Berna
4 December 2024 00:08
1
Good morning everyone. The other evening I received about 7.5GB
of updates from the well-known Add/Remove Software
GUI. I started the updates and shortly after the Add/Remove Software
GUI crashed. So I reopened it but nothing happened. So I turned the Thinkpad T480 off and on again and was faced with this message:
error: file '/boot/vmlinuz-6.6-x86_64' not found.
error: you need to load the kernel first.
Press any key to continue...
I prepared a Live USB with Manjaro and used the command:
manjaro-chroot -a
getting:
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
I can access all my files. I don’t know how I should configure GRUB. After a few attempts where I tried using the commands:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro
update-grub
but when I restarted the computer I got:
error: no server is specified.
error: no suitable video mode found.
error: symbol 'grub_efi_set_variable_to_string' not found.
and after a few seconds:
error: sparse file not allowed.
error: symbol 'grub_is_shim_lock_enabled' not found.
Press any key to continue....
I searched online and the error error: symbol 'grub_is_shim_lock_enabled' not found.
should be related to Secure Boot
. However if I open UEFI Boot this setting is already disabled.
I thank everyone in advance for their attention.
P.S.
A little while ago I tried rerunning the manjaro-chroot -a
command and used the sudo pacman -Syu
command and got this output:
sudo: unable to find terminal name for device 136, 3
core is up to date
extra is up to date
community is up to date
multilib is up to date
there is nothing to do
cscs
4 December 2024 00:17
2
Your update was interrupted and according to the system files you have no kernel installed.
We also cannot be sure if that is the *only* problem.
You can start by doing something like
sudo pacman -Syu $(pacman -Qnq)
Which should instruct the system to reinstall all packages … likely providing some errors to tackle.
We also can specifically do the kernel install and initram/grub update dance;
sudo pacman -Syu linux66 && sudo mkinitcpio -P && sudo update-grub
Which you may wish to do after step 1 above, but is very very unlikely to be the only issue and thus the solve on its own.
PS.
We may also wonder about why the crash … an especially important and easy guess may be lack of space, which would likewise ruin any attempted new installs/updates, so please check your free space as well. ex;
lsblk -f
Berna
6 December 2024 09:03
3
Thank you for your answer.
I try to use the lsblk -f
command inside a Live USB with Manjaro and I obtain the following lines:
[manjaro /]# lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
loop1
loop2
loop3
sda
sdb
|-sdb1
`-sdb2
nvme0n1
|-nvme0n1p1 299M 0% /boot/efi
`-nvme0n1p2 134.7G 66% /
but I think there is enough space to download and install updates.
Next I tried using the command:
and I got a very long list of warnings.
So I used the last command you recommended, which is this:
and I got this:
[manjaro /]# sudo pacman -Syu linux66 && sudo mkinitcpio -P && sudo update-grub
sudo: unable to find terminal name for device 136, 1
core is up to date
extra is up to date
warning: linux66-6.6.63-1 is up to date -- reinstalling
resolving dependencies...
warning: dependency cycle detected:
warning: qt6-multimedia-ffmpeg will be installed before its qt6-multimedia dependency
Packages (110) archlinux-keyring-20241203-1 bash-completion-2.15.0-1
btrfs-progs-6.12-1 c-ares-1.34.3-1 chromium-131.0.6778.108-1
cpupower-6.12-1 dav1d-1.5.0-1 debootstrap-1.0.138-1
dkms-3.1.3-1 edk2-ovmf-202411-1 electron32-32.2.6-1
ffmpeg-2:7.1-3 file-5.46-1 filesystem-2024.11.25-2
fluidsynth-2.4.1-1 glslang-15.0.0-2 gnupg-2.4.7-1
gst-libav-1.24.10-1 gst-plugins-bad-1.24.10-1
gst-plugins-bad-libs-1.24.10-1 gst-plugins-base-1.24.10-1
gst-plugins-base-libs-1.24.10-1 gst-plugins-good-1.24.10-1
gst-plugins-ugly-1.24.10-1 gstreamer-1.24.10-1
kirigami-addons-1.6.0-1 kwin-6.2.4-2 layer-shell-qt-6.2.4-2
less-1:668-1 lib32-mesa-1:24.2.8-1 lib32-pixman-0.44.2-1
lib32-systemd-256.9-1 lib32-vulkan-intel-1:24.2.8-1
lib32-vulkan-radeon-1:24.2.8-1 libbpf-1.5.0-1 libldap-2.6.9-1
libpamac-11.7.0-2 libpamac-flatpak-plugin-11.7.0-2
libpamac-snap-plugin-11.7.0-2 libplacebo-7.349.0-3
libsynctex-2024.2-5 libsysprof-capture-47.2-1
libtool-2.5.4+r1+gbaa1fe41-1 libvirt-1:10.10.0-1
libvirt-python-1:10.10.0-1 libwireplumber-0.5.7-1
linux61-virtualbox-host-modules-7.1.4-9
linux66-virtualbox-host-modules-7.1.4-9 manjaro-hello-0.7.2-9
manjaro-release-24.2.0-1 mesa-1:24.2.8-1
mhwd-nvidia-470xx-470.256.02-9 mpv-1:0.39.0-4
node-gyp-10.3.1-1 nodejs-nopt-7.2.1-1
noto-fonts-1:2024.12.01-1 npth-1.8-1 nvidia-utils-550.135-2
openal-1.24.1-1 perf-6.12-1 pixman-0.44.2-1 pkgconf-2.3.0-1
qt6-5compat-6.8.1-1 qt6-base-6.8.1-1 qt6-charts-6.8.1-1
qt6-declarative-6.8.1-1 qt6-doc-6.8.1-1 qt6-examples-6.8.1-1
qt6-imageformats-6.8.1-1 qt6-multimedia-6.8.1-1
qt6-multimedia-ffmpeg-6.8.1-1 qt6-networkauth-6.8.1-1
qt6-positioning-6.8.1-1 qt6-quick3d-6.8.1-1
qt6-quicktimeline-6.8.1-1 qt6-scxml-6.8.1-1
qt6-sensors-6.8.1-1 qt6-serialport-6.8.1-1
qt6-shadertools-6.8.1-1 qt6-speech-6.8.1-1 qt6-svg-6.8.1-1
qt6-tools-6.8.1-1 qt6-translations-6.8.1-1
qt6-virtualkeyboard-6.8.1-1 qt6-wayland-6.8.1-1
qt6-webchannel-6.8.1-1 qt6-webengine-6.8.1-1
qt6-websockets-6.8.1-1 qtcreator-15.0.0-1 ruby-rexml-3.3.9-1
screenfetch-3.9.9-1 shaderc-2024.3-2 spirv-tools-2024.4.rc1-1
sqlite-3.47.1-1 sudo-1.9.16.p2-1 systemd-256.9-1
systemd-libs-256.9-1 systemd-sysvcompat-256.9-1
telegram-desktop-5.9.0-1 texlive-bin-2024.2-5
timeshift-24.06.4-1 traceroute-2.1.6-1 unrar-1:7.1.2-1
vulkan-intel-1:24.2.8-1 vulkan-radeon-1:24.2.8-1
wireplumber-0.5.7-1 wireshark-cli-4.4.2-3 wireshark-qt-4.4.2-3
zlib-ng-2.2.2-2 linux66-6.6.63-1
Total Download Size: 1211.25 MiB
Total Installed Size: 3596.05 MiB
Net Upgrade Size: 21.18 MiB
lib32-systemd-25... 924.5 KiB 1108 KiB/s 00:01 [######################] 100%
libpamac-11.7.0-... 867.1 KiB 1032 KiB/s 00:01 [######################] 100%
openal-1.24.1-1-... 823.0 KiB 983 KiB/s 00:01 [######################] 100%
qt6-charts-6.8.1... 805.8 KiB 1180 KiB/s 00:01 [######################] 100%
timeshift-24.06.... 752.9 KiB 1129 KiB/s 00:01 [######################] 100%
dav1d-1.5.0-1-x86_64 627.5 KiB 961 KiB/s 00:01 [######################] 100%
qt6-scxml-6.8.1-... 514.5 KiB 804 KiB/s 00:01 [######################] 100%
libplacebo-7.349... 496.1 KiB 775 KiB/s 00:01 [######################] 100%
qt6-5compat-6.8.... 452.3 KiB 715 KiB/s 00:01 [######################] 100%
file-5.46-1-x86_64 430.8 KiB 684 KiB/s 00:01 [######################] 100%
libtool-2.5.4+r1... 418.4 KiB 568 KiB/s 00:01 [######################] 100%
qt6-positioning-... 373.6 KiB 599 KiB/s 00:01 [######################] 100%
linux66-virtualb... 313.4 KiB 505 KiB/s 00:01 [######################] 100%
gst-plugins-base... 307.2 KiB 427 KiB/s 00:01 [######################] 100%
linux61-virtualb... 295.6 KiB 477 KiB/s 00:01 [######################] 100%
libldap-2.6.9-1-... 281.3 KiB 458 KiB/s 00:01 [######################] 100%
pixman-0.44.2-1-... 270.1 KiB 438 KiB/s 00:01 [######################] 100%
libwireplumber-0... 266.7 KiB 430 KiB/s 00:01 [######################] 100%
libbpf-1.5.0-1-x... 262.5 KiB 426 KiB/s 00:01 [######################] 100%
lib32-pixman-0.4... 259.8 KiB 419 KiB/s 00:01 [######################] 100%
fluidsynth-2.4.1... 250.3 KiB 406 KiB/s 00:01 [######################] 100%
qt6-svg-6.8.1-1-... 248.7 KiB 401 KiB/s 00:01 [######################] 100%
c-ares-1.34.3-1-... 225.7 KiB 362 KiB/s 00:01 [######################] 100%
wireplumber-0.5.... 224.6 KiB 362 KiB/s 00:01 [######################] 100%
qt6-multimedia-f... 222.2 KiB 360 KiB/s 00:01 [######################] 100%
libvirt-python-1... 215.3 KiB 349 KiB/s 00:01 [######################] 100%
bash-completion-... 209.7 KiB 340 KiB/s 00:01 [######################] 100%
cpupower-6.12-1-... 201.3 KiB 320 KiB/s 00:01 [######################] 100%
ruby-rexml-3.3.9... 200.7 KiB 320 KiB/s 00:01 [######################] 100%
qt6-sensors-6.8.... 187.7 KiB 309 KiB/s 00:01 [######################] 100%
unrar-1:7.1.2-1-... 181.7 KiB 299 KiB/s 00:01 [######################] 100%
gst-plugins-ugly... 176.2 KiB 286 KiB/s 00:01 [######################] 100%
shaderc-2024.3-2... 167.5 KiB 271 KiB/s 00:01 [######################] 100%
less-1:668-1-x86_64 142.4 KiB 232 KiB/s 00:01 [######################] 100%
qt6-webchannel-6... 129.3 KiB 180 KiB/s 00:01 [######################] 100%
qt6-speech-6.8.1... 127.7 KiB 208 KiB/s 00:01 [######################] 100%
manjaro-hello-0.... 107.6 KiB 174 KiB/s 00:01 [######################] 100%
qt6-websockets-6... 101.8 KiB 167 KiB/s 00:01 [######################] 100%
zlib-ng-2.2.2-2-... 98.6 KiB 161 KiB/s 00:01 [######################] 100%
gst-libav-1.24.1... 95.5 KiB 156 KiB/s 00:01 [######################] 100%
qt6-networkauth-... 88.8 KiB 145 KiB/s 00:01 [######################] 100%
qt6-quicktimelin... 75.9 KiB 123 KiB/s 00:01 [######################] 100%
qt6-imageformats... 66.4 KiB 108 KiB/s 00:01 [######################] 100%
pkgconf-2.3.0-1-... 61.8 KiB 199 KiB/s 00:00 [######################] 100%
qt6-serialport-6... 55.2 KiB 180 KiB/s 00:00 [######################] 100%
screenfetch-3.9.... 54.6 KiB 180 KiB/s 00:00 [######################] 100%
libsynctex-2024.... 48.0 KiB 155 KiB/s 00:00 [######################] 100%
libsysprof-captu... 47.2 KiB 152 KiB/s 00:00 [######################] 100%
dkms-3.1.3-1-any 46.8 KiB 113 KiB/s 00:00 [######################] 100%
filesystem-2024.... 40.0 KiB 129 KiB/s 00:00 [######################] 100%
traceroute-2.1.6... 38.9 KiB 125 KiB/s 00:00 [######################] 100%
debootstrap-1.0.... 37.6 KiB 123 KiB/s 00:00 [######################] 100%
layer-shell-qt-6... 35.3 KiB 114 KiB/s 00:00 [######################] 100%
libpamac-flatpak... 29.6 KiB 91.6 KiB/s 00:00 [######################] 100%
npth-1.8-1-x86_64 28.2 KiB 92.2 KiB/s 00:00 [######################] 100%
libpamac-snap-pl... 25.8 KiB 84.0 KiB/s 00:00 [######################] 100%
mhwd-nvidia-470x... 25.1 KiB 81.1 KiB/s 00:00 [######################] 100%
manjaro-release-... 17.4 KiB 56.8 KiB/s 00:00 [######################] 100%
nodejs-nopt-7.2.... 13.1 KiB 42.8 KiB/s 00:00 [######################] 100%
systemd-sysvcomp... 6.6 KiB 21.7 KiB/s 00:00 [######################] 100%
Total (109/109) 1211.2 MiB 2.74 MiB/s 07:23 [######################] 100%
(110/110) checking keys in keyring [######################] 100%
(110/110) checking package integrity [######################] 100%
(110/110) loading package files [######################] 100%
(110/110) checking for file conflicts [######################] 100%
(110/110) checking available disk space [######################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
/usr/bin/timeshift-autosnap: line 5: [: too many arguments
/usr/bin/timeshift-autosnap: line 36: [: too many arguments
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Remove upgraded DKMS modules
( 1/110) upgrading filesystem [######################] 100%
( 2/110) upgrading systemd-libs [######################] 100%
( 3/110) upgrading libldap [######################] 100%
( 4/110) upgrading sqlite [######################] 100%
( 5/110) upgrading file [######################] 100%
( 6/110) upgrading systemd [######################] 100%
Assertion 'path_is_absolute(p)' failed at src/basic/chase.c:648, function chase(). Aborting.
/tmp/alpm_Nu51lQ/.INSTALL: line 7: 574 Aborted (core dumped) systemd-sysusers
/tmp/alpm_Nu51lQ/.INSTALL: line 7: 575 Aborted (core dumped) journalctl --update-catalog
( 7/110) reinstalling linux66 [######################] 100%
( 8/110) upgrading npth [######################] 100%
( 9/110) upgrading libsysprof-capture [######################] 100%
( 10/110) upgrading gnupg [######################] 100%
( 11/110) upgrading archlinux-keyring [######################] 100%
==> Appending keys from archlinux.gpg...
==> Updating trust database...
gpg: next trustdb check due at 2025-01-01
( 12/110) upgrading bash-completion [######################] 100%
( 13/110) upgrading btrfs-progs [######################] 100%
( 14/110) upgrading c-ares [######################] 100%
( 15/110) upgrading pixman [######################] 100%
( 16/110) upgrading mesa [######################] 100%
( 17/110) upgrading nvidia-utils [######################] 100%
xorg configuration symlink valid...
Enabling nvidia-resume...
/tmp/alpm_ck690p/.INSTALL: line 33: 676 Aborted (core dumped) systemctl enable $service
Enabling nvidia-hibernate...
/tmp/alpm_ck690p/.INSTALL: line 33: 678 Aborted (core dumped) systemctl enable $service
Enabling nvidia-suspend...
/tmp/alpm_ck690p/.INSTALL: line 33: 680 Aborted (core dumped) systemctl enable $service
error: command failed to execute correctly
( 18/110) upgrading dav1d [######################] 100%
( 19/110) upgrading chromium [######################] 100%
( 20/110) upgrading cpupower [######################] 100%
( 21/110) upgrading debootstrap [######################] 100%
( 22/110) upgrading dkms [######################] 100%
( 23/110) upgrading edk2-ovmf [######################] 100%
( 24/110) upgrading electron32 [######################] 100%
( 25/110) upgrading spirv-tools [######################] 100%
( 26/110) upgrading glslang [######################] 100%
( 27/110) upgrading shaderc [######################] 100%
( 28/110) upgrading libplacebo [######################] 100%
( 29/110) upgrading ffmpeg [######################] 100%
( 30/110) upgrading fluidsynth [######################] 100%
( 31/110) upgrading gstreamer [######################] 100%
( 32/110) upgrading gst-plugins-base-libs [######################] 100%
( 33/110) upgrading gst-libav [######################] 100%
( 34/110) upgrading gst-plugins-bad-libs [######################] 100%
( 35/110) upgrading openal [######################] 100%
( 36/110) upgrading libtool [######################] 100%
( 37/110) upgrading gst-plugins-bad [######################] 100%
( 38/110) upgrading gst-plugins-base [######################] 100%
( 39/110) upgrading gst-plugins-good [######################] 100%
( 40/110) upgrading gst-plugins-ugly [######################] 100%
( 41/110) upgrading qt6-translations [######################] 100%
( 42/110) upgrading qt6-base [######################] 100%
( 43/110) upgrading qt6-declarative [######################] 100%
( 44/110) upgrading qt6-multimedia-ffmpeg [######################] 100%
( 45/110) upgrading qt6-multimedia [######################] 100%
( 46/110) upgrading qt6-svg [######################] 100%
( 47/110) upgrading qt6-wayland [######################] 100%
( 48/110) upgrading kirigami-addons [######################] 100%
( 49/110) upgrading libwireplumber [######################] 100%
( 50/110) upgrading wireplumber [######################] 100%
( 51/110) upgrading qt6-shadertools [######################] 100%
( 52/110) upgrading qt6-5compat [######################] 100%
( 53/110) upgrading qt6-sensors [######################] 100%
( 54/110) upgrading qt6-tools [######################] 100%
( 55/110) upgrading layer-shell-qt [######################] 100%
( 56/110) upgrading kwin [######################] 100%
( 57/110) upgrading less [######################] 100%
( 58/110) upgrading lib32-mesa [######################] 100%
( 59/110) upgrading lib32-pixman [######################] 100%
( 60/110) upgrading lib32-systemd [######################] 100%
( 61/110) upgrading vulkan-intel [######################] 100%
( 62/110) upgrading lib32-vulkan-intel [######################] 100%
( 63/110) upgrading vulkan-radeon [######################] 100%
( 64/110) upgrading lib32-vulkan-radeon [######################] 100%
( 65/110) upgrading libbpf [######################] 100%
( 66/110) upgrading libpamac [######################] 100%
( 67/110) upgrading libpamac-flatpak-plugin [######################] 100%
( 68/110) upgrading libpamac-snap-plugin [######################] 100%
( 69/110) upgrading libsynctex [######################] 100%
( 70/110) upgrading libvirt [######################] 100%
warning: directory permissions differ on /var/lib/libvirt/swtpm/
filesystem: 755 package: 711
( 71/110) upgrading libvirt-python [######################] 100%
( 72/110) upgrading linux61-virtualbox-host-mo... [######################] 100%
( 73/110) upgrading linux66-virtualbox-host-mo... [######################] 100%
( 74/110) upgrading manjaro-hello [######################] 100%
( 75/110) upgrading manjaro-release [######################] 100%
( 76/110) upgrading mhwd-nvidia-470xx [######################] 100%
( 77/110) upgrading mpv [######################] 100%
( 78/110) upgrading nodejs-nopt [######################] 100%
( 79/110) upgrading node-gyp [######################] 100%
( 80/110) upgrading noto-fonts [######################] 100%
( 81/110) upgrading perf [######################] 100%
( 82/110) upgrading pkgconf [######################] 100%
( 83/110) upgrading qt6-charts [######################] 100%
( 84/110) upgrading qt6-doc [######################] 100%
( 85/110) upgrading qt6-examples [######################] 100%
( 86/110) upgrading qt6-imageformats [######################] 100%
( 87/110) upgrading qt6-networkauth [######################] 100%
( 88/110) upgrading qt6-positioning [######################] 100%
( 89/110) upgrading qt6-quicktimeline [######################] 100%
( 90/110) upgrading qt6-quick3d [######################] 100%
( 91/110) upgrading qt6-scxml [######################] 100%
( 92/110) upgrading qt6-serialport [######################] 100%
( 93/110) upgrading qt6-speech [######################] 100%
( 94/110) upgrading qt6-virtualkeyboard [######################] 100%
( 95/110) upgrading qt6-webchannel [######################] 100%
( 96/110) upgrading qt6-webengine [######################] 100%
( 97/110) upgrading qt6-websockets [######################] 100%
( 98/110) upgrading qtcreator [######################] 100%
( 99/110) upgrading ruby-rexml [######################] 100%
(100/110) upgrading screenfetch [######################] 100%
(101/110) upgrading sudo [######################] 100%
(102/110) upgrading systemd-sysvcompat [######################] 100%
(103/110) upgrading telegram-desktop [######################] 100%
(104/110) upgrading texlive-bin [######################] 100%
(105/110) upgrading timeshift [######################] 100%
(106/110) upgrading traceroute [######################] 100%
(107/110) upgrading unrar [######################] 100%
(108/110) installing zlib-ng [######################] 100%
(109/110) upgrading wireshark-cli [######################] 100%
(110/110) upgrading wireshark-qt [######################] 100%
( 1/25) Creating system user accounts...
fmtutil [ERROR]: running `luahbtex -ini -jobname=luahbtex -progname=luahbtex luatex.ini </dev/null' return status: 1
fmtutil [ERROR]: returning error due to option --strict
fmtutil [ERROR]: running `luajittex -ini -jobname=luajittex -progname=luajittex luatex.ini </dev/null' return status: 1
fmtutil [ERROR]: running `luajithbtex -ini -jobname=luajithbtex -progname=luajithbtex luatex.ini </dev/null' return status: 1
fmtutil [WARNING]: inifile pdfetex.ini for pdfetex/pdftex not found.
fmtutil [WARNING]: inifile dvilualatex.ini for dvilualatex/luatex not found.
fmtutil [ERROR]: running `luatex -ini -jobname=dviluatex -progname=dviluatex dviluatex.ini </dev/null' return status: 1
fmtutil [WARNING]: inifile lualatex.ini for lualatex-dev/luahbtex not found.
fmtutil [WARNING]: inifile lualatex.ini for lualatex/luahbtex not found.
fmtutil [ERROR]: running `pdftex -ini -jobname=mptopdf -progname=context -translate-file=cp227.tcx mptopdf.tex </dev/null' return status: 1
fmtutil [WARNING]: inifile etex.ini for etex/pdftex not found.
fmtutil [WARNING]: inifile pdflatex.ini for pdflatex/pdftex not found.
fmtutil [WARNING]: inifile dvilualatex.ini for dvilualatex-dev/luatex not found.
fmtutil [WARNING]: inifile pdflatex.ini for pdflatex-dev/pdftex not found.
fmtutil [ERROR]: running `pdftex -ini -jobname=amstex -progname=amstex -translate-file=cp227.tcx *amstex.ini </dev/null' return status: 1
fmtutil [WARNING]: inifile latex.ini for latex/pdftex not found.
fmtutil [WARNING]: inifile latex.ini for latex-dev/pdftex not found.
(14/25) Updating TeXLive font maps...
(15/25) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
==> Starting build: '6.6.63-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> WARNING: No fsck helpers found. fsck will not be run on boot.
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
(16/25) Updating Kernel initcpios for Nvidia-DRM...
(17/25) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
(18/25) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(19/25) Reloading system bus configuration...
Skipped: Running in chroot.
(20/25) Updating fontconfig cache...
(21/25) Updating 32-bit fontconfig cache...
(22/25) Updating icon theme caches...
(23/25) Updating the info directory file...
(24/25) Updating the desktop file MIME type cache...
(25/25) Updating X fontdir indices...
Now I don’t know if with the initcpio image generation successful
message I can try turning it off and on again to see if everything works or consider whether to run other commands first to “fix” other problems. Thank you very much for your attention.
cscs
6 December 2024 09:19
4
I’m not sure if you included the full output from the final exchange.
I see an edit added more, but still the output from sudo update-grub
is missing.
It may have not fired because of errors encountered in the prior command.
Still, running sudo update-grub
is required after rebuilding initramfs (mkinitcpio).
And I am not familiar with the errors here;
Berna:
That said
This should be handled.
Reinstalling existing local native packages shouldnt produce a bunch of errors.
If it does, we should analyze and formulate approaches to overcome them.
PS.
Its likely unrelated, but no Arch/Manjaro system should have or use packagekit.
sudo pacman -Rns $(pacman -Qsq packagekit)
Berna
6 December 2024 11:06
7
I try to use sudo update-grub
and I obtain:
[manjaro /]# sudo update-grub
done
I try again using the command sudo pacman -Syu $(pacman -Qnq)
and now I obtain:
[manjaro /]# sudo pacman -Syu $(pacman -Qnq)
core is up to date
extra is up to date
warning: a52dec-0.8.0-2 is up to date -- reinstalling
warning: aalib-1.4rc5-18 is up to date -- reinstalling
warning: abseil-cpp-20240722.0-1 is up to date -- reinstalling
warning: accounts-qml-module-0.7-6 is up to date -- reinstalling
warning: accountsservice-23.13.9-2 is up to date -- reinstalling
warning: acl-2.3.2-1 is up to date -- reinstalling
Packages (1969) a52dec-0.8.0-2 aalib-1.4rc5-18 abseil-cpp-20240722.0-1
accounts-qml-module-0.7-6 accountsservice-23.13.9-2
acl-2.3.2-1 acpi-1.7-4 acpid-2.0.34-2 ada-2.9.0-2
Total Download Size: 7135.74 MiB
Total Installed Size: 30442.11 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
cuda-12.6.3-1-x86_64 1842.2 MiB 6.07 MiB/s 05:04 [######################] 100%
(1969/1969) checking available disk space [######################] 100%
warning: could not get file information for usr/share/foomatic/db/source/printer/Olivetti-JP350S.xml
warning: could not get file information for usr/share/foomatic/db/source/printer/Olivetti-JP450.xml
warning: could not get file information for usr/share/foomatic/db/source/printer/Olivetti-JP470.xml
warning: could not get file information for usr/share/foomatic/db/source/printer/Olivetti-PG_306.xml
warning: could not get file information for usr/share/foomatic/db/source/printer/Olivetti-d-Color_P160W.xml
warning: could not get file information for var/log/gssproxy/
warning: could not get file information for usr/share/icons/Papirus/16x16/apps/gnvim.svg
warning: could not get file information for usr/share/icons/Papirus/16x16/apps/io.neovim.nvim.svg
warning: could not get file information for usr/share/icons/Papirus/16x16/apps/nvim-gtk.svg
warning: could not get file information for usr/share/icons/Papirus/16x16/apps/nvim-qt.svg
warning: could not get file information for usr/share/icons/Papirus/16x16/apps/nvim.svg
warning: could not get file information for usr/share/icons/Papirus/16x16/apps/pynvim.svg
warning: could not get file information for usr/share/icons/Papirus/22x22/apps/gnvim.svg
warning: could not get file information for usr/share/icons/Papirus/22x22/apps/io.neovim.nvim.svg
warning: could not get file information for usr/share/icons/Papirus/22x22/apps/nvim-gtk.svg
warning: could not get file information for usr/share/icons/Papirus/22x22/apps/nvim-qt.svg
warning: could not get file information for usr/share/icons/Papirus/22x22/apps/nvim.svg
warning: could not get file information for usr/share/icons/Papirus/22x22/apps/pynvim.svg
warning: could not get file information for usr/share/icons/Papirus/24x24/apps/gnvim.svg
warning: could not get file information for usr/share/icons/Papirus/24x24/apps/io.neovim.nvim.svg
warning: could not get file information for usr/share/icons/Papirus/24x24/apps/nvim-gtk.svg
warning: could not get file information for usr/share/icons/Papirus/24x24/apps/nvim-qt.svg
warning: could not get file information for usr/share/icons/Papirus/24x24/apps/nvim.svg
warning: could not get file information for usr/share/icons/Papirus/24x24/apps/pynvim.svg
warning: could not get file information for usr/share/icons/Papirus/32x32/apps/gnvim.svg
warning: could not get file information for usr/share/icons/Papirus/32x32/apps/io.neovim.nvim.svg
warning: could not get file information for usr/share/icons/Papirus/32x32/apps/nvim-gtk.svg
warning: could not get file information for usr/share/icons/Papirus/32x32/apps/nvim-qt.svg
warning: could not get file information for usr/share/icons/Papirus/32x32/apps/nvim.svg
warning: could not get file information for usr/share/icons/Papirus/32x32/apps/pynvim.svg
warning: could not get file information for usr/share/icons/Papirus/48x48/apps/gnvim.svg
warning: could not get file information for usr/share/icons/Papirus/48x48/apps/io.neovim.nvim.svg
warning: could not get file information for usr/share/icons/Papirus/48x48/apps/nvim-gtk.svg
warning: could not get file information for usr/share/icons/Papirus/48x48/apps/nvim-qt.svg
warning: could not get file information for usr/share/icons/Papirus/48x48/apps/nvim.svg
warning: could not get file information for usr/share/icons/Papirus/48x48/apps/pynvim.svg
warning: could not get file information for usr/share/icons/Papirus/64x64/apps/gnvim.svg
warning: could not get file information for usr/share/icons/Papirus/64x64/apps/io.neovim.nvim.svg
warning: could not get file information for usr/share/icons/Papirus/64x64/apps/nvim-gtk.svg
warning: could not get file information for usr/share/icons/Papirus/64x64/apps/nvim-qt.svg
warning: could not get file information for usr/share/icons/Papirus/64x64/apps/nvim.svg
warning: could not get file information for usr/share/icons/Papirus/64x64/apps/pynvim.svg
(1/4) Creating Timeshift snapshot before upgrade...
(2/4) Remove upgraded DKMS modules
(3/4) Remove Firefox Distribution Settings
(4/4) Unregistering Haskell modules...
( 1/1969) reinstalling linux-api-headers [######################] 100%
( 2/1969) reinstalling tzdata [######################] 100%
( 3/1969) reinstalling iana-etc [######################] 100%
( 4/1969) reinstalling filesystem [######################] 100%
( 5/1969) reinstalling glibc [######################] 100%
Generating locales...
en_US.UTF-8... done
it_IT.UTF-8... done
Generation complete.
