Resolv.conf resetting to empty dns
okay I swear I solved this before but I changed some settings around with my dns to get my pi-hole-standalone to work but now everytime I reboot or put in terminal sudo resolvconf -u my only nameserver is 127.0.0.1 and I have to edit resolve.conf and add in some dns’s to get internet to work again any help is appreciated
edit: including some info
  Kernel: 5.8.0-2-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=9ba3defc-19c7-4c89-a71f-0734b217f4d7 rw apparmor=1
  Desktop: Cinnamon 4.6.7 tk: GTK 3.24.22 dm: LightDM 1.30.0
  Distro: Manjaro Linux
  Type: Desktop System: Dell product: OptiPlex 390 v: 01 serial: <filter>
  Chassis: type: 3 serial: <filter>
  Mobo: Dell model: 0M5DCD v: A00 serial: <filter> BIOS: Dell v: A06
  date: 03/27/2012
  Topology: Quad Core model: Intel Core i5-2400 bits: 64 type: MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  L2 cache: 6144 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24753
  Speed: 1596 MHz min/max: 1600/3400 MHz Core speeds (MHz): 1: 1596 2: 1868
  3: 1596 4: 1596
  Type: l1tf
  Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI
  driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:128b
  Display: x11 server: X.Org 1.20.8 driver: nvidia display ID: :0 screens: 1
  Screen-1: 0 s-res: 3600x1093 s-dpi: 96 s-size: 953x289mm (37.5x11.4")
  s-diag: 996mm (39.2")
  Monitor-1: VGA-0 res: 1680x1050 hz: 60 dpi: 90
  size: 474x296mm (18.7x11.7") diag: 559mm (22")
  Monitor-2: DVI-D-0 res: 1920x1080 hz: 60 dpi: 92
  size: 531x299mm (20.9x11.8") diag: 609mm (24")
  OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
  direct render: Yes
  vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1c20
  Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0e0f
  Sound Server: ALSA v: k5.8.0-2-MANJARO
  vendor: Dell driver: r8169 v: kernel port: 2000 bus ID: 04:00.0
  chip ID: 10ec:8168
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8192EU 802.11b/g/n WLAN Adapter type: USB
  driver: rtl8xxxu bus ID: 1-1.4:3 chip ID: 0bda:818b serial: <filter>
  IF: wlp0s26u1u4 state: down mac: <filter>
  Local Storage: total: 2.73 TiB used: 13.28 GiB (0.5%)
  ID-1: /dev/sda vendor: Hitachi model: HUA721010KLA330 size: 931.51 GiB
  block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  serial: <filter> rev: AB0A
  ID-2: /dev/sdb vendor: Western Digital model: WD2003FZEX-00Z4SA0
  size: 1.82 TiB block size: physical: 4096 B logical: 512 B
  speed: <unknown> rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
  ID-1: / raw size: 100.00 GiB size: 97.93 GiB (97.93%)
  used: 9.84 GiB (10.0%) fs: ext4 dev: /dev/sdb1
  ID-2: /home raw size: 1.68 TiB size: 1.66 TiB (98.37%)
  used: 3.44 GiB (0.2%) fs: ext4 dev: /dev/sdb3
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 39 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 50%
  Processes: 190 Uptime: 34m Memory: 7.75 GiB used: 1.94 GiB (25.1%)
  Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1125
  lib: 289 flatpak: 0 Shell: Bash v: 5.0.18 running in: gnome-terminal
  inxi: 3.1.05
Are you using resolvconf or systemd-resolvconf ?
pacman -Qs resolv
local/geoip 1.6.12-2
    Non-DNS IP-to-country resolver C library & utils
local/python-geoip 1.3.2-8
    Python bindings for the GeoIP IP-to-country resolver library
local/python-resolvelib 0.4.0-1
    Resolve abstract dependencies into concrete ones
local/systemd-resolvconf 245.7-2
    systemd resolvconf replacement (for use with systemd-resolved)
OK.
So … you want to set a specific DNS server(s) for always?
Then do the following
First, lets back up your resolvconf
sudo mv /etc/resolv.conf /etc/resolv.conf.bak
Then lets make sure the file is a link to be handled by systemd and such:
sudo ln -sf /run/systemd/resolve/stub-resolv.conf /etc/resolv.conf
Then create the file
/etc/systemd/resolved.conf.d/dns_servers.conf
with content (using your DNS in place of cloudflares)
[Resolve]
DNS=1.1.1.1 1.0.0.1  ## put your own DNS here, separated by spaces
Domains=~.
and then restart, check, etc
Instead … You could of course always just make the file immutable I guess, ex:
sudo chattr +i /etc/resolv.conf
This is confusing:
the resolvconf command from systemd does not have a ‘-u’ option:
   -u, -I, -i, -l, -R, -r, -v, -V, --enable-updates, --disable-updates, --are-updates-enabled
       These switches are not supported and the command will fail if used.
Therefore: The resolvconf command you are using can not be from package systemd-resolvconf
Oo. good catch.
@minty_64 I should have thought to ask this way …
pacman -Qo resolvconf
/usr/bin/resolvconf is owned by openresolv 3.10.0-1
setting chatter messes with my vpn as it changes dns temporarily and the first option didn’t work and had to revert
really odd that package didnt show up when we did pacman -Qs resolv
Especially since these 2 conflict with eachother and should not be able to be installed at the same time:
I had to reinstall so currently I’m using openresolv, the reason stated above is I installed pi-hole-standalone and I forgot how I did it but I got the resolv.conf to stay even after reboot.
With openresolv you probably want to do something like this:
went threw the guide step by step and still need to go into /etc/resolv.conf to add a dns that lets me load a web page
edit: at least I have 127.0.0.1 in the file upon reset though isn’t much constellation.
did a bit of searching and it seems resolve pulls from /etc/resolv.conf.head and appending my nameservers into that file I created puts them in resolve.conf
I’m having the same issue myself. I was trying all this and I wasn’t having much luck because I wasn’t doing something correctly. So, I tried opening the GUI Network Configuration Utility, went to settings, then IPv4 settings tab, then I put in the DNS servers manually there, saved and rebooted the system and I was able to connect again.
yes … network manager has the functionality to set ‘manual’ DNS servers per connection …
But really that isnt what this thread is about …
Understood, I just figured if someone was in a jam it’s a decent temporary fix until it can be figured out via this method.
OK - no floggings this time :wink:
