Hi! I’ve been using Manjaro and Windows on a single M.2 SSD for a long time now. And so far, I have not run into any major issues. But today, my PC suddenly shut down all by itself whilst I was using Manjaro. It kept shutting down, and it couldn’t even boot the motherboard. I discovered I had to clean my PC, and that resolved the shutdown issue.
However, when I tried to start the PC up again after that, it just booted straight into Windows. Usually the GRUB menu would show up and let me choose. Now I’m seemingly unable to boot into my Manjaro-partition. I assume I have to fix GRUB somehow, but I ofc have no clue how to do that. I could install Manjaro again from scratch, but that would probably mean loosing much progress in games that have obscure save-locations, and I would have to reinstall all of my programs, change settings etc etc…
Ok, so I’m not that good at the terminal, but I’m trying to follow the steps from the link you gave me. Tnx a whole bunch btw! I try to run manjaro-chroot -a, but it prints out this in console:
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Detected systems
--> 0) ManjaroLinux
==> Select system to mount [0-0]:
Responding to the prompt with 0 or nothing returns this message: ==> ERROR: You can't mount 0!