( 6/1969) reinstalling a52dec [######################] 100%
( 7/1969) reinstalling gcc-libs [######################] 100%
( 8/1969) reinstalling ncurses [######################] 100%
( 9/1969) reinstalling readline [######################] 100%
( 10/1969) reinstalling bash [######################] 100%
( 11/1969) reinstalling zlib [######################] 100%
( 12/1969) reinstalling sqlite [######################] 100%
( 13/1969) reinstalling util-linux-libs [######################] 100%
( 14/1969) reinstalling e2fsprogs [######################] 100%
( 15/1969) reinstalling keyutils [######################] 100%
( 16/1969) reinstalling gdbm [######################] 100%
( 17/1969) reinstalling openssl [######################] 100%
( 18/1969) reinstalling libsasl [######################] 100%
( 19/1969) reinstalling libldap [######################] 100%
( 20/1969) reinstalling libevent [######################] 100%
( 21/1969) reinstalling libverto [######################] 100%
( 22/1969) reinstalling lmdb [######################] 100%
( 23/1969) reinstalling krb5 [######################] 100%
( 24/1969) reinstalling libcap-ng [######################] 100%
( 25/1969) reinstalling audit [######################] 100%
( 26/1969) reinstalling libxcrypt [######################] 100%
( 27/1969) reinstalling libtirpc [######################] 100%
( 28/1969) reinstalling libnsl [######################] 100%
( 29/1969) reinstalling pambase [######################] 100%
( 30/1969) reinstalling pam [######################] 100%
( 31/1969) reinstalling libcap [######################] 100%
( 32/1969) reinstalling libgpg-error [######################] 100%
( 33/1969) reinstalling libgcrypt [######################] 100%
( 34/1969) reinstalling lz4 [######################] 100%
( 35/1969) reinstalling xz [######################] 100%
( 36/1969) reinstalling zstd [######################] 100%
( 37/1969) reinstalling systemd-libs [######################] 100%
( 38/1969) reinstalling procps-ng [######################] 100%
( 39/1969) reinstalling gpm [######################] 100%
( 40/1969) reinstalling xcb-proto [######################] 100%
( 41/1969) reinstalling xorgproto [######################] 100%
( 42/1969) reinstalling libxdmcp [######################] 100%
( 43/1969) reinstalling libxau [######################] 100%
( 44/1969) reinstalling libxcb [######################] 100%
( 45/1969) reinstalling libx11 [######################] 100%
( 46/1969) reinstalling bzip2 [######################] 100%
( 47/1969) reinstalling pcre [######################] 100%
( 48/1969) reinstalling slang [######################] 100%
( 49/1969) reinstalling aalib [######################] 100%
( 50/1969) reinstalling gtest [######################] 100%
( 51/1969) reinstalling abseil-cpp [######################] 100%
( 52/1969) reinstalling libffi [######################] 100%
( 53/1969) reinstalling libsysprof-capture [######################] 100%
( 54/1969) reinstalling pcre2 [######################] 100%
( 55/1969) reinstalling glib2 [######################] 100%
( 56/1969) reinstalling icu [######################] 100%
( 57/1969) reinstalling libxml2 [######################] 100%
( 58/1969) reinstalling libaccounts-glib [######################] 100%
( 59/1969) reinstalling brotli [######################] 100%
( 60/1969) reinstalling expat [######################] 100%
( 61/1969) reinstalling dbus [######################] 100%
( 62/1969) reinstalling double-conversion [######################] 100%
( 63/1969) reinstalling libpng [######################] 100%
( 64/1969) reinstalling graphite [######################] 100%
( 65/1969) reinstalling harfbuzz [######################] 100%
( 66/1969) reinstalling freetype2 [######################] 100%
( 67/1969) reinstalling fontconfig [######################] 100%
Rebuilding fontconfig cache...
( 68/1969) reinstalling libb2 [######################] 100%
( 69/1969) reinstalling gmp [######################] 100%
( 70/1969) reinstalling libtasn1 [######################] 100%
( 71/1969) reinstalling nettle [######################] 100%
( 72/1969) reinstalling libp11-kit [######################] 100%
( 73/1969) reinstalling libunistring [######################] 100%
( 74/1969) reinstalling libidn2 [######################] 100%
( 75/1969) reinstalling gnutls [######################] 100%
( 76/1969) reinstalling libdaemon [######################] 100%
( 77/1969) reinstalling avahi [######################] 100%
( 78/1969) reinstalling libcups [######################] 100%
( 79/1969) reinstalling libpciaccess [######################] 100%
( 80/1969) reinstalling libdrm [######################] 100%
( 81/1969) reinstalling libxext [######################] 100%
( 82/1969) reinstalling acl [######################] 100%
( 83/1969) reinstalling attr [######################] 100%
( 84/1969) reinstalling coreutils [######################] 100%
( 85/1969) reinstalling findutils [######################] 100%
( 86/1969) reinstalling p11-kit [######################] 100%
( 87/1969) reinstalling ca-certificates-utils [######################] 100%
( 88/1969) reinstalling ca-certificates-mozilla [######################] 100%
( 89/1969) reinstalling ca-certificates [######################] 100%
( 90/1969) reinstalling libnghttp2 [######################] 100%
( 91/1969) reinstalling libnghttp3 [######################] 100%
( 92/1969) reinstalling libpsl [######################] 100%
( 93/1969) reinstalling libssh2 [######################] 100%
( 94/1969) reinstalling curl [######################] 100%
( 95/1969) reinstalling json-c [######################] 100%
( 96/1969) reinstalling libelf [######################] 100%
( 97/1969) reinstalling libxfixes [######################] 100%
( 98/1969) reinstalling libxshmfence [######################] 100%
( 99/1969) reinstalling libxxf86vm [######################] 100%
( 100/1969) reinstalling libedit [######################] 100%
( 101/1969) reinstalling llvm-libs [######################] 100%
( 102/1969) reinstalling lm_sensors [######################] 100%
( 103/1969) reinstalling default-cursors [######################] 100%
( 104/1969) reinstalling wayland [######################] 100%
( 105/1969) reinstalling libomxil-bellagio [######################] 100%
( 106/1969) reinstalling mesa [######################] 100%
( 107/1969) reinstalling eglexternalplatform [######################] 100%
( 108/1969) reinstalling egl-wayland [######################] 100%
( 109/1969) reinstalling nvidia-utils [######################] 100%
( 110/1969) reinstalling libglvnd [######################] 100%
( 111/1969) reinstalling libice [######################] 100%
( 112/1969) reinstalling mtdev [######################] 100%
( 113/1969) reinstalling libevdev [######################] 100%
( 114/1969) reinstalling device-mapper [######################] 100%
( 115/1969) reinstalling popt [######################] 100%
( 116/1969) reinstalling argon2 [######################] 100%
( 117/1969) reinstalling cryptsetup [######################] 100%
( 118/1969) reinstalling dbus-broker [######################] 100%
( 119/1969) reinstalling dbus-broker-units [######################] 100%
( 120/1969) reinstalling sed [######################] 100%
( 121/1969) reinstalling grep [######################] 100%
( 122/1969) reinstalling gzip [######################] 100%
( 123/1969) reinstalling kbd [######################] 100%
( 124/1969) reinstalling kmod [######################] 100%
( 125/1969) reinstalling hwdata [######################] 100%
( 126/1969) reinstalling libseccomp [######################] 100%
( 127/1969) reinstalling file [######################] 100%
( 128/1969) reinstalling shadow [######################] 100%
( 129/1969) reinstalling util-linux [######################] 100%
( 130/1969) reinstalling systemd [######################] 100%
/tmp/alpm_u98qeI/.INSTALL: line 7: 36913 Aborted (core dumped) systemd-sysusers
/tmp/alpm_u98qeI/.INSTALL: line 7: 36914 Aborted (core dumped) journalctl --update-catalog
( 131/1969) reinstalling libgudev [######################] 100%
( 132/1969) reinstalling libwacom [######################] 100%
( 133/1969) reinstalling libinput [######################] 100%
( 134/1969) reinstalling libjpeg-turbo [######################] 100%
