After following a tutorial to fix something (can’t remember what exactly) it recommended me to do the command grub-update. After rebooting after this, my system launches with the error:
error: can’t find command ‘fwsetup’.
Press any key to continue…
Failed to boot both default and fallback entries.
And after continuing both my Windows and Manjaro options were gone. I don’t want to try and fix stuff myself with my limited knowledge as I would probably break stuff further.
inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 5.15.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2125 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0
i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: P8H61-I LX R2.0 v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1106
date: 06/20/2014
RAM: total: 15.58 GiB used: 3.06 GiB (19.6%)
RAM Report:
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1671 high: 2117 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1601 2: 1601 3: 1601
4: 1601 5: 1600 6: 2117 7: 1653 8: 1601 bogomips: 54430
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms
est f16c flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tsc tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA TU116 [GeForce GTX 1660] driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:2184
class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
OpenGL: renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aeb class-ID: 0403
Device-3: Trust GXT 232 Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-1.1.2:7
chip-ID: 145f:0254 class-ID: 0300
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Local Storage: total: 1.37 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 28.82 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: K1B3 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000VM002-1ET162
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: ZZZZ scheme: MBR
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 3.54 GiB fs: iso9660
ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: EAE6-38D6
ID-3: /dev/sdb1 maj-min: 8:17 size: 579 MiB fs: ntfs
label: System Reserved uuid: D432AC8732AC7062
ID-4: /dev/sdb2 maj-min: 8:18 size: 387.97 GiB fs: ntfs label: N/A
uuid: FE38AEBD38AE7475
ID-5: /dev/sdb3 maj-min: 8:19 size: 58.59 GiB fs: ext4 label: N/A
uuid: f9952d03-0f12-41ad-b4ef-eb741110d281
ID-6: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ntfs label: New Volume
uuid: 34D8D32FD8D2EE5C
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 2-1.1:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 2-1.1.1:6 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 300mA chip-ID: 0951:1666 class-ID: 0806
serial: <filter>
Device-2: 2-1.1.2:7 info: Trust GXT 232 Microphone type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 145f:0254 class-ID: 0300
Device-3: 2-1.3:4 info: Maxxter Wireless Receiver type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 248a:8564 class-ID: 0301
Device-4: 2-1.4:5 info: Areson Corp 2.4G Wireless Receiver
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 98mA chip-ID: 25a7:fa70 class-ID: 0301
Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Processes: 240 Uptime: 2m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1236 lib: 332
flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.13
