Hi all. Newb here.
I have a problem with GRUB… I think.
I installed 6.0, but my system keep booting in 5.19 if I do not specifically change it every boot.
mhwd-kernel -li only shows 5.15 installed, but 5.19 and 6.0 is installed as well when I enter GRUB.
GRUB shows all 3, but automatically boots in 5.19
Manjaro KDE with BTRFS
Thank you
sudo grub-install --recheck --no-rs-codes
[sudo] password for sarge:
Installing for x86_64-efi platform.
Installation finished. No error reported.
sudo update-grub
Found linux image: /boot/vmlinuz-linux519-tkg-pds
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux519-tkg-pds.img
Found initrd fallback image: /boot/initramfs-linux519-tkg-pds-fallback.img
fgrep: warning: fgrep is obsolescent; using grep -F
Found linux image: /boot/vmlinuz-linux60-tkg-pds
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux60-tkg-pds.img
Found initrd fallback image: /boot/initramfs-linux60-tkg-pds-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Detecting snapshots ...
Found snapshot: 2022-10-13 17:22:44 | timeshift-btrfs/snapshots/2022-10-13_17-22-44/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2022-10-13 17:18:33 | timeshift-btrfs/snapshots/2022-10-13_17-18-33/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2022-10-13 06:15:54 | timeshift-btrfs/snapshots/2022-10-13_06-15-54/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2022-09-28 21:00:03 | timeshift-btrfs/snapshots/2022-09-28_21-00-03/@ | weekly | N/A |
Found snapshot: 2022-07-30 10:05:29 | timeshift-btrfs/snapshots/2022-07-30_10-05-28/@ | ondemand | N/A |
Found 5 snapshot(s)
Unmount /tmp/grub-btrfs.dz2RFiRLDj .. Success
done
mhwd-kernel -li
Currently running: 5.19.15-270-tkg-pds (linux519)
* linux515
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT="true"
