Grub is not working on boot
It didn’t change a thing. And I have indeed GRUB_TIMEOUT_STYLE=menu in the grub file
try tapping shift during boot… if it doesnt work, try tapping esc during boot
Tapping shift worked! It opened a Manjaro themed grub. I will see in the near future if it’s only when I tap shift, and if there are options I can change
Thank you!
(I don’t know how to close the topic)
did you also try with esc ?
post also output from:
cat /etc/default/grub
so that i can compare it to mine…
esc seems to work also. I must say that on one boot, grub appeared for 1 seconds, and it booted without me picking the boot options. I cannot say yet if it will be recurrent.
Output of cat /etc/default/grub:
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3 ibt=off"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
do you have this first line there?:
GRUB_DEFAULT=saved
so that it looks like this:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
Yes, I have the same first line, I miss copied.
ok, try increasing the timeout from 5 to 10 seconds, change this line to look lik this:
GRUB_TIMEOUT=10
save grub, update grub:
sudo update-grub
reboot
It seems to work without esc. I even increased to 15 (I saw the timer being quite low when the grub showed).
Thank you for your help. I won’t reply quickly anymore (end of my day).
so the grub menu now appears normally, without pressing shift or esc?
Yes it does
so the issue is solved then
