Hi everyone i´m new to linux.
Having installed it previously but never really using it actively.
Now trying to change that, I’ve managed to install manjaro on dual boot with windows 10 sharing the same nvme drive.
My problem is that in the Manjaro GRUB it doesn’t detect windows.
It seems like even thought I’ve installed manjaro on this nvme it doesn’t recognize the other operating system in it
when i run sudo update-grub this what i get
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
sudo fdisk -l ✔ 11s
Disk /dev/nvme0n1: 465,76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 970 EVO Plus 500GB
Disklabel type: gpt
Disk identifier: 45E4E6BB-D0AB-45B5-B815-BEFEBD9F0D3C
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 206847 204800 100M EFI System
/dev/nvme0n1p2 206848 239615 32768 16M Microsoft reserved
/dev/nvme0n1p3 239616 468492779 468253164 223,3G Microsoft basic data
/dev/nvme0n1p4 975710208 976771071 1060864 518M Windows recovery environment
/dev/nvme0n1p5 468492781 724049359 255556579 121,9G EFI System
Partition table entries are not in disk order.
Disk /dev/sda: 465,76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 860
Disklabel type: gpt
Disk identifier: DED9560B-9C8B-415A-A74F-053957BEE476
/dev/sda1 2048 976771071 976769024 465,8G Microsoft basic data
Disk /dev/sdb: 931,51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST1000DM010-2EP1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x535ff402
Device Boot Start End Sectors Size Id Type
/dev/sdb1 2048 1953521663 1953519616 931,5G 7 HPFS/NTFS/exFAT
From what i saw looking in the other related forums here it might be related to the uefi but i didn’t understood it completly
And form my bios it appears that my manjaro installation is not on uefi and windows is on uefi is there any way to fix this or do i need to reinstall manjaro?
Thanks in advance
