Grub Error Unknown File System
Hello! I recently installed Windows in some unallocated space on my SSD so I can use Photoshop. Anyway, it somehow broke grub which now throws an unknown file system error and puts me in a grub rescue. I am able to boot into Manjaro if I do the following:
> set root=(hd1,7)
> set prefix=(hd1,7)/boot/grub
> insmod normal
> normal
After this I tried reinstalling grub with update-grub and grub-install /dev/sda. The installation reports that is finishes successfully and Windows was detected through os-prober. However, grub is not fixed. Any ideas?
If it was MBR installation/drive, it should be fixed. I suppose it is UEFI or mixed MBR/UEFI instalaltions.
  • Is your drive partition system GPT ?
  • Is Manjaro installed as UEFI?
  • Is Windows installed as UEFI?
If one of the above answers “Yes” you might find this usefull (study well):
Thanks for the response! It worked! It seems the separate commands for UEFI systems were necessary and that fixed it. Sorry for not specifying that earlier.
