Grub error while installing
Hi,
I get an error on Grub while installing. Does anyone have an idea what I can do about it?
I already saw that there is a similar thread from october, but that didn’t help in my case.
I vaguely recall something similar. Something with the efivar fs not mounted. The solution was to mount efivarfs and mount the install partition and the corresponding /boot/efi partition and then chroot to the install system and manually running the
grub-install --target=x86_54-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force
The efivarfs must be mounted before chrooting into the new system for grub installation
Thank you for the quick reply. Sorry if the question is stupid but I have to do that after I got this error?
At the time I faced it this wiki was of great help
https://wiki.archlinux.org/index.php/Unified_Extensible_Firmware_Interface
Even the grub-install fails you still have a complete system.
Open a terminal in the live enviroment
mount -t efivarfs efivarfs /sys/firmware/efi/efivars
mount your root partition on /mnt
sudo mount /dev/sdxY /mnt
mount your efi partition
sudo mount /dev/sdxZ /mnt/boot/efi
chroot into your mount
manjaro-chroot /mnt
In the chrooted environment
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force
I tried what you said. My laptop is just rebooting.
That didn’t work. It said it is already mounted.
Holy cow! I see it in my bios/efi.
But when I boot from it I just get
grub>
Ok, i ran an update-grub in the live environment and was able to get into the emergency console and updated the grub there again and now I can start my Windows from grub, but my Manjaro doesn’t boot and always gets me into the emergency console.
With journalctl -xb I got following error
emergency.service: Failed at step EXEC spawning /bin/plymouth: No such file or directory
Then you have removed plymouth without removing the reference to it in mkinitcpio.conf
Remove it and rebuild your init images
Refer this post for more details.
grub> search -f /boot/intel-ucode.img
Any output? write down what that is, ‘hd0,gptx’ and that is your installed Manjaro partition?
If yes, proceed.
grub> search.file /boot/intel-ucode.img root
grub> ls ($root)/boot/
copy down kernel and initramfs so it may be vmlinuz-4.9-x86_64 and initramfs-4.9-x86_64.img
Proceed with
grub> probe -u $root --set=abc
grub> linux /boot/vmlinuz-4.9-x86_64 root=UUID=$abc rw
grub> initrd /boot/initramfs-4.9-x86_64.img
grub> boot
Change to correct kernel/initramfs that you copied down.
When booted up to installed manjaro, do this first
sudo pacman-mirrors -g
sudo pacman -Syyu
Then check if there is a /boot/efi
by
findmnt /boot/efi
Then do
sudo grub-install
sudo update-grub
If you get error message as before on ‘plymouth’
Amend one line - the linux line above to
grub> linux /boot/vmlinuz-4.9-x86_64 root=UUID=$abc rw 3
Note the ‘3’ added.
If you can boot to prompt, login with password and then
sudo pacman -Syyu
sudo grub-install
sudo update-grub
Then fix your graphics.
Thank you for all the replys.
I was able to make it work with manjaro architect.
It took like forever but it is up and running :grin:
