When I start up my desktop PC, I see GRUB. It disappears for a moment, but then reappears for about two seconds. The computer then starts up normally. How can I prevent it from appearing a second time? Thanks in advance!
In case you mean the company logo of your computer being displayed twice: That’s totally normal for grub.
Did the second grub appear after you run the recommended install-grub after one of the more recent updates? If so, most likely you installed it twice.
What’s the output of:
inxi -zv8
This shouldn’t matter.
This. If not, OP has to explain what does he mean with “grub appears twice”. The menu? Some logo?
Another normal possibility is that itdetects the video or loads module and switches the resolution which will blank the screen for a moment.
Here is the output:
inxi -zv8
Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=44b12396-82ff-4fed-81e7-ff9bcf980f7f rw quiet splash apparmor=1
security=apparmor resume=UUID=fb6c42d8-951f-42b4-8107-4433db6c6197
udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Intel product: NUC7i3BNH v: J31191-313
serial: <superuser required> Chassis: type: 3 v: 2
Mobo: Intel model: NUC7i3BNB v: J22859-313 serial: <superuser required>
uuid: <superuser required> UEFI: Intel v: BNKBL357.86A.0062.2018.0222.1644
date: 02/22/2018
System RAM: total: 16 GiB available: 15.51 GiB used: 1.87 GiB (12.1%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: spec: 2400 MT/s actual: 2133 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Crucial part-no: CT16G4SFD824A.C16FE serial: <filter>
Device-2: ChannelB-DIMM0 type: no module installed
Info: model: Intel Core i3-7100U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 400/2400 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 19204
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Device-1: Intel HD Graphics 620 driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: DP-1 empty: DP-2,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.18 compositor: xfwm4 v: 4.20.0
driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: DP-1 model: Medion MD20436 serial: <filter> built: 2015
res: 1920x1080 dpi: 94 gamma: 1.2 chroma: red: x: 0.643 y: 0.341 green:
x: 0.318 y: 0.627 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
modes: 1920x1080, 1920x1080i, 1600x1200, 1680x1050, 1400x1050, 1280x1024,
1440x900, 1280x960, 1360x768, 1152x864, 1280x720, 1024x768, 832x624,
800x600, 720x576, 720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.4
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 15.14 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xprop
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.12.44-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:24fd
class-ID: 0280
IF: wlp58s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:0a2b
class-ID: e001
Local Storage: total: 953.87 GiB used: 528.76 GiB (55.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXP7 temp: 30.9 C
scheme: GPT
ID-1: / raw-size: 944.77 GiB size: 928.87 GiB (98.32%)
used: 528.76 GiB (56.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 44b12396-82ff-4fed-81e7-ff9bcf980f7f
used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: CBB9-853D
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: fb6c42d8-951f-42b4-8107-4433db6c6197
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Trust Wireless Silent Mouse type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 145f:021f class-ID: 0301
Hub-2: 1-4:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-4.2:5 info: Microsoft Wired Keyboard 600 (model 1576)
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 045e:07f8 class-ID: 0300
Device-2: 1-8:4 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 47.0 C pch: 44.5 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1173 libs: 354 tools: pamac pm: flatpak pkgs: 0
1: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
2: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 216
1: cpu: 26.3% command: chrome pid: 1498 mem: 353.3 MiB (2.2%)
2: cpu: 13.9% command: xfce4-terminal pid: 1778 mem: 53.6 MiB (0.3%)
3: cpu: 13.1% command: chrome pid: 1382 mem: 193.4 MiB (1.2%)
4: cpu: 11.4% command: chrome pid: 1337 mem: 346.4 MiB (2.1%)
5: cpu: 8.5% command: zsh pid: 1784 mem: 10.2 MiB (0.0%)
Memory top: 5 of 216
1: mem: 353.3 MiB (2.2%) command: chrome pid: 1498 cpu: 26.3%
2: mem: 346.4 MiB (2.1%) command: chrome pid: 1337 cpu: 11.4%
3: mem: 234.1 MiB (1.4%) command: chrome pid: 1450 cpu: 2.8%
4: mem: 217.9 MiB (1.3%) command: chrome pid: 1451 cpu: 2.5%
5: mem: 205.3 MiB (1.2%) command: chrome pid: 1427 cpu: 1.0%
Processes: 216 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: upowerd,xfce4-power-manager
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: xfce4-terminal
inxi: 3.3.39
By appearing twice, I mean the whole GRUB menu.
Are you able to post a screenshot or photo of each “Grub menu” that you see?
I see something similar, but the second time it seems to be a screenshot of the grub menu. I can’t interact with it using the keyboard. I suspect it is something to do with the lack of a background image setting or logo or something, but I just ignore it.
Can you interact with grub when it appears the second time (e.g. with cursor keys)?
I haven’t experienced this yet myself, but it could just be an echo of the framebuffer while the video mode switches.
It does somehow, I have the same issue. To reinstall grub I used to run sudo grub-install /dev/sdX. Since running install-grub I have the 2 grub menus the OP describes plus another one at shutdown.
For me that would most likely be fixed by running the old command again, never tried, though, since it never bothered me much.
Please note that there are significant differences between the OP’s single gpt drive uefi system and my msdos drive bios system with a second gpt drive for data.
Yes, that was the answer I found for “grub menu at shutdown”, most likely the reason for the second one at boot too.
This happens during the startup messages on my systems as I removed quiet and splash from /etc/default/grub — I prefer to see the messages. I think I get a brief flash of the initial ones on shutdown; will have to look closely next time. (I only typically shut down or reboot following a bundled update).
Maybe @Skoebidoe you could try that, if you don’t mind the messages scrolling up. I’d be interested to see what happens then. Those are in the GRUB_CMDLINE. ![]()
Mod note:-
Thanks for the requested images. They have served their purpose and have now been removed.
If the second one is after the nuc+manjaro logos and moving dots a.k.a. Plymouth, it is just a framebuffer artefact.
Actually even before it is very probably this.
Disabling Plymouth partially as descreibed above (removing splash and quiet from the boot line) might or might not help. But i am curious if this is yet another Plymouth quirk (that thing should be banned by law
no, i can not interact with GRUB the second time
In that case, as mentioned by others above, it is probably just a framebuffer artefact. In which case it is not harmful.
Thank you for the screenshots; they can now be removed.
The second “menu” is at a higher resolution than the first, which is likely an artefact of the console resolution changing, much as @Teo and @Aragorn have described (above).
This might be annoying to see but otherwise should be harmless.
However, if you find it too visually disturbing, you could try disabling Compatibility Support Mode (CSM) in your BIOS (if enabled), which may help to some degree (but, no guarantees).
