GRUB issue (grub_rescue)
DISCLAIMER I am transitioning from Windows to Linux, I have little experience with this.
HISTORY
After manjaro failed, windows started booting without entering GRUB.
Now, GRUB prevents my Linux system from working.
DESCRIPTION
When trying to install Manjaro 18 on my system, GRUB entered rescue mode. I searched the web for solutions, but none of them worked. (I used Rufus to burn the .isos)
I couldn’t find any relevant information by using “set” command on the grub_rescue> menu. Every ls, insmod, normal, etc, command returned no useful information (Filesystem not known or similar).
Manjaro 17 installs normally, but prevents me from updating its own repositories and, consequently, GRUB.
I tried SuperGrubDisk2, Rescatux and lastly the boot-repair program (this last one through Ubuntu Live).
The SuperGrubDisk2 found every OS and succeeded in running GRUB (yes, it’s pure magic), but was not able to restore it.
Rescatux did basically the same thing, but using a graphic interface.
The boot-repair program made this log:
http://paste.ubuntu.com/p/PfChb4x78k/
============================= Boot Info Summary: ===============================
 => Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector
    1660422608 of the same hard drive for core.img. core.img is at this
    location and looks for (,gpt8)/boot/grub. It also embeds following
    components:
    modules
    fshelp ext2 part_gpt biosdisk
 => Syslinux MBR (5.00 and higher) is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  Windows 8/2012: FAT32
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /EFI/Boot/bootx64.efi /EFI/Manjaro/grubx64.efi
                       /EFI/Microsoft/Boot/bootmgfw.efi
                       /EFI/Microsoft/Boot/bootmgr.efi
                       /EFI/Microsoft/Boot/memtest.efi
sda2: __________________________________________________________________________
    File system:
    Boot sector type:  -
    Boot sector info:
    Mounting failed:   mount: /mnt/BootInfo/sda2: unknown filesystem type ''.
sda3: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows 8/2012: NTFS
    Operating System:
    Boot files:        /bootmgr /Windows/System32/winload.exe
sda4: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:
sda5: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:
sda6: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:
sda7: __________________________________________________________________________
    File system:       vfat
    Operating System:
                       /EFI/Microsoft/Boot/LrsBootmgr.efi
                       /EFI/Microsoft/Boot/memtest.efi /bootmgr /boot/bcd
sda8: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  Manjaro Linux
    Boot files:        /boot/grub/grub.cfg /etc/fstab
                       /boot/grub/i386-pc/core.img
sdb1: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  SYSLINUX 6.04
    Boot sector info:  Syslinux looks at sector 32800 of /dev/sdb1 for its
                       second stage. The integrity check of Syslinux failed.
    Operating System:
    Boot files:        /boot/grub/grub.cfg /syslinux.cfg
                       /EFI/BOOT/grubx64.efi /ldlinux.sys
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1                   1 1,953,525,167 1,953,525,167  ee GPT
GUID Partition Table detected.
Partition  Attrs   Start Sector    End Sector  # of Sectors System
/dev/sda1                 2,048       534,527       532,480 EFI System partition
/dev/sda2               534,528       567,295        32,768 Microsoft Reserved Partition (Windows)
/dev/sda3               567,296 1,022,593,023 1,022,025,728 Data partition (Windows/Linux)
/dev/sda4         1,860,225,024 1,912,653,823    52,428,800 Data partition (Windows/Linux)
/dev/sda5      R  1,912,653,824 1,914,701,823     2,048,000 Windows Recovery Environment (Windows)
/dev/sda6         1,914,701,824 1,951,475,711    36,773,888 Windows Recovery Environment (Windows)
/dev/sda7      R  1,951,475,712 1,953,523,711     2,048,000 -
/dev/sda8         1,022,593,024 1,860,225,023   837,632,000 Data partition (Linux)
Attributes: R=Required, N=No Block IO, B=Legacy BIOS Bootable, +=More bits set
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 14.3 GiB, 15376318464 bytes, 30031872 sectors
Disklabel type: dos
/dev/sdb1    *          2,048    30,031,871    30,029,824   c W95 FAT32 (LBA)
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/loop0                                              squashfs
/dev/loop1                                              squashfs
/dev/loop2                                              squashfs
/dev/loop3                                              squashfs
/dev/loop4                                              squashfs
/dev/loop5                                              squashfs
/dev/loop6                                              squashfs
/dev/loop7                                              squashfs
/dev/sda1        22A9-D559                              vfat       SYSTEM_DRV
/dev/sda2
/dev/sda3        4A86ABDD86ABC7B1                       ntfs       Windows
/dev/sda4        9CE48BCFE48BAA5A                       ntfs       LENOVO
/dev/sda5        0C92A96A92A9594A                       ntfs       WINRE_DRV
/dev/sda6        04B62A3CB62A2E9C                       ntfs       LENOVO_PART
/dev/sda7        E62B-CBC0                              vfat       LRS_ESP
/dev/sda8        195246a9-3b82-4f07-a4c1-2fddcbb6602c   ext4
/dev/sdb1        22D0-4D49                              vfat       UBUNTU 18_1
========================= "ls -l /dev/disk/by-id" output: ======================
total 0
lrwxrwxrwx 1 root root  9 Dec 29 13:23 ata-HL-DT-ST_DVDRAM_GUE0N_KLMG1FA5442 -> ../../sr0
lrwxrwxrwx 1 root root  9 Dec 29 13:27 ata-WDC_WD10JPCX-24UE4T0_WD-WX41AB51HL22 -> ../../sda
lrwxrwxrwx 1 root root 10 Dec 29 13:27 ata-WDC_WD10JPCX-24UE4T0_WD-WX41AB51HL22-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Dec 29 13:27 ata-WDC_WD10JPCX-24UE4T0_WD-WX41AB51HL22-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Dec 29 13:27 ata-WDC_WD10JPCX-24UE4T0_WD-WX41AB51HL22-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Dec 29 13:30 ata-WDC_WD10JPCX-24UE4T0_WD-WX41AB51HL22-part4 -> ../../sda4
lrwxrwxrwx 1 root root 10 Dec 29 13:30 ata-WDC_WD10JPCX-24UE4T0_WD-WX41AB51HL22-part5 -> ../../sda5
lrwxrwxrwx 1 root root 10 Dec 29 13:30 ata-WDC_WD10JPCX-24UE4T0_WD-WX41AB51HL22-part6 -> ../../sda6
lrwxrwxrwx 1 root root 10 Dec 29 13:27 ata-WDC_WD10JPCX-24UE4T0_WD-WX41AB51HL22-part7 -> ../../sda7
lrwxrwxrwx 1 root root 10 Dec 29 13:27 ata-WDC_WD10JPCX-24UE4T0_WD-WX41AB51HL22-part8 -> ../../sda8
lrwxrwxrwx 1 root root  9 Dec 29 13:27 usb-SanDisk_Ultra_Fit_4C531001540203104592-0:0 -> ../../sdb
lrwxrwxrwx 1 root root 10 Dec 29 13:27 usb-SanDisk_Ultra_Fit_4C531001540203104592-0:0-part1 -> ../../sdb1
lrwxrwxrwx 1 root root  9 Dec 29 13:23 wwn-0x5001480000000000 -> ../../sr0
lrwxrwxrwx 1 root root  9 Dec 29 13:27 wwn-0x50014ee6b1041243 -> ../../sda
lrwxrwxrwx 1 root root 10 Dec 29 13:27 wwn-0x50014ee6b1041243-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Dec 29 13:27 wwn-0x50014ee6b1041243-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Dec 29 13:27 wwn-0x50014ee6b1041243-part3 -> ../../sda3
lrwxrwxrwx 1 root root 10 Dec 29 13:30 wwn-0x50014ee6b1041243-part4 -> ../../sda4
lrwxrwxrwx 1 root root 10 Dec 29 13:30 wwn-0x50014ee6b1041243-part5 -> ../../sda5
lrwxrwxrwx 1 root root 10 Dec 29 13:30 wwn-0x50014ee6b1041243-part6 -> ../../sda6
lrwxrwxrwx 1 root root 10 Dec 29 13:27 wwn-0x50014ee6b1041243-part7 -> ../../sda7
lrwxrwxrwx 1 root root 10 Dec 29 13:27 wwn-0x50014ee6b1041243-part8 -> ../../sda8
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/loop0       /rofs                    squashfs   (ro,noatime)
/dev/sda8        /mnt/boot-sav/sda8       ext4       (rw,relatime)
/dev/sdb1        /cdrom                   vfat       (ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
=========================== sda8/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_gpt
insmod ext2
set root='hd0,gpt8'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt8 --hint-efi=hd0,gpt8 --hint-baremetal=ahci0,gpt8  195246a9-3b82-4f07-a4c1-2fddcbb6602c
else
  search --no-floppy --fs-uuid --set=root 195246a9-3b82-4f07-a4c1-2fddcbb6602c
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=en_US
  insmod gettext
fi
terminal_input console
terminal_output gfxterm
insmod part_gpt
insmod ext2
set root='hd0,gpt8'
else
fi
insmod png
background_image -m stretch /usr/share/grub/background.png
if [ x$feature_timeout_style = xy ] ; then
  set timeout_style=menu
  set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
  set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-195246a9-3b82-4f07-a4c1-2fddcbb6602c' {
	savedefault
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt8'
	else
	fi
	echo	'Loading Linux 4.14.11-3-MANJARO x64 ...'
