GRUB not loading after new installation
I installed Manjaro Cinnamon on my PC to use it as a dual-boot with Windows 10. However, Windows 10 keeps loading every time and I am forced to use the LiveCD and boot the .efi from there.
I used this guide to help install Manjaro as a dual-boot https://forum.manjaro.org/t/wiki-windows-10-manjaro-dual-boot-step-by-step/52668 however as mentioned earlier Windows 10 boots and no grub is shown. I also did try this https://forum.manjaro.org/t/using-livecd-v17-0-1-as-grub-to-boot-os-with-broken-bootloader/24916, but it didn't solve my problem. What else can I do from here?
(Lenovo H415 PC)
Timeout: 0 seconds
BootOrder: 0002,0000,0005,0006,0001,0003,0007,0004
Boot0000* Windows Boot Manager	HD(2,GPT,d06b4829-2a2c-4499-8592-e88caefc863c,0x1f4800,0x82000)/File(\EFI\boot\bootx64.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...t................
Boot0001* TSSTcorp DVD-RW SH-216BB	BBS(CDROM,,0x0)AMBO
Boot0002* manjaro	HD(9,GPT,2dba3410-c086-438f-b230-4f360902d150,0x5fbc8000,0x100000)/File(\EFI\manjaro\grubx64.efi)
Boot0003* ST1000DM003-9YN162	BBS(HD,,0x0)AMBO
Boot0004* Realtek PXE B02 D00	BBS(Network,,0x0)AMBO
Boot0005* Windows Boot Manager	HD(2,GPT,d06b4829-2a2c-4499-8592-e88caefc863c,0x1f4800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)
Boot0006* UEFI: Generic Mass-Storage 1.09	PciRoot(0x0)/Pci(0x12,0x2)/USB(1,0)/HD(1,MBR,0x0,0x3f31d4,0x2000)AMBO
Boot0007* Generic Mass-Storage 1.09	BBS(HD,,0x0)AMBO```
```Model: ATA ST1000DM003-9YN1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name                          Flags
 1      1049kB  1050MB  1049MB  ntfs                                          hidden, diag
 2      1050MB  1322MB  273MB   fat32           EFI system partition          boot, esp
 3      1322MB  1847MB  524MB   fat32                                         hidden
 4      1847MB  1981MB  134MB                   Microsoft reserved partition  msftres
 5      2019MB  822GB   820GB   ntfs            Basic data partition          msftdata
 9      822GB   823GB   537MB   fat32                                         msftdata
10      823GB   826GB   3196MB  linux-swap(v1)
11      826GB   973GB   147GB   ext4            Manjaro
 6      973GB   974GB   929MB   ntfs                                          hidden, diag
 7      974GB   974GB   367MB   ntfs                                          hidden, diag
 8      974GB   1000GB  26.2GB  ntfs                                          hidden, diag
/dev/sda2: LABEL="SYSTEM_DRV" UUID="2248-931D" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="d06b4829-2a2c-4499-8592-e88caefc863c"
/dev/sda3: LABEL="LRS_ESP" UUID="863E-76BC" TYPE="vfat" PARTUUID="aad8d0ff-bf90-4946-9e8e-ca91e7bd1c1e"
/dev/sda5: LABEL="FM-PC" UUID="01D513473F1871B0" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="510dfdb2-bb44-4686-8611-f5706f6e0762"
/dev/sda6: UUID="9EE649B4E6498D89" TYPE="ntfs" PARTUUID="6ed2e3b1-b6ae-4675-9a55-cb0572b99c23"
/dev/sda7: UUID="36D6827AD68239DF" TYPE="ntfs" PARTUUID="365b3626-f6fb-464b-9947-a9e71d9ac4bf"
/dev/sda8: LABEL="PBR_DRV" UUID="5EAE380BAE37DA6B" TYPE="ntfs" PARTUUID="c791a865-a873-405a-b051-cac0ece30b13"
/dev/sda9: UUID="2A84-262C" TYPE="vfat" PARTUUID="2dba3410-c086-438f-b230-4f360902d150"
/dev/sda10: UUID="97099072-82ca-4c3c-8f8e-1f79ffdd95ee" TYPE="swap" PARTUUID="e8c7321e-ae7b-42de-bb80-4b118e918cc9"
/dev/sda11: UUID="0f908a44-23a3-47a7-b5b3-ebd5e52bbdaa" TYPE="ext4" PARTLABEL="Manjaro" PARTUUID="b78e7920-5f37-4ea3-894c-87c9590e877c"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda4: PARTLABEL="Microsoft reserved partition" PARTUUID="033fb1b1-a81e-4e91-a994-2c27e11a6261"
/boot/efi UUID=2A84-262C                            vfat   defaults,noatime
swap      UUID=97099072-82ca-4c3c-8f8e-1f79ffdd95ee swap   defaults,noatime
/         UUID=0f908a44-23a3-47a7-b5b3-ebd5e52bbdaa ext4   defaults,noatime
/boot/efi /dev/sda9 vfat   rw,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro
only one /boot/efi witf flag boot&esp is sda2
not sda9 not sda3
Have you done the 2 [Additional UEFI commands] in the 2nd link you referenced? Make sure you use sda9 in that 2nd command. And I suggest another (third) command just for you
sudo parted /dev/sda set 9 boot on
Then check with 'efibootmgr' that 'manjaro' entry is there and is default bootorder (first in order)
If you reboot and you still wont boot to manjaro, boot up (your way) and check again 'efibootmgr' if the manjaro entry is missing. If it is missing, you most likely have a Lenovo that is tied up with Microsoft. Then see the Lenovo link [Difficult UEFI setups] in that referenced link, but remember you may have the Windows efi file in another $esp to work on (sda2)
