I am dual booting manjaro and fedora using grub as my bootloader. I had LUKS encryption on my manjaro partition which I’ve removed today, after which on boot I receive a “cryptodisk/luks-…: no such disk” error, which then kicks me into the grub rescue shell. I’ve purged all mention of the cryptodisk from my configuration files, including mkinitcpio.conf, fstab, crypttab and grub.cfg. I’ve done this on both distros too, so I can’t work out why grub is still trying to mount the encrypted partitions. When I manually boot manjaro, the encrypt and opencrypt hooks still run (despite not being listed in the hooks for my mkinitcpio.conf)…
Here is my grub.cfg from manjaro.
Thanks for the help
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod ext2
search --no-floppy --fs-uuid --set=root eb7ab5ef-5a39-443b-bafd-2105cf5ba628
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_GB
insmod gettext
fi
terminal_input console
terminal_output gfxterm
insmod part_gpt
insmod ext2
insmod gfxmenu
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_24.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_48.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_bold_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_mono_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-18.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b18.pf2
insmod png
set theme=($root)/usr/share/grub/themes/manjaro/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-eb7ab5ef-5a39-443b-bafd-2105cf5ba628' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
linux /boot/vmlinuz-5.15-rt-x86_64 root=UUID=eb7ab5ef-5a39-443b-bafd-2105cf5ba628 rw root=/dev/nvme0n1p2
initrd /boot/intel-ucode.img /boot/initramfs-5.15-rt-x86_64.img
submenu 'Advanced options for Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-eb7ab5ef-5a39-443b-bafd-2105cf5ba628' {
menuentry 'Manjaro Linux (Kernel: 5.15.27-rt35-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.15.27-rt35-1-MANJARO x64-advanced-eb7ab5ef-5a39-443b-bafd-2105cf5ba628' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
menuentry 'Manjaro Linux (Kernel: 5.15.27-rt35-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.15.27-rt35-1-MANJARO x64-fallback-eb7ab5ef-5a39-443b-bafd-2105cf5ba628' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
initrd /boot/initramfs-5.15-rt-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Fedora Linux 35 (KDE Plasma) (on /dev/nvme0n1p5)' --class fedora --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-63abe411-58b0-4794-9679-c670f07e1e2d' {
savedefault
insmod part_gpt
insmod ext2
search --no-floppy --fs-uuid --set=root 63abe411-58b0-4794-9679-c670f07e1e2d
linux /boot/vmlinuz-0-rescue-8b96f5d1567d41578c39a64a7443d1eb root=/dev/nvme0n1p5
initrd /boot/initramfs-0-rescue-8b96f5d1567d41578c39a64a7443d1eb.img
submenu 'Advanced options for Fedora Linux 35 (KDE Plasma) (on /dev/nvme0n1p5)' $menuentry_id_option 'osprober-gnulinux-advanced-63abe411-58b0-4794-9679-c670f07e1e2d' {
menuentry 'Fedora Linux 35 (KDE Plasma) (on /dev/nvme0n1p5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-0-rescue-8b96f5d1567d41578c39a64a7443d1eb--63abe411-58b0-4794-9679-c670f07e1e2d' {
savedefault
insmod part_gpt
insmod ext2
menuentry 'Fedora Linux 35 (KDE Plasma) (on /dev/nvme0n1p5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.14.10-300.fc35.x86_64--63abe411-58b0-4794-9679-c670f07e1e2d' {
savedefault
insmod part_gpt
insmod ext2
linux /boot/vmlinuz-5.14.10-300.fc35.x86_64 root=/dev/nvme0n1p5
initrd /boot/initramfs-5.14.10-300.fc35.x86_64.img
menuentry 'Fedora Linux 35 (KDE Plasma) (on /dev/nvme0n1p5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.17.11-200.fc35.x86_64--63abe411-58b0-4794-9679-c670f07e1e2d' {
savedefault
insmod part_gpt
insmod ext2
linux /boot/vmlinuz-5.17.11-200.fc35.x86_64 root=/dev/nvme0n1p5
initrd /boot/initramfs-5.17.11-200.fc35.x86_64.img
menuentry 'Fedora Linux 35 (KDE Plasma) (on /dev/nvme0n1p5)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.17.7-200.fc35.x86_64--63abe411-58b0-4794-9679-c670f07e1e2d' {
savedefault
insmod part_gpt
insmod ext2
linux /boot/vmlinuz-5.17.7-200.fc35.x86_64 root=/dev/nvme0n1p5
initrd /boot/initramfs-5.17.7-200.fc35.x86_64.img
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
#menuentry "Fedora Bootloader" {
# insmod chain
# if [ x$feature_platform_search_hint = xy ]; then
# search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt5 --hint-efi=hd0,gpt5 63abe411-58b0-4794-9679-c670f07e1e2d
# else
# search --no-floppy --fs-uuid --set=root 63abe411-58b0-4794-9679-c670f07e1e2d
# fi
# configfile /boot/grub2/grub.cfg
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
search --fs-uuid --no-floppy --set=root eb7ab5ef-5a39-443b-bafd-2105cf5ba628
linux16 /boot/memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