	linux	/boot/vmlinuz-4.14-x86_64 root=UUID=195246a9-3b82-4f07-a4c1-2fddcbb6602c rw  quiet
	echo	'Loading initial ramdisk ...'
	initrd	/boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
submenu 'Advanced options for Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-195246a9-3b82-4f07-a4c1-2fddcbb6602c' {
	menuentry 'Manjaro Linux (Kernel: 4.14.11-3-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.14.11-3-MANJARO x64-advanced-195246a9-3b82-4f07-a4c1-2fddcbb6602c' {
	savedefault
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt8'
		else
		fi
	menuentry 'Manjaro Linux (Kernel: 4.14.11-3-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.14.11-3-MANJARO x64-fallback-195246a9-3b82-4f07-a4c1-2fddcbb6602c' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt8'
		else
		fi
		initrd	/boot/intel-ucode.img /boot/initramfs-4.14-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows Recovery Environment (on /dev/sda7)' --class windows --class os $menuentry_id_option 'osprober-chain-E62B-CBC0' {
	savedefault
	insmod part_gpt
	insmod fat
	set root='hd0,gpt7'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt7 --hint-efi=hd0,gpt7 --hint-baremetal=ahci0,gpt7  E62B-CBC0
	else
	  search --no-floppy --fs-uuid --set=root E62B-CBC0
	fi
	drivemap -s (hd0) ${root}
	chainloader +1
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
    menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
        search --fs-uuid --no-floppy --set=root --hint-bios=hd0,gpt8 --hint-efi=hd0,gpt8 --hint-baremetal=ahci0,gpt8  195246a9-3b82-4f07-a4c1-2fddcbb6602c
        linux16 /boot/memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
=============================== sda8/etc/fstab: ================================
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=195246a9-3b82-4f07-a4c1-2fddcbb6602c /              ext4    defaults,noatime 0 1
UUID=22A9-D559	/boot/efi	vfat	defaults	0	1
=================== sda8: Location of files loaded by Grub: ====================
           GiB - GB             File                                 Fragment(s)
 791.752994537 = 850.138304512  boot/grub/grub.cfg                             2
 527.753196716 = 566.670680064  boot/grub/i386-pc/core.img                     1
 527.741321564 = 566.657929216  boot/vmlinuz-4.14-x86_64                       1
 488.719722748 = 524.758806528  boot/initramfs-4.14-x86_64-fallback.img        2
 527.748149872 = 566.665261056  boot/initramfs-4.14-x86_64.img                 1
=========================== sdb1/boot/grub/grub.cfg: ===========================
if loadfont /boot/grub/font.pf2 ; then
	set gfxmode=auto
	insmod efi_gop
	insmod efi_uga
	insmod gfxterm
fi
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
set timeout=5
menuentry "Try Ubuntu without installing" {
	set gfxpayload=keep
	linux	/casper/vmlinuz  file=/cdrom/preseed/ubuntu.seed boot=casper quiet splash ---
	initrd	/casper/initrd
menuentry "Install Ubuntu" {
	set gfxpayload=keep
	linux	/casper/vmlinuz  file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity quiet splash ---
menuentry "OEM install (for manufacturers)" {
	set gfxpayload=keep
	linux	/casper/vmlinuz  file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity quiet splash oem-config/enable=true ---
menuentry "Check disc for defects" {
	set gfxpayload=keep
	linux	/casper/vmlinuz  boot=casper integrity-check quiet splash ---
============================== sdb1/syslinux.cfg: ==============================
DEFAULT loadconfig
LABEL loadconfig
  CONFIG /isolinux/isolinux.cfg
  APPEND /isolinux/
=================== sdb1: Location of files loaded by Grub: ====================
            ?? = ??             boot/grub/grub.cfg                             1
================= sdb1: Location of files loaded by Syslinux: ==================
            ?? = ??             syslinux.cfg                                   1
            ?? = ??             ldlinux.sys                                    1
======================== Unknown MBRs/Boot Sectors/etc: ========================
Unknown GPT Partiton Type
e7afbfbf4fa38a449a5b6213eb736c22
=============================== StdErr Messages: ===============================
File descriptor 9 (/proc/6289/mountinfo) leaked on lvs invocation. Parent PID 21666: bash
File descriptor 63 (pipe:[84518]) leaked on lvs invocation. Parent PID 21666: bash
ADDITIONAL INFORMATION :
=================== log of boot-repair 20181229_1326 ===================
boot-repair version : 4ppa65
boot-sav version : 4ppa65
boot-sav-extra version : 4ppa65
glade2script version : 3.2.3~ppa4
boot-repair is executed in live-session (Ubuntu 18.10, cosmic, Ubuntu, x86_64)
CPU op-mode(s):      32-bit, 64-bit
BOOT_IMAGE=/casper/vmlinuz file=/cdrom/preseed/ubuntu.seed boot=casper quiet splash ---
ls: cannot access '/home/usr/.config': No such file or directory
The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Falling back to read-only mount because the NTFS partition is in an
unsafe state. Please resume and shutdown Windows fully (no hibernation
or fast restarting.)
=================== os-prober:
/dev/sda1@/efi/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi
/dev/sda8:Manjaro Linux (17.1.1):ManjaroLinux:linux
=================== blkid:
/dev/sda1: LABEL="SYSTEM_DRV" UUID="22A9-D559" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="677b85db-3371-4645-8d90-000020f8f998"
/dev/sda3: LABEL="Windows" UUID="4A86ABDD86ABC7B1" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="6acef6d8-c71a-4ff4-a0bc-6fed040aeec1"
/dev/sda4: LABEL="LENOVO" UUID="9CE48BCFE48BAA5A" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="489f8c1b-7fcd-4bb9-9e48-b06868be62f1"
/dev/sda5: LABEL="WINRE_DRV" UUID="0C92A96A92A9594A" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="dbf3675e-a956-4bfb-9aaa-8eede630e4d7"
/dev/sda6: LABEL="LENOVO_PART" UUID="04B62A3CB62A2E9C" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="d47666bf-a1b6-4913-b4e3-1446dd0f7629"
/dev/sda7: LABEL="LRS_ESP" UUID="E62B-CBC0" TYPE="vfat" PARTLABEL="Basic data partition" PARTUUID="6fb6c4af-a0f9-4c96-a5f4-487ce88be9bb"
/dev/sda8: UUID="195246a9-3b82-4f07-a4c1-2fddcbb6602c" TYPE="ext4" PARTUUID="525ad036-8d2e-43b2-8096-704819bbec82"
/dev/sdb1: LABEL="UBUNTU 18_1" UUID="22D0-4D49" TYPE="vfat" PARTUUID="00918134-01"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda2: PARTLABEL="Microsoft reserved partition" PARTUUID="e9bc1c42-be1a-4d23-ad9b-ea55f88cf4c0"
1 disks with OS, 2 OS : 1 Linux, 0 MacOS, 1 Windows, 0 unknown type OS.
Windows not detected by os-prober on sda3.
=================== No kernel in /mnt/boot-sav/sda1/boot:
BOOT.SDI
Presence of EFI/Microsoft file detected: /mnt/boot-sav/sda1/EFI/Microsoft/Boot/bootmgfw.efi
Presence of EFI/Boot file detected: /mnt/boot-sav/sda1/EFI/Boot/bootx64.efi
Presence of EFI/Microsoft file detected: /mnt/boot-sav/sda7/EFI/Microsoft/Boot/LrsBootmgr.efi
Presence of EFI/Boot file detected: /mnt/boot-sav/sda7/EFI/Boot/bootx64.efi
=================== sda8/etc/grub.d/ :
drwxr-xr-x 2 root root   4096 Jan  5  2018 grub.d
total 64
-rwxr-xr-x 1 root root  8871 Dec  1  2017 00_header
-rwxr-xr-x 1 root root 10980 Dec  1  2017 10_linux
-rwxr-xr-x 1 root root 10793 Dec  1  2017 20_linux_xen
-rwxr-xr-x 1 root root 11314 Dec  1  2017 30_os-prober
-rwxr-xr-x 1 root root   214 Dec  1  2017 40_custom
-rwxr-xr-x 1 root root   216 Dec  1  2017 41_custom
-rwxr-xr-x 1 root root  1219 Aug  3  2016 60_memtest86+
-rw-r--r-- 1 root root   483 Dec  1  2017 README
=================== sda8/etc/default/grub :
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR='Manjaro'
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to enable Hidden Menu, and optionally hide the timeout count
#GRUB_HIDDEN_TIMEOUT=5
#GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_BACKGROUND="/usr/share/grub/background.png"
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
/usr/share/boot-sav/bs-cmd_terminal.sh: line 179: warning: command substitution: ignored null byte in input
=================== efibootmgr -v
BootCurrent: 0003
Timeout: 0 seconds
BootOrder: 0003,0004,0000,0001,0005,0002,0006,2001,2002,2003
Boot0000* WDC WD10JPCX-24UE4T0            	BBS(HD,WDC WD10JPCX-24UE4T0            ,0x500)................-.e.......e.A.e.....................................k..
Boot0001* HL-DT-ST DVDRAM GUE0N           	BBS(CDROM,HL-DT-ST DVDRAM GUE0N           ,0x500)................-.l.......l.A.l.....................................k..
Boot0002* SanDisk	BBS(HD,SanDisk,0x500)..................................................................9.k..
Boot0003* Linpus lite	HD(1,MBR,0x918134,0x800,0x1ca3800)/File(EFIBootgrubx64.efi)RC
Boot0004* Windows Boot Manager	HD(1,GPT,677b85db-3371-4645-8d90-000020f8f998,0x800,0x82000)/File(EFIMicrosoftBootbootmgfw.efi)RC
Boot0005* Realtek PXE B01 D00	BBS(128,Realtek PXE B01 D00,0x0).......................................................................
Boot0006* Lenovo Recovery System	HD(7,GPT,6fb6c4af-a0f9-4c96-a5f4-487ce88be9bb,0x74512800,0x1f4000)/File(EFIMicrosoftBootLrsBootMgr.efi)RC
Boot0007* Windows Boot Manager	HD(1,GPT,677b85db-3371-4645-8d90-000020f8f998,0x800,0x82000)/File(EFIMicrosoftBootbootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...................
Boot2001* EFI USB Device	RC
Boot2002* EFI DVD/CDROM	RC
Boot2003* EFI Network	RC
=================== UEFI/Legacy mode:
BIOS is EFI-compatible, and is setup in EFI-mode for this live-session.
SecureBoot disabled. (maybe sec-boot, Please report this message to boot.repair@gmail.com)
=================== PARTITIONS & DISKS:
sda1	: sda,	not-sepboot,	no-grubenv	nogrub,	no-docgrub,	no-update-grub,	32,	no-kernel,	is-os,	is-correct-EFI,	part-has-no-fstab,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-bmgr,	notwinboot,	nopakmgr,	nogrubinstall,	no---usr,	part-has-no-fstab,	not-sep-usr,	standard,	not-far,	notbiosboot, /mnt/boot-sav/sda1.
sda3	: sda,	not-sepboot,	no-grubenv	nogrub,	no-docgrub,	no-update-grub,	32,	no-boot,	is-os,	not--efi--part,	part-has-no-fstab,	part-has-no-fstab,	no-nt,	haswinload,	no-recov-nor-hid,	bootmgr,	notwinboot,	nopakmgr,	nogrubinstall,	no---usr,	part-has-no-fstab,	not-sep-usr,	standard,	farbios,	notbiosboot, /mnt/boot-sav/sda3.
sda4	: sda,	not-sepboot,	no-grubenv	nogrub,	no-docgrub,	no-update-grub,	32,	no-boot,	no-os,	not--efi--part,	part-has-no-fstab,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-bmgr,	notwinboot,	nopakmgr,	nogrubinstall,	no---usr,	part-has-no-fstab,	not-sep-usr,	standard,	farbios,	notbiosboot, /mnt/boot-sav/sda4.
sda5	: sda,	not-sepboot,	no-grubenv	nogrub,	no-docgrub,	no-update-grub,	32,	no-boot,	no-os,	not--efi--part,	part-has-no-fstab,	part-has-no-fstab,	no-nt,	no-winload,	recovery-or-hidden,	no-bmgr,	notwinboot,	nopakmgr,	nogrubinstall,	no---usr,	part-has-no-fstab,	not-sep-usr,	standard,	farbios,	notbiosboot, /mnt/boot-sav/sda5.
sda6	: sda,	not-sepboot,	no-grubenv	nogrub,	no-docgrub,	no-update-grub,	32,	no-boot,	no-os,	not--efi--part,	part-has-no-fstab,	part-has-no-fstab,	no-nt,	no-winload,	recovery-or-hidden,	no-bmgr,	notwinboot,	nopakmgr,	nogrubinstall,	no---usr,	part-has-no-fstab,	not-sep-usr,	standard,	farbios,	notbiosboot, /mnt/boot-sav/sda6.
sda7	: sda,	not-sepboot,	no-grubenv	nogrub,	no-docgrub,	no-update-grub,	32,	no-boot,	no-os,	is-maybe-EFI,	part-has-no-fstab,	part-has-no-fstab,	no-nt,	no-winload,	recovery-or-hidden,	bootmgr,	is-winboot,	nopakmgr,	nogrubinstall,	no---usr,	part-has-no-fstab,	not-sep-usr,	standard,	farbios,	notbiosboot, /mnt/boot-sav/sda7.
sda8	: sda,	not-sepboot,	grubenv-ok	grub2,	no-docgrub,	update-grub,	64,	with-boot,	is-os,	not--efi--part,	fstab-without-boot,	fstab-without-efi,	no-nt,	no-winload,	no-recov-nor-hid,	no-bmgr,	notwinboot,	pacman,	grub-install,	with--usr,	fstab-without-usr,	not-sep-usr,	standard,	farbios,	notbiosboot, /mnt/boot-sav/sda8.
sda	: GPT,	no-BIOS_boot,	has-correctEFI, 	not-usb,	not-mmc, has-os,	2048 sectors * 512 bytes
=================== parted -lm:
BYT;
/dev/sda:1000GB:scsi:512:4096:gpt:ATA WDC WD10JPCX-24U:;
1:1049kB:274MB:273MB:fat32:EFI system partition:boot, esp;
2:274MB:290MB:16.8MB::Microsoft reserved partition:msftres;
3:290MB:524GB:523GB:ntfs:Basic data partition:msftdata;
8:524GB:952GB:429GB:ext4::;
4:952GB:979GB:26.8GB:ntfs:Basic data partition:msftdata;
5:979GB:980GB:1049MB:ntfs:Basic data partition:hidden, diag;
6:980GB:999GB:18.8GB:ntfs:Basic data partition:diag;
7:999GB:1000GB:1049MB:fat32:Basic data partition:hidden;
BYT;
/dev/sdb:15.4GB:scsi:512:512:msdos:SanDisk Ultra Fit:;
1:1049kB:15.4GB:15.4GB:fat32::boot, lba;
=================== lsblk:
KNAME TYPE FSTYPE     SIZE LABEL
loop0 loop squashfs   1.8G
loop1 loop squashfs  87.9M
loop2 loop squashfs 140.9M
loop3 loop squashfs   2.3M
loop4 loop squashfs    13M
loop5 loop squashfs  14.5M
loop6 loop squashfs   3.7M
loop7 loop squashfs  42.1M
sda   disk          931.5G
sda1  part vfat       260M SYSTEM_DRV
sda2  part             16M
sda3  part ntfs     487.3G Windows
sda4  part ntfs        25G LENOVO
sda5  part ntfs      1000M WINRE_DRV
sda6  part ntfs      17.5G LENOVO_PART
sda7  part vfat      1000M LRS_ESP
sda8  part ext4     399.4G
sdb   disk           14.3G
sdb1  part vfat      14.3G UBUNTU 18_1
sr0   rom            1024M
KNAME ROTA RO RM STATE   MOUNTPOINT
loop0    1  1  0         /rofs
loop1    1  1  0         /snap/core/5662
loop2    1  1  0         /snap/gnome-3-26-1604/70
loop3    1  1  0         /snap/gnome-calculator/238
loop4    1  1  0         /snap/gnome-characters/124
loop5    1  1  0         /snap/gnome-logs/45
loop6    1  1  0         /snap/gnome-system-monitor/57
loop7    1  1  0         /snap/gtk-common-themes/701
sda      1  0  0 running
sda1     1  0  0         /mnt/boot-sav/sda1
sda2     1  0  0
sda3     1  0  0         /mnt/boot-sav/sda3
sda4     1  0  0         /mnt/boot-sav/sda4
sda5     1  0  0         /mnt/boot-sav/sda5
sda6     1  0  0         /mnt/boot-sav/sda6
sda7     1  0  0         /mnt/boot-sav/sda7
sda8     1  0  0         /mnt/boot-sav/sda8
sdb      1  0  1 running
sdb1     1  0  1         /cdrom
sr0      1  0  1 running
=================== mount:
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=3989704k,nr_inodes=997426,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=802484k,mode=755)
/dev/sdb1 on /cdrom type vfat (ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/loop0 on /rofs type squashfs (ro,noatime)
/cow on / type overlay (rw,relatime,lowerdir=//filesystem.squashfs,upperdir=/cow/upper,workdir=/cow/work)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=16638)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime)
tmpfs on /run/user/999 type tmpfs (rw,nosuid,nodev,relatime,size=802480k,mode=700,uid=999,gid=999)
gvfsd-fuse on /run/user/999/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=999,group_id=999)
/var/lib/snapd/snaps/core_5662.snap on /snap/core/5662 type squashfs (ro,nodev,relatime,x-gdu.hide)
/var/lib/snapd/snaps/gnome-3-26-1604_70.snap on /snap/gnome-3-26-1604/70 type squashfs (ro,nodev,relatime,x-gdu.hide)
/var/lib/snapd/snaps/gnome-calculator_238.snap on /snap/gnome-calculator/238 type squashfs (ro,nodev,relatime,x-gdu.hide)
/var/lib/snapd/snaps/gnome-characters_124.snap on /snap/gnome-characters/124 type squashfs (ro,nodev,relatime,x-gdu.hide)
/var/lib/snapd/snaps/gnome-logs_45.snap on /snap/gnome-logs/45 type squashfs (ro,nodev,relatime,x-gdu.hide)
/var/lib/snapd/snaps/gnome-system-monitor_57.snap on /snap/gnome-system-monitor/57 type squashfs (ro,nodev,relatime,x-gdu.hide)
/var/lib/snapd/snaps/gtk-common-themes_701.snap on /snap/gtk-common-themes/701 type squashfs (ro,nodev,relatime,x-gdu.hide)
/dev/sda1 on /mnt/boot-sav/sda1 type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/sda3 on /mnt/boot-sav/sda3 type fuseblk (ro,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sda4 on /mnt/boot-sav/sda4 type fuseblk (ro,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sda5 on /mnt/boot-sav/sda5 type fuseblk (ro,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sda6 on /mnt/boot-sav/sda6 type fuseblk (ro,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sda7 on /mnt/boot-sav/sda7 type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/sda8 on /mnt/boot-sav/sda8 type ext4 (rw,relatime)
=================== ls:
/sys/block/sda (filtered):  alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range hidden holders inflight integrity power queue range removable ro sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 size slaves stat subsystem trace uevent
