Every time I reboot my laptop I get thrown into grub rescue:
Attempting to decrypt master key…
Enter passphrase for hd0, gpt2 (disk uuid)
error: access denied.
error: no such cryptodisk found.
error: disk ‘cryptouuid/uuid’ not found.
Entering rescue mode…
I reinstall grub using the wiki article and chroot in
Everything goes smoothly until I have to do “mount -t efivarfs efivarfs /sys/firmware/efi/efivarfs” where it gives me the error “no such mount point”
ls /sys/firmware/efi verifies that the efi filesystem is loaded though
so I do mkdir -p /sys/firmware/efi/efivarfs and it says “Cannot create directory: read-only file system”.
I can’t find anything to do about that error so I abandon it and move onto the next step the wiki tells me to do which is reinstall grub again.
Sometimes it works when I initially reboot but never the second time after the grub reinstallation.
This is the third time today I’ve reinstalled grub…
edit:
trying to reinstall grub for the 4th time today
]# cryptsetup luksOpen /dev/sda2 crypto
Enter passphrase for /dev/sda2: * I enter the passphrase *
No key available with this passphrase.
I entered the passphrase 9 times and went slowly twice and it gave me the same error every single time.
I think my ssd is ■■■■■■■