( 135/1969) reinstalling duktape [######################] 100%
( 136/1969) reinstalling libproxy [######################] 100%
( 137/1969) reinstalling libsm [######################] 100%
( 138/1969) reinstalling xkeyboard-config [######################] 100%
( 139/1969) reinstalling libxkbcommon [######################] 100%
( 140/1969) reinstalling libxkbcommon-x11 [######################] 100%
( 141/1969) reinstalling md4c [######################] 100%
( 142/1969) reinstalling shared-mime-info [######################] 100%
( 143/1969) reinstalling tslib [######################] 100%
( 144/1969) reinstalling vulkan-headers [######################] 100%
( 145/1969) reinstalling xcb-util-renderutil [######################] 100%
( 146/1969) reinstalling xcb-util [######################] 100%
( 147/1969) reinstalling xcb-util-image [######################] 100%
( 148/1969) reinstalling xcb-util-cursor [######################] 100%
( 149/1969) reinstalling xcb-util-keysyms [######################] 100%
( 150/1969) reinstalling xcb-util-wm [######################] 100%
( 151/1969) reinstalling libxt [######################] 100%
( 152/1969) reinstalling libxmu [######################] 100%
( 153/1969) reinstalling xorg-xset [######################] 100%
( 154/1969) reinstalling xorg-xprop [######################] 100%
( 155/1969) reinstalling xdg-utils [######################] 100%
( 156/1969) reinstalling qt6-translations [######################] 100%
( 157/1969) reinstalling qt6-base [######################] 100%
( 158/1969) reinstalling libaccounts-qt [######################] 100%
( 159/1969) reinstalling qt6-declarative [######################] 100%
( 160/1969) reinstalling signond [######################] 100%
( 161/1969) reinstalling accounts-qml-module [######################] 100%
( 162/1969) reinstalling polkit [######################] 100%
( 163/1969) reinstalling accountsservice [######################] 100%
( 164/1969) reinstalling acpi [######################] 100%
( 165/1969) reinstalling acpid [######################] 100%
( 166/1969) reinstalling ada [######################] 100%
( 167/1969) reinstalling adobe-source-code-pro... [######################] 100%
( 168/1969) reinstalling adobe-source-han-sans... [######################] 100%
( 169/1969) reinstalling adobe-source-han-sans... [######################] 100%
( 170/1969) reinstalling adobe-source-han-sans... [######################] 100%
( 171/1969) reinstalling adobe-source-sans-fonts [######################] 100%
( 172/1969) reinstalling adwaita-cursors [######################] 100%
( 173/1969) reinstalling hicolor-icon-theme [######################] 100%
( 174/1969) reinstalling adwaita-icon-theme-legacy [######################] 100%
( 175/1969) reinstalling adwaita-icon-theme [######################] 100%
( 176/1969) reinstalling alsa-card-profiles [######################] 100%
( 177/1969) reinstalling alsa-firmware [######################] 100%
( 178/1969) reinstalling alsa-topology-conf [######################] 100%
( 179/1969) reinstalling alsa-ucm-conf [######################] 100%
( 180/1969) reinstalling alsa-lib [######################] 100%
( 181/1969) reinstalling alsa-oss [######################] 100%
( 182/1969) reinstalling alsa-plugins [######################] 100%
( 183/1969) reinstalling pciutils [######################] 100%
( 184/1969) reinstalling psmisc [######################] 100%
( 185/1969) reinstalling libsamplerate [######################] 100%
( 186/1969) reinstalling alsa-utils [######################] 100%
( 187/1969) reinstalling fmt [######################] 100%
( 188/1969) reinstalling protobuf [######################] 100%
( 189/1969) reinstalling libusb [######################] 100%
( 190/1969) reinstalling libmtp [######################] 100%
( 191/1969) reinstalling android-udev [######################] 100%
( 192/1969) reinstalling android-tools [######################] 100%
( 193/1969) reinstalling aom [######################] 100%
( 194/1969) reinstalling mpdecimal [######################] 100%
( 195/1969) reinstalling python [######################] 100%
( 196/1969) reinstalling apparmor [######################] 100%
( 197/1969) reinstalling libxrender [######################] 100%
( 198/1969) reinstalling lzo [######################] 100%
( 199/1969) reinstalling pixman [######################] 100%
( 200/1969) reinstalling cairo [######################] 100%
( 201/1969) reinstalling desktop-file-utils [######################] 100%
( 202/1969) reinstalling boost-libs [######################] 100%
( 203/1969) reinstalling libarchive [######################] 100%
( 204/1969) reinstalling dav1d [######################] 100%
( 205/1969) reinstalling jbigkit [######################] 100%
( 206/1969) reinstalling libtiff [######################] 100%
( 207/1969) reinstalling gdk-pixbuf2 [######################] 100%
( 208/1969) reinstalling fribidi [######################] 100%
( 209/1969) reinstalling libdatrie [######################] 100%
( 210/1969) reinstalling libthai [######################] 100%
( 211/1969) reinstalling libxft [######################] 100%
( 212/1969) reinstalling pango [######################] 100%
( 213/1969) reinstalling librsvg [######################] 100%
( 214/1969) reinstalling fuse-common [######################] 100%
( 215/1969) reinstalling fuse2 [######################] 100%
( 216/1969) reinstalling squashfuse [######################] 100%
( 217/1969) reinstalling libappimage [######################] 100%
( 218/1969) reinstalling libmd [######################] 100%
( 219/1969) reinstalling libbsd [######################] 100%
( 220/1969) reinstalling libxpm [######################] 100%
( 221/1969) reinstalling libxi [######################] 100%
( 222/1969) reinstalling qt5-translations [######################] 100%
( 223/1969) reinstalling qt5-base [######################] 100%
( 224/1969) reinstalling appimagelauncher [######################] 100%
( 225/1969) reinstalling libstemmer [######################] 100%
( 226/1969) reinstalling libxmlb [######################] 100%
( 227/1969) reinstalling libyaml [######################] 100%
( 228/1969) reinstalling appstream [######################] 100%
( 229/1969) reinstalling appstream-qt [######################] 100%
( 230/1969) reinstalling appstream-qt5 [######################] 100%
( 231/1969) reinstalling archlinux-appstream-data [######################] 100%
( 232/1969) reinstalling mpfr [######################] 100%
( 233/1969) reinstalling gawk [######################] 100%
( 234/1969) reinstalling gettext [######################] 100%
( 235/1969) reinstalling libksba [######################] 100%
( 236/1969) reinstalling libassuan [######################] 100%
( 237/1969) reinstalling tpm2-tss [######################] 100%
( 238/1969) reinstalling libsecret [######################] 100%
( 239/1969) reinstalling pinentry [######################] 100%
( 240/1969) reinstalling npth [######################] 100%
( 241/1969) reinstalling gnupg [######################] 100%
( 242/1969) reinstalling gpgme [######################] 100%
( 243/1969) reinstalling python-npyscreen [######################] 100%
( 244/1969) reinstalling python-charset-normalizer [######################] 100%
( 245/1969) reinstalling python-idna [######################] 100%
( 246/1969) reinstalling python-urllib3 [######################] 100%
( 247/1969) reinstalling python-requests [######################] 100%
( 248/1969) reinstalling pacman-mirrors [######################] 100%
( 249/1969) reinstalling pacman [######################] 100%
( 250/1969) reinstalling archlinux-keyring [######################] 100%
( 251/1969) reinstalling aribb24 [######################] 100%
( 252/1969) reinstalling dconf [######################] 100%
( 253/1969) reinstalling gsettings-system-schemas [######################] 100%
( 254/1969) reinstalling cantarell-fonts [######################] 100%
( 255/1969) reinstalling gsettings-desktop-schemas [######################] 100%
( 256/1969) reinstalling libxtst [######################] 100%
( 257/1969) reinstalling at-spi2-core [######################] 100%
( 258/1969) reinstalling libsigc++ [######################] 100%
( 259/1969) reinstalling glibmm [######################] 100%