/sys/block/sdb (filtered):  alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range hidden holders inflight integrity power queue range removable ro sdb1 size slaves stat subsystem trace uevent
/sys/block/sr0 (filtered):  alignment_offset bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range hidden holders inflight integrity power queue range removable ro size slaves stat subsystem trace uevent
/dev (filtered):  autofs block bsg btrfs-control bus cdrom cdrw char console core cpu cpu_dma_latency cuse disk dri drm_dp_aux0 drm_dp_aux1 dvd dvdrw ecryptfs fb0 fd full fuse hpet hugepages hwrng i2c-0 i2c-1 i2c-10 i2c-11 i2c-12 i2c-2 i2c-3 i2c-4 i2c-5 i2c-6 i2c-7 i2c-8 i2c-9 initctl input kmsg kvm lightnvm log mapper mcelog media0 mei0 mem memory_bandwidth mqueue net network_latency network_throughput null port ppp psaux ptmx pts random rfkill rtc rtc0 sda sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sdb sdb1 sg0 sg1 sg2 shm snapshot snd sr0 stderr stdin stdout tpm0 tpmrm0 uhid uinput urandom userio v4l vfio vga_arbiter vhci vhost-net vhost-vsock video0 video1 zero
ls /dev/mapper:  control
=================== hexdump -n512 -C /dev/sda1
00000000  eb 58 90 4d 53 44 4f 53  35 2e 30 00 02 08 fe 1b  |.X.MSDOS5.0.....|
00000010  02 00 00 00 00 f8 00 00  3f 00 ff 00 00 08 00 00  |........?.......|
00000020  00 20 08 00 01 02 00 00  00 00 00 00 02 00 00 00  |. ..............|
00000030  01 00 06 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000040  80 01 29 59 d5 a9 22 4e  4f 20 4e 41 4d 45 20 20  |..)Y.."NO NAME  |
00000050  20 20 46 41 54 33 32 20  20 20 33 c9 8e d1 bc f4  |  FAT32   3.....|
00000060  7b 8e c1 8e d9 bd 00 7c  88 56 40 88 4e 02 8a 56  |{......|.V@.N..V|
00000070  40 b4 41 bb aa 55 cd 13  72 10 81 fb 55 aa 75 0a  |@.A..U..r...U.u.|
00000080  f6 c1 01 74 05 fe 46 02  eb 2d 8a 56 40 b4 08 cd  |...t..F..-.V@...|
00000090  13 73 05 b9 ff ff 8a f1  66 0f b6 c6 40 66 0f b6  |.s......f...@f..|
000000a0  d1 80 e2 3f f7 e2 86 cd  c0 ed 06 41 66 0f b7 c9  |...?.......Af...|
000000b0  66 f7 e1 66 89 46 f8 83  7e 16 00 75 39 83 7e 2a  |f..f.F..~..u9.~*|
000000c0  00 77 33 66 8b 46 1c 66  83 c0 0c bb 00 80 b9 01  |.w3f.F.f........|
000000d0  00 e8 2c 00 e9 a8 03 a1  f8 7d 80 c4 7c 8b f0 ac  |..,......}..|...|
000000e0  84 c0 74 17 3c ff 74 09  b4 0e bb 07 00 cd 10 eb  |..t.<.t.........|
000000f0  ee a1 fa 7d eb e4 a1 7d  80 eb df 98 cd 16 cd 19  |...}...}........|
00000100  66 60 80 7e 02 00 0f 84  20 00 66 6a 00 66 50 06  |f`.~.... .fj.fP.|
00000110  53 66 68 10 00 01 00 b4  42 8a 56 40 8b f4 cd 13  |Sfh.....B.V@....|
00000120  66 58 66 58 66 58 66 58  eb 33 66 3b 46 f8 72 03  |fXfXfXfX.3f;F.r.|
00000130  f9 eb 2a 66 33 d2 66 0f  b7 4e 18 66 f7 f1 fe c2  |..*f3.f..N.f....|
00000140  8a ca 66 8b d0 66 c1 ea  10 f7 76 1a 86 d6 8a 56  |..f..f....v....V|
00000150  40 8a e8 c0 e4 06 0a cc  b8 01 02 cd 13 66 61 0f  |@............fa.|
00000160  82 74 ff 81 c3 00 02 66  40 49 75 94 c3 42 4f 4f  |.t.....f@Iu..BOO|
00000170  54 4d 47 52 20 20 20 20  00 00 00 00 00 00 00 00  |TMGR    ........|
00000180  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001a0  00 00 00 00 00 00 00 00  00 00 00 00 0d 0a 45 72  |..............Er|
000001b0  72 6f 2f 64 69 73 63 6f  ff 0d 0a 50 72 65 73 73  |ro/disco...Press|
000001c0  69 6f 6e 65 20 74 65 63  6c 61 20 70 2f 72 65 69  |ione tecla p/rei|
000001d0  6e 69 63 69 61 72 0d 0a  00 00 00 00 00 00 00 00  |niciar..........|
000001e0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001f0  00 00 00 00 00 00 00 00  ac 01 b9 01 00 00 55 aa  |..............U.|
00000200
=================== hexdump -n512 -C /dev/sda3
00000000  eb 52 90 4e 54 46 53 20  20 20 20 00 02 08 00 00  |.R.NTFS    .....|
00000010  00 00 00 00 00 f8 00 00  3f 00 ff 00 00 a8 08 00  |........?.......|
00000020  00 00 00 00 80 00 80 00  ff df ea 3c 00 00 00 00  |...........<....|
00000030  00 00 0c 00 00 00 00 00  02 00 00 00 00 00 00 00  |................|
00000040  f6 00 00 00 01 00 00 00  b1 c7 ab 86 dd ab 86 4a  |...............J|
00000050  00 00 00 00 fa 33 c0 8e  d0 bc 00 7c fb 68 c0 07  |.....3.....|.h..|
00000060  1f 1e 68 66 00 cb 88 16  0e 00 66 81 3e 03 00 4e  |..hf......f.>..N|
00000070  54 46 53 75 15 b4 41 bb  aa 55 cd 13 72 0c 81 fb  |TFSu..A..U..r...|
00000080  55 aa 75 06 f7 c1 01 00  75 03 e9 dd 00 1e 83 ec  |U.u.....u.......|
00000090  18 68 1a 00 b4 48 8a 16  0e 00 8b f4 16 1f cd 13  |.h...H..........|
000000a0  9f 83 c4 18 9e 58 1f 72  e1 3b 06 0b 00 75 db a3  |.....X.r.;...u..|
000000b0  0f 00 c1 2e 0f 00 04 1e  5a 33 db b9 00 20 2b c8  |........Z3... +.|
000000c0  66 ff 06 11 00 03 16 0f  00 8e c2 ff 06 16 00 e8  |f...............|
000000d0  4b 00 2b c8 77 ef b8 00  bb cd 1a 66 23 c0 75 2d  |K.+.w......f#.u-|
000000e0  66 81 fb 54 43 50 41 75  24 81 f9 02 01 72 1e 16  |f..TCPAu$....r..|
000000f0  68 07 bb 16 68 52 11 16  68 09 00 66 53 66 53 66  |h...hR..h..fSfSf|
00000100  55 16 16 16 68 b8 01 66  61 0e 07 cd 1a 33 c0 bf  |U...h..fa....3..|
00000110  0a 13 b9 f6 0c fc f3 aa  e9 fe 01 90 90 66 60 1e  |.............f`.|
00000120  06 66 a1 11 00 66 03 06  1c 00 1e 66 68 00 00 00  |.f...f.....fh...|
00000130  00 66 50 06 53 68 01 00  68 10 00 b4 42 8a 16 0e  |.fP.Sh..h...B...|
00000140  00 16 1f 8b f4 cd 13 66  59 5b 5a 66 59 66 59 1f  |.......fY[ZfYfY.|
00000150  0f 82 16 00 66 ff 06 11  00 03 16 0f 00 8e c2 ff  |....f...........|
00000160  0e 16 00 75 bc 07 1f 66  61 c3 a1 f6 01 e8 09 00  |...u...fa.......|
00000170  a1 fa 01 e8 03 00 f4 eb  fd 8b f0 ac 3c 00 74 09  |............<.t.|
00000180  b4 0e bb 07 00 cd 10 eb  f2 c3 0d 0a 45 72 72 6f  |............Erro|
00000190  20 64 65 20 64 69 73 63  6f 00 0d 0a 42 4f 4f 54  | de disco...BOOT|
000001a0  4d 47 52 20 63 6f 6d 70  61 63 74 61 64 6f 00 0d  |MGR compactado..|
000001b0  0a 50 72 65 73 73 69 6f  6e 65 20 43 74 72 6c 2b  |.Pressione Ctrl+|
000001c0  41 6c 74 2b 44 65 6c 20  70 61 72 61 20 72 65 69  |Alt+Del para rei|
000001d0  6e 69 63 69 61 72 0d 0a  00 73 74 61 72 74 0d 0a  |niciar...start..|
000001f0  00 00 00 00 00 00 8a 01  9a 01 af 01 00 00 55 aa  |..............U.|
00000200
=================== hexdump -n512 -C /dev/sda4
00000010  00 00 00 00 00 f8 00 00  3f 00 ff 00 00 c8 e0 6e  |........?......n|
00000020  00 00 00 00 80 00 80 00  ff ff 1f 03 00 00 00 00  |................|
00000040  f6 00 00 00 01 00 00 00  5a aa 8b e4 cf 8b e4 9c  |........Z.......|
00000180  b4 0e bb 07 00 cd 10 eb  f2 c3 0d 0a 41 20 64 69  |............A di|
00000190  73 6b 20 72 65 61 64 20  65 72 72 6f 72 20 6f 63  |sk read error oc|
000001a0  63 75 72 72 65 64 00 0d  0a 42 4f 4f 54 4d 47 52  |curred...BOOTMGR|
000001b0  20 69 73 20 63 6f 6d 70  72 65 73 73 65 64 00 0d  | is compressed..|
000001c0  0a 50 72 65 73 73 20 43  74 72 6c 2b 41 6c 74 2b  |.Press Ctrl+Alt+|
000001d0  44 65 6c 20 74 6f 20 72  65 73 74 61 72 74 0d 0a  |Del to restart..|
000001f0  00 00 00 00 00 00 8a 01  a7 01 bf 01 00 00 55 aa  |..............U.|
00000200
=================== hexdump -n512 -C /dev/sda5
00000010  00 00 00 00 00 f8 00 00  3f 00 ff 00 00 c8 00 72  |........?......r|
00000020  00 00 00 00 80 00 80 00  ff 3f 1f 00 00 00 00 00  |.........?......|
00000030  55 4d 01 00 00 00 00 00  02 00 00 00 00 00 00 00  |UM..............|
00000040  f6 00 00 00 01 00 00 00  4a 59 a9 92 6a a9 92 0c  |........JY..j...|
00000200
=================== hexdump -n512 -C /dev/sda6
00000010  00 00 00 00 00 f8 00 00  3f 00 ff 00 00 08 20 72  |........?..... r|
00000020  00 00 00 00 80 00 80 00  ff 1f 31 02 00 00 00 00  |..........1.....|
00000040  f6 00 00 00 01 00 00 00  9c 2e 2a b6 3c 2a b6 04  |..........*.<*..|
00000200
efi files in sda7/efi: /Microsoft/Boot/memtest.efi /Microsoft/Boot/LrsBootmgr.efi /Boot/bootx64.efi
=================== hexdump -n512 -C /dev/sda7
00000000  eb 58 90 4d 53 44 4f 53  35 2e 30 00 02 08 6e 10  |.X.MSDOS5.0...n.|
00000010  02 00 00 00 00 f8 00 00  3f 00 ff 00 00 28 51 74  |........?....(Qt|
00000020  00 40 1f 00 c9 07 00 00  00 00 00 00 02 00 00 00  |.@..............|
00000040  80 01 29 c0 cb 2b e6 4e  4f 20 4e 41 4d 45 20 20  |..)..+.NO NAME  |
000001a0  00 00 00 00 00 00 00 00  00 00 00 00 0d 0a 44 69  |..............Di|
000001b0  73 6b 20 65 72 72 6f 72  ff 0d 0a 50 72 65 73 73  |sk error...Press|
000001c0  20 61 6e 79 20 6b 65 79  20 74 6f 20 72 65 73 74  | any key to rest|
000001d0  61 72 74 0d 0a 00 00 00  00 00 00 00 00 00 00 00  |art.............|
00000200
=================== df -Th:
Filesystem     Type      Size  Used Avail Use% Mounted on
udev           devtmpfs  3.9G     0  3.9G   0% /dev
tmpfs          tmpfs     784M  1.7M  783M   1% /run
/dev/sdb1      vfat       15G  1.9G   13G  14% /cdrom
/dev/loop0     squashfs  1.8G  1.8G     0 100% /rofs
/cow           overlay   3.9G  374M  3.5G  10% /
tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
tmpfs          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /tmp
tmpfs          tmpfs     784M   36K  784M   1% /run/user/999
/dev/loop1     squashfs   88M   88M     0 100% /snap/core/5662
/dev/loop2     squashfs  141M  141M     0 100% /snap/gnome-3-26-1604/70
/dev/loop3     squashfs  2.3M  2.3M     0 100% /snap/gnome-calculator/238
/dev/loop4     squashfs   13M   13M     0 100% /snap/gnome-characters/124
/dev/loop5     squashfs   15M   15M     0 100% /snap/gnome-logs/45
/dev/loop6     squashfs  3.8M  3.8M     0 100% /snap/gnome-system-monitor/57
/dev/loop7     squashfs   43M   43M     0 100% /snap/gtk-common-themes/701
/dev/sda1      vfat      256M   28M  229M  11% /mnt/boot-sav/sda1
/dev/sda3      fuseblk   488G  210G  278G  44% /mnt/boot-sav/sda3
/dev/sda4      fuseblk    25G  2.3G   23G  10% /mnt/boot-sav/sda4
/dev/sda5      fuseblk  1000M  479M  522M  48% /mnt/boot-sav/sda5
/dev/sda6      fuseblk    18G   13G  4.6G  75% /mnt/boot-sav/sda6
/dev/sda7      vfat      996M  535M  462M  54% /mnt/boot-sav/sda7
/dev/sda8      ext4      393G  5.3G  367G   2% /mnt/boot-sav/sda8
=================== fdisk -l:
Disk /dev/loop0: 1.8 GiB, 1905549312 bytes, 3721776 sectors
Disk /dev/loop1: 87.9 MiB, 92123136 bytes, 179928 sectors
Disk /dev/loop2: 140.9 MiB, 147722240 bytes, 288520 sectors
Disk /dev/loop3: 2.3 MiB, 2355200 bytes, 4600 sectors
Disk /dev/loop4: 13 MiB, 13619200 bytes, 26600 sectors
Disk /dev/loop5: 14.5 MiB, 15208448 bytes, 29704 sectors
Disk /dev/loop6: 3.7 MiB, 3878912 bytes, 7576 sectors
Disk /dev/loop7: 42.1 MiB, 44183552 bytes, 86296 sectors
Disklabel type: gpt
Disk identifier: 78658C49-6B21-4F92-AFC8-9EFEE5873F8C
Device          Start        End    Sectors   Size Type
/dev/sda1        2048     534527     532480   260M EFI System
/dev/sda2      534528     567295      32768    16M Microsoft reserved
/dev/sda3      567296 1022593023 1022025728 487.3G Microsoft basic data
/dev/sda4  1860225024 1912653823   52428800    25G Microsoft basic data
/dev/sda5  1912653824 1914701823    2048000  1000M Windows recovery environment
/dev/sda6  1914701824 1951475711   36773888  17.5G Windows recovery environment
/dev/sda7  1951475712 1953523711    2048000  1000M Lenovo boot partition
/dev/sda8  1022593024 1860225023  837632000 399.4G Linux filesystem
Partition table entries are not in disk order.
