considered too much, or unnecessary, please feel free to delete it.
system
Closed
29 February 2024 11:51
5
