Grub problems. [solved]
Hi,
I installed Artix to see how it works and after uninstall this system the grub was gone ...
I tried to get the grub back by installing the Manjaro i have in a USB, with this command:
# grub-mkconfig -o /boot/grub.cfg
(from the terminal of the system in which i want to have the new grub).
-- then, after this, i go to gparted and remove the Manjaro/USB from the partition, but after reboot ... the grub is gone.
I don't know what is wrong, how can i recover the Grub now?.
Thanks.
Use search function upper right, "grub gohlip restore" :wink:
Have you considered using the wiki?
https://wiki.manjaro.org/index.php?title=Restore_the_GRUB_Bootloader
You need to Install Grub, not update-grub (what you did).
If you are on MBR/MSDOS type booting, just install grub at your drive.
If you are on UEFI, check current options in efibootmgr and re-order entries to have Manjaro 1st.
Check this tutorial for general help and if you have problems, post info (as advised in the tutorial).
sudo grub install /dev/sda
sudo update-grub
It works!
Thanks everybody for the links.
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