Disklabel type: dos
Disk identifier: 0x00918134
Device     Boot Start      End  Sectors  Size Id Type
/dev/sdb1  *     2048 30031871 30029824 14.3G  c W95 FAT32 (LBA)
=================== Recommended repair
The default repair of the Boot-Repair utility will purge (in order to fix packages) and reinstall the grub-efi-amd64-signed of sda8, using the following options:        sda1/boot/efi,
Additional repair will be performed: unhide-bootmenu-10s   fix-windows-boot use-standard-efi-file
/boot/efi added in sda8/fstab
Quantity of real Windows: 1
Created sda8/boot/efi
Mount sda1 on /mnt/boot-sav/sda8/boot/efi
efi files in sda1/efi: /Microsoft/Boot/memtest.efi /Microsoft/Boot/bootmgr.efi /Microsoft/Boot/bootmgfw.efi /Manjaro/grubx64.efi /Boot/bootx64.efi
No sda8/boot/efi/efi/ ubuntu/mint folder
chroot /mnt/boot-sav/sda8 pacman -Sy --noconfirm pacman
error: failed retrieving file 'core.db' from manjaro.cu.be : The requested URL returned error: 404
error: failed retrieving file 'extra.db' from manjaro.cu.be : The requested URL returned error: 404
error: failed retrieving file 'community.db' from manjaro.cu.be : The requested URL returned error: 404
error: failed retrieving file 'multilib.db' from manjaro.cu.be : The requested URL returned error: 404
error: failed retrieving file 'archlinux-keyring-20181128-1-any.pkg.tar.xz' from manjaro.cu.be : The requested URL returned error: 404
error: failed retrieving file 'manjaro-keyring-20180607-1-any.pkg.tar.xz' from manjaro.cu.be : The requested URL returned error: 404
error: failed retrieving file 'manjaro-system-20180828-2-any.pkg.tar.xz' from manjaro.cu.be : The requested URL returned error: 404
warning: lock file missing /var/lib/pacman/db.lck
chroot /mnt/boot-sav/sda8 pacman-db-upgrade
Purge the GRUB of sda8
error: target not found: grub-efi-amd64-signed
grub-efi-amd64-signed NOT available (pacman -Syw --noconfirm  problem)
grub-efi NOT available (pacman -Syw --noconfirm  problem)
error: target not found: grub2-efi
grub2-efi NOT available (pacman -Syw --noconfirm  problem)
=================== grub-efi-amd64-signed purge cancelled
Please enable a repository containing the [grub-efi-amd64-signed] packages in the software sources of Manjaro Linux (sda8). Then try again.
umount: /mnt/boot-sav/sda8/dev: target is busy.
=================== Suggested repair
=================== Final advice in case of suggested repair
Please do not forget to make your BIOS boot on sda1/efi/.../grub*.efi file!
If your computer reboots directly into Windows, try to change the boot order in your BIOS.
If your BIOS does not allow to change the boot order, change the default boot entry of the Windows bootloader.
For example you can boot into Windows, then type the following command in an admin command prompt:
bcdedit /set {bootmgr} path \EFI\...\grub*.efi
=================== User settings
The settings chosen by the user will not act on the boot.
My suspicion involves:
  1. Manjaro 17 and 18 share some compatibility issues that prevent me from (i) updating repos (ii) upgrading from 17 to 18 (iii) updating GRUB
  2. My GRUB installation is somewhat corrupted or does not exist. I do not know how to overcome this.
    Thus, it seems that the problem is circular.
Again, I am just a beginner and many terms may be wrong, but if necessary I can provide further clarification.
The SYSTEM
LENOVO ideapad
intel Core i5 6200
Windows 10 Version 10.0.17134
BIOS Version LENOVO D5CN47WW (UEFI Legacy mode enabled/Secure boot disabled)
Manjaro (gnome) versions used:
17.1.1 (installs, but doesn’t update)
18 (does not install, enters grub_rescue>)
Ubuntu (Live) version used: 18.10
Please help, so I can fully join the Manjaro community!
Many thanks!
L_flldr
with usb install , can you return
inxi -Fxxxz
fdisk -l
Can it boot Manjaro?
yes, it can.
Then provide at manjaro terminal (print)
efibootmgr -v
sudo parted -l
sudo blkid
findmnt -s
If error, print error message and continue to next command.
here it goes
[lorenzo@lorenzomjro ~]$ inxi -Fxxxz
Resuming in non X mode: xrandr not found. For package install advice run: inxi --recommends
System:    Host: lorenzomjro Kernel: 4.14.11-3-MANJARO x86_64
           bits: 64 gcc: 7.2.1
           Desktop: Gnome 3.26.2 (Gtk 3.22.26) info: gnome-shell dm: gdm
           Distro: Manjaro Linux
Machine:   Device: laptop System: LENOVO product: 80RS v: Lenovo ideapad 300-15ISK serial: N/A
           Mobo: LENOVO model: Paris 5A8 v: SDK0J40679 WIN serial: N/A
           UEFI [Legacy]: LENOVO v: D5CN47WW date: 08/26/2016
           Chassis: type: 10 v: Lenovo ideapad 300-15ISK serial: N/A
Battery    BAT0: charge: 32.9 Wh 97.2% condition: 33.8/39.7 Wh (85%)
           volts: 16.5/14.4
           model: SANYO L15S4E01 Li-ion serial: <filter>status: Charging cycles: 0
CPU:       Dual core Intel Core i5-6200U (-MT-MCP-)
           arch: Skylake rev.3 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9602
           clock speeds: min/max: 400/2800 MHz 1: 2400 MHz 2: 2400 MHz
           3: 2400 MHz 4: 2400 MHz
Graphics:  Card-1: Intel HD Graphics 520 bus-ID: 00:02.0 chip-ID: 8086:1916
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / R7 M520]
           bus-ID: 03:00.0 chip-ID: 1002:6660
           Display Server: N/A drivers: i915,radeon tty size: 80x24
Audio:     Card Intel Sunrise Point-LP HD Audio
           driver: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d70
           Sound: Advanced Linux Sound Architecture v: k4.14.11-3-MANJARO
Network:   Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8168 v: 8.044.02-NAPI port: 4000
           bus-ID: 01:00.0 chip-ID: 10ec:8168
           IF: enp1s0 state: down mac: <filter>
           Card-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
           driver: ath10k_pci bus-ID: 02:00.0 chip-ID: 168c:0042
           IF: wlp2s0 state: down mac: <filter>
           Card-3: Qualcomm Atheros usb-ID: 001-005 chip-ID: 0cf3:e360
           IF: null-if-id state: N/A speed: N/A duplex: N/A mac: N/A
Drives:    HDD Total Size: 1016.4GB (0.6% used)
           ID-1: /dev/sda model: WDC_WD10JPCX size: 1000.2GB serial: <filter>
           ID-2: USB /dev/sdb model: USB_DISK size: 16.2GB serial: <filter>
Partition: ID-1: / size: 393G used: 5.4G (2%) fs: ext4 dev: /dev/sda8
Sensors:   System Temperatures: cpu: 39.0C mobo: N/A gpu: 43.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 176 Uptime: 1 min Memory: 716.5/7841.1MB
           Init: systemd v: 236 Gcc sys: N/A
           Client: Shell (bash 4.4.121 running in gnome-terminal-) inxi: 2.3.53
[lorenzo@lorenzomjro ~]$ sudo fdisk -l
    Disk /dev/sda: 931,5 GiB, 1000204886016 bytes, 1953525168 sectors
Disklabel type: gpt
/dev/sda3      567296 1022593023 1022025728 487,3G Microsoft basic data
/dev/sda6  1914701824 1951475711   36773888  17,5G Windows recovery environment
/dev/sda8  1022593024 1860225023  837632000 399,4G Linux filesystem
Disk /dev/sdb: 15,1 GiB, 16231956480 bytes, 31703040 sectors
Disklabel type: dos
Disk identifier: 0x00053792
/dev/sdb1  *     2048 31703039 31700992 15,1G  c W95 FAT32 (LBA)
Returns:
[lorenzo@lorenzomjro ~]$ efibootmgr -v
EFI variables are not supported on this system.
[lorenzo@lorenzomjro ~]$ sudo parted -l
[sudo] password for lorenzo:
Model: ATA WDC WD10JPCX-24U (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name                          Flags
 1      1049kB  274MB   273MB   fat32        EFI system partition          boot, esp
 2      274MB   290MB   16,8MB               Microsoft reserved partition  msftres
 3      290MB   524GB   523GB   ntfs         Basic data partition          msftdata
 8      524GB   952GB   429GB   ext4
 4      952GB   979GB   26,8GB  ntfs         Basic data partition          msftdata
 5      979GB   980GB   1049MB  ntfs         Basic data partition          hidden, diag
 6      980GB   999GB   18,8GB  ntfs         Basic data partition          diag
 7      999GB   1000GB  1049MB  fat32        Basic data partition          hidden
Model: SMI USB DISK (scsi)
Disk /dev/sdb: 16,2GB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 1      1049kB  16,2GB  16,2GB  primary  fat32        boot, lba
[lorenzo@lorenzomjro ~]$ sudo blkid
/dev/sdb1: LABEL="ISOIMAGE" UUID="D85B-B9C2" TYPE="vfat" PARTUUID="00053792-01"
[lorenzo@lorenzomjro ~]$ findmnt -s
TARGET    SOURCE                                    FSTYPE OPTIONS
/         UUID=195246a9-3b82-4f07-a4c1-2fddcbb6602c ext4   defaults,noa
/boot/efi UUID=22A9-D559
you should verify all option in bios , you have not boot in EFI for Manjaro , but in Bios
 date: 08/26/2016
Disk /dev/sda: 931,5 GiBbytes  Disklabel type: gpt
Disk /dev/sdb: 15,1 GiB Disklabel type: dos ( USB stick )
how did you created the USB img ?
you should have 2 partitions , 2nd partition is for boot EFI iso manjaro
do not mix GPT and DOS disks
Thanks, stephane!
USB image was created using Rufus for windows.
This usb stick is running SGD2, which in turn identifies the OSs in the system and allows me to acces my “old” manjaro installation.
The sda (913GB) is my internal HD.
The sdb (15GB) is the USB sitck.
The system runs UEFI on legacy mode which, as I understand, would make it compatible with BIOS-derived software and OS.
How can I, then, boot in EFI for Manjaro?
UPDATE
As stephane pointed out, changing boot order from “EFI first” to “Legacy first” worked fine, and now GRUB loads. Thanks again!
However, no windows option other than the Windows Recovery environment loads.
How can I add the Windows instance on GRUB?
I suggest you start from the beginning, when it all started! :joy:
You are very near having Manjaro working…
My concern is with your suspicions
  1. You have problem updating Manjaro, means you have booted to Manjaro installation on disk. Am I wrong?
  2. You seem to have Manjaro $esp files in place (bootloader), though it seems you have no (proper) UEFI entry for Manjaro, if I understood correctly (you have a Linpus entry…)
Your system is normaly a UEFI system with Windows and Manjaro installed in UEFI mode.
In order to have Windows entry included in Grub menu, Windows and Manjaro have to be in the same mode (now UEFI). So you need to set your BIOS to UEFI priority (or only)
I suggest you follow the below tutorial to boot and repair your bootloader.
Use the Simple method first and the additional commands for UEFI.
If you don’t succeed, post your experience.
Morning.
To repeat what petsam says (in a different way),
A bios-legacy grub cannot detect/boot a uefi windows.
Your Manjaro is now bios-legacy though you have a $esp (correctly) specified in fstab.
I suspect (but not conclusively) that SuperGrubDisk had turned (that pure magic) your system from uefi to a bios-legacy (and that’s why I ask you to print out ‘efibootmgr -v’ expecting it to have errors).
I concur with petsam you use the link to try to fix it to uefi with the following emphasis.
o You cannot boot up Manjaro the way you’re doing now or the “SuperGrub” way
as that will boot up in bios-legacy mode. You must boot in UEFI mode and for that you must use livecd and boot it up in uefi mode.
o Be sure to do the 2 [Additional UEFI commands].
sudo cp /boot/grub/x86_64-efi/core.efi /boot/efi/EFI/boot/bootx64.efi
sudo efibootmgr -c -d /dev/sda -p 1 -L "manjaro" -l "\EFI\Manjaro\grubx64.efi"
o It is possible that having done that, you may still face some problems as your system is Lenovo and may be tied up with Microsoft in monopolizing your system.
In that case, follow up with the Lenovo link in the [Difficult UEFI setups] section further down in the link.
Good luck.
Thanks gohlip and petsam for the answers!
As I understand, I need to revert the Manjaro installation to an UEFI boot.
To do that, I’ll boot Manjaro in using a liveCD, follow the instructions on this link and then add those two lines of code that gohlip suggested.
If problems arise, I’ll follow the Lenovo path.
I’ll post the follow-up to this thread as soon as possible.
Thanks.
Hello all,
Fortunately, I tried new installation and… it worked! Some friends helped along, and it’s fine.
I thank everybody for the time, it was useful to get experience with the distro.
I’ll keep posting doubts here, should they occur.
Thanks a lot!