( 260/1969) reinstalling atkmm [######################] 100%
( 261/1969) reinstalling attica [######################] 100%
( 262/1969) reinstalling attica5 [######################] 100%
( 263/1969) reinstalling libogg [######################] 100%
( 264/1969) reinstalling flac [######################] 100%
( 265/1969) reinstalling iso-codes [######################] 100%
( 266/1969) reinstalling libcloudproviders [######################] 100%
( 267/1969) reinstalling lcms2 [######################] 100%
( 268/1969) reinstalling libcolord [######################] 100%
( 269/1969) reinstalling libepoxy [######################] 100%
( 270/1969) reinstalling libxcomposite [######################] 100%
( 271/1969) reinstalling libxcursor [######################] 100%
( 272/1969) reinstalling libxdamage [######################] 100%
( 273/1969) reinstalling libxinerama [######################] 100%
( 274/1969) reinstalling libxrandr [######################] 100%
( 275/1969) reinstalling json-glib [######################] 100%
( 276/1969) reinstalling glib-networking [######################] 100%
( 277/1969) reinstalling libsoup3 [######################] 100%
( 278/1969) reinstalling tinysparql [######################] 100%
( 279/1969) reinstalling gtk-update-icon-cache [######################] 100%
( 280/1969) reinstalling gtk3 [######################] 100%
( 281/1969) reinstalling db5.3 [######################] 100%
( 282/1969) reinstalling opus [######################] 100%
( 283/1969) reinstalling jack2 [######################] 100%
( 284/1969) reinstalling lame [######################] 100%
( 285/1969) reinstalling libid3tag [######################] 100%
( 286/1969) reinstalling libmad [######################] 100%
( 287/1969) reinstalling libsbsms [######################] 100%
( 288/1969) reinstalling libvorbis [######################] 100%
( 289/1969) reinstalling mpg123 [######################] 100%
( 290/1969) reinstalling libsndfile [######################] 100%
( 291/1969) reinstalling libsoxr [######################] 100%
( 292/1969) reinstalling serd [######################] 100%
( 293/1969) reinstalling zix [######################] 100%
( 294/1969) reinstalling sord [######################] 100%
( 295/1969) reinstalling lv2 [######################] 100%
( 296/1969) reinstalling sratom [######################] 100%
( 297/1969) reinstalling lilv [######################] 100%
( 298/1969) reinstalling opusfile [######################] 100%
( 299/1969) reinstalling portaudio [######################] 100%
( 300/1969) reinstalling portmidi [######################] 100%
( 301/1969) reinstalling portsmf [######################] 100%
( 302/1969) reinstalling rapidjson [######################] 100%
( 303/1969) reinstalling soundtouch [######################] 100%
( 304/1969) reinstalling suil [######################] 100%
( 305/1969) reinstalling twolame [######################] 100%
( 306/1969) reinstalling libunwind [######################] 100%
( 307/1969) reinstalling gstreamer [######################] 100%
( 308/1969) reinstalling libxv [######################] 100%
( 309/1969) reinstalling orc [######################] 100%
( 310/1969) reinstalling gst-plugins-base-libs [######################] 100%
( 311/1969) reinstalling gssdp [######################] 100%
( 312/1969) reinstalling gupnp [######################] 100%
( 313/1969) reinstalling gupnp-igd [######################] 100%
( 314/1969) reinstalling libnice [######################] 100%
( 315/1969) reinstalling libva [######################] 100%
( 316/1969) reinstalling vulkan-icd-loader [######################] 100%
( 317/1969) reinstalling gst-plugins-bad-libs [######################] 100%
( 318/1969) reinstalling libnotify [######################] 100%
( 319/1969) reinstalling libmspack [######################] 100%
( 320/1969) reinstalling hidapi [######################] 100%
( 321/1969) reinstalling sdl2 [######################] 100%
( 322/1969) reinstalling wxwidgets-common [######################] 100%
( 323/1969) reinstalling wxwidgets-gtk3 [######################] 100%
( 324/1969) reinstalling vamp-plugin-sdk [######################] 100%
( 325/1969) reinstalling wavpack [######################] 100%
( 326/1969) reinstalling audacity [######################] 100%
( 327/1969) reinstalling audacity-docs [######################] 100%
( 328/1969) reinstalling augeas [######################] 100%
( 329/1969) reinstalling m4 [######################] 100%
( 330/1969) reinstalling diffutils [######################] 100%
( 331/1969) reinstalling perl [######################] 100%
( 332/1969) reinstalling autoconf [######################] 100%
( 333/1969) reinstalling automake [######################] 100%
( 334/1969) reinstalling avr-binutils [######################] 100%
( 335/1969) reinstalling libmpc [######################] 100%
( 336/1969) reinstalling libisl [######################] 100%
( 337/1969) reinstalling avr-gcc [######################] 100%
( 338/1969) reinstalling avr-libc [######################] 100%
( 339/1969) reinstalling b43-fwcutter [######################] 100%
( 340/1969) reinstalling kconfig [######################] 100%
( 341/1969) reinstalling kcoreaddons [######################] 100%
( 342/1969) reinstalling kcrash [######################] 100%
( 343/1969) reinstalling kdbusaddons [######################] 100%
( 344/1969) reinstalling libtommath [######################] 100%
( 345/1969) reinstalling convertlit [######################] 100%
( 346/1969) reinstalling libzip [######################] 100%
( 347/1969) reinstalling ebook-tools [######################] 100%
( 348/1969) reinstalling libinih [######################] 100%
( 349/1969) reinstalling exiv2 [######################] 100%
( 350/1969) reinstalling spirv-tools [######################] 100%
( 351/1969) reinstalling glslang [######################] 100%
( 352/1969) reinstalling gsm [######################] 100%
( 353/1969) reinstalling libunibreak [######################] 100%
( 354/1969) reinstalling libass [######################] 100%
( 355/1969) reinstalling libraw1394 [######################] 100%
( 356/1969) reinstalling libavc1394 [######################] 100%
( 357/1969) reinstalling libbluray [######################] 100%
( 358/1969) reinstalling libbs2b [######################] 100%
( 359/1969) reinstalling libdvdread [######################] 100%
( 360/1969) reinstalling libdvdnav [######################] 100%
( 361/1969) reinstalling libiec61883 [######################] 100%
( 362/1969) reinstalling giflib [######################] 100%
( 363/1969) reinstalling gperftools [######################] 100%
( 364/1969) reinstalling highway [######################] 100%
( 365/1969) reinstalling libjxl [######################] 100%
( 366/1969) reinstalling libmodplug [######################] 100%
( 367/1969) reinstalling libasyncns [######################] 100%
( 368/1969) reinstalling libpulse [######################] 100%
( 369/1969) reinstalling libopenmpt [######################] 100%
( 370/1969) reinstalling shaderc [######################] 100%
( 371/1969) reinstalling libdovi [######################] 100%
( 372/1969) reinstalling xxhash [######################] 100%
( 373/1969) reinstalling libplacebo [######################] 100%
( 374/1969) reinstalling libssh [######################] 100%
( 375/1969) reinstalling libtheora [######################] 100%
( 376/1969) reinstalling libvdpau [######################] 100%
( 377/1969) reinstalling libvpx [######################] 100%
( 378/1969) reinstalling libwebp [######################] 100%
( 379/1969) reinstalling ocl-icd [######################] 100%
( 380/1969) reinstalling libvpl [######################] 100%
( 381/1969) reinstalling opencore-amr [######################] 100%
( 382/1969) reinstalling openjpeg2 [######################] 100%
( 383/1969) reinstalling rav1e [######################] 100%
( 384/1969) reinstalling fftw [######################] 100%
( 385/1969) reinstalling rubberband [######################] 100%
( 386/1969) reinstalling snappy [######################] 100%
( 387/1969) reinstalling speexdsp [######################] 100%
( 388/1969) reinstalling speex [######################] 100%
( 389/1969) reinstalling srt [######################] 100%
