You can try this,instead of the 1st entry,you can edit the file /etc/default/grub
the GRUB_DEFAULT to always boot a specific entry,like Manjaro Linux for example would be
GRUB_DEFAULT="Manjaro Linux"
That way it gonna always boot that entry.
Thank youâŚwill try that
Already installed grub customizer from source
All is ok for now!
No GUI alternative as far as I know.
A. The standard way is to edit the /etc/default/grub file. https://www.howtogeek.com/196655/how-to-configure-the-grub2-boot-loaders-settings/
Some possibilities:
These wonât change order of entries but the cursor will automatically be placed over a selected entry by default.
B. Create custom entries in /boot/grub/custom.cfg - with this, you can order your boot menu entries the way you want
see this whole thread: Creating a new os-independent grub 2 bootloader - Tutorials - Manjaro Linux Forum
I didnât use the information within the thread to create a os-independent bootloader but as a guide on how to create the various boot entries in my custom.cfg file
changes in your custom.cfg file do not need a sudo update-grub. It is automatically read by the /etc/grub.d/41_custom script , and will appear in the grub menu AFTER the normal entries in /boot/grub/grub.cfg (these are the entries generated by sudo update-grub), which is read by the /etc/grub.d/10_linux script. This is because 41 comes after 10
if you want your custom.cfg file entries to be displayed in boot menu BEFORE the grub.cfg entries, rename /etc/grub.d/41_custom to /etc/grub.d/09_custom (9 comes before 10).
you can use
sudo mv ~/initial/file/location ~/destination/location
Or just use root thunar to rename the file.
Removed by moderator request
How did you deal with these double enteries?
I have the same problem.
Is there a WIKI or Guide how to learn to edit GRUB manually.
Suddenly I also have two WINDOWS enteries on my GRUB after todayâs update.
In case they point to different partitions - thatâs normal.
Can one of the replies here be flagged as a solution so people like me who have this problem can easily solve it without spending half-an-hour reading this long thread?
