Grub menu not shown when booting, instead Manjaro boots up
grub
dual-boot
#1
After a clean install I’m not getting grub menu option to choose other os, instead Manjaro boots up by default
I tried changing the time out but no luck.
#2
See here, the relevant part …
#3
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR='Manjaro'
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=84e06bdf-1941-42b8-b949-3d8579926157"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
this is my grub config
#4
Change this part
to this:
#GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
and then:
sudo update-grub
#5
thank u for ur help…
sudo grub-editenv - unset menu_auto_hide
i think i’ll close this topic too…
Thank u, cheers
#6
How you do that ?
#7
:sweat_smile::sweat_smile:
By not responding :stuck_out_tongue_winking_eye:
#8
Good that you find your answer … As i don’t deal with silent-grub (or whatever), for me the editenv was not so obvious to deal with. I’ll mark your comment as solution.
#9
@bogdancovaciu
Your solution is okay but must do ‘grub-install’ and then do ‘update-grub’.
Best to clear out gubenv also - ‘rm /boot/grub/grubenv’
Cheers.