( 390/1969) reinstalling svt-av1 [######################] 100%
( 391/1969) reinstalling v4l-utils [######################] 100%
( 392/1969) reinstalling zimg [######################] 100%
( 393/1969) reinstalling vapoursynth [######################] 100%
( 394/1969) reinstalling vid.stab [######################] 100%
( 395/1969) reinstalling vmaf [######################] 100%
( 396/1969) reinstalling l-smash [######################] 100%
( 397/1969) reinstalling x264 [######################] 100%
( 398/1969) reinstalling x265 [######################] 100%
( 399/1969) reinstalling xvidcore [######################] 100%
( 400/1969) reinstalling libsodium [######################] 100%
( 401/1969) reinstalling libpgm [######################] 100%
( 402/1969) reinstalling zeromq [######################] 100%
( 403/1969) reinstalling ffmpeg [######################] 100%
( 404/1969) reinstalling karchive [######################] 100%
( 405/1969) reinstalling kcodecs [######################] 100%
( 406/1969) reinstalling ki18n [######################] 100%
( 407/1969) reinstalling nspr [######################] 100%
( 408/1969) reinstalling nss [######################] 100%
( 409/1969) reinstalling poppler [######################] 100%
( 410/1969) reinstalling poppler-qt6 [######################] 100%
( 411/1969) reinstalling taglib [######################] 100%
( 412/1969) reinstalling kfilemetadata [######################] 100%
( 413/1969) reinstalling kidletime [######################] 100%
( 414/1969) reinstalling qt6-svg [######################] 100%
( 415/1969) reinstalling qt6-wayland [######################] 100%
( 416/1969) reinstalling kwindowsystem [######################] 100%
( 417/1969) reinstalling polkit-qt6 [######################] 100%
( 418/1969) reinstalling kauth [######################] 100%
( 419/1969) reinstalling kwidgetsaddons [######################] 100%
( 420/1969) reinstalling kbookmarks [######################] 100%
( 421/1969) reinstalling kguiaddons [######################] 100%
( 422/1969) reinstalling kcolorscheme [######################] 100%
( 423/1969) reinstalling kcompletion [######################] 100%
( 424/1969) reinstalling breeze-icons [######################] 100%
( 425/1969) reinstalling kiconthemes [######################] 100%
( 426/1969) reinstalling kitemviews [######################] 100%
( 427/1969) reinstalling tar [######################] 100%
( 428/1969) reinstalling libtool [######################] 100%
( 429/1969) reinstalling tdb [######################] 100%
( 430/1969) reinstalling sound-theme-freedesktop [######################] 100%
( 431/1969) reinstalling libcanberra [######################] 100%
( 432/1969) reinstalling knotifications [######################] 100%
( 433/1969) reinstalling kjobwidgets [######################] 100%
( 434/1969) reinstalling kservice [######################] 100%
( 435/1969) reinstalling qt6-shadertools [######################] 100%
( 436/1969) reinstalling qt6-5compat [######################] 100%
( 437/1969) reinstalling qca-qt6 [######################] 100%
( 438/1969) reinstalling kwallet [######################] 100%
( 439/1969) reinstalling libxslt [######################] 100%
( 440/1969) reinstalling libplist [######################] 100%
( 441/1969) reinstalling libimobiledevice-glue [######################] 100%
( 442/1969) reinstalling libusbmuxd [######################] 100%
( 443/1969) reinstalling libimobiledevice [######################] 100%
( 444/1969) reinstalling media-player-info [######################] 100%
( 445/1969) reinstalling libatasmart [######################] 100%
( 446/1969) reinstalling libblockdev [######################] 100%
( 447/1969) reinstalling volume_key [######################] 100%
( 448/1969) reinstalling libblockdev-crypto [######################] 100%
( 449/1969) reinstalling libbytesize [######################] 100%
( 450/1969) reinstalling parted [######################] 100%
( 451/1969) reinstalling libblockdev-fs [######################] 100%
( 452/1969) reinstalling mdadm [######################] 100%
( 453/1969) reinstalling libblockdev-mdraid [######################] 100%
( 454/1969) reinstalling libblockdev-loop [######################] 100%
( 455/1969) reinstalling libnvme [######################] 100%
( 456/1969) reinstalling libblockdev-nvme [######################] 100%
( 457/1969) reinstalling libblockdev-part [######################] 100%
( 458/1969) reinstalling libblockdev-swap [######################] 100%
( 459/1969) reinstalling udisks2 [######################] 100%
( 460/1969) reinstalling upower [######################] 100%
( 461/1969) reinstalling solid [######################] 100%
( 462/1969) reinstalling kio [######################] 100%
( 463/1969) reinstalling baloo [######################] 100%
( 464/1969) reinstalling graphene [######################] 100%
( 465/1969) reinstalling gtk4 [######################] 100%
( 466/1969) reinstalling libadwaita [######################] 100%
( 467/1969) reinstalling baobab [######################] 100%
( 468/1969) reinstalling licenses [######################] 100%
( 469/1969) reinstalling manjaro-keyring [######################] 100%
==> Appending keys from manjaro.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signed 2 keys.
==> Importing owner trust values...
( 470/1969) reinstalling systemd-sysvcompat [######################] 100%
( 471/1969) reinstalling iputils [######################] 100%
( 472/1969) reinstalling libmnl [######################] 100%
( 473/1969) reinstalling libnftnl [######################] 100%
( 474/1969) reinstalling libnl [######################] 100%
( 475/1969) reinstalling libpcap [######################] 100%
( 476/1969) reinstalling libnfnetlink [######################] 100%
( 477/1969) reinstalling libnetfilter_conntrack [######################] 100%
( 478/1969) reinstalling jansson [######################] 100%
( 479/1969) reinstalling nftables [######################] 100%
( 480/1969) reinstalling iptables-nft [######################] 100%
( 481/1969) reinstalling libbpf [######################] 100%
( 482/1969) reinstalling iproute2 [######################] 100%
( 483/1969) reinstalling base [######################] 100%
( 484/1969) reinstalling binutils [######################] 100%
( 485/1969) reinstalling bison [######################] 100%
( 486/1969) reinstalling debugedit [######################] 100%
( 487/1969) reinstalling fakeroot [######################] 100%
( 488/1969) reinstalling flex [######################] 100%
( 489/1969) reinstalling gcc [######################] 100%
( 490/1969) reinstalling groff [######################] 100%
( 491/1969) reinstalling gc [######################] 100%
( 492/1969) reinstalling guile [######################] 100%
( 493/1969) reinstalling make [######################] 100%
( 494/1969) reinstalling patch [######################] 100%
( 495/1969) reinstalling pkgconf [######################] 100%
( 496/1969) reinstalling sudo [######################] 100%
( 497/1969) reinstalling texinfo [######################] 100%
( 498/1969) reinstalling which [######################] 100%
( 499/1969) reinstalling base-devel [######################] 100%
( 500/1969) reinstalling bash-completion [######################] 100%
( 501/1969) reinstalling bc [######################] 100%
( 502/1969) reinstalling bcg729 [######################] 100%
( 503/1969) reinstalling bigsh0t [######################] 100%
( 504/1969) reinstalling dnssec-anchors [######################] 100%
( 505/1969) reinstalling libmaxminddb [######################] 100%
( 506/1969) reinstalling libuv [######################] 100%
( 507/1969) reinstalling jemalloc [######################] 100%
( 508/1969) reinstalling liburcu [######################] 100%
( 509/1969) reinstalling bind [######################] 100%
( 510/1969) reinstalling c-ares [######################] 100%
( 511/1969) reinstalling minizip [######################] 100%
( 512/1969) reinstalling electron32 [######################] 100%
( 513/1969) reinstalling libxss [######################] 100%
( 514/1969) reinstalling libnss_nis [######################] 100%
( 515/1969) reinstalling kwidgetsaddons5 [######################] 100%
( 516/1969) reinstalling kconfig5 [######################] 100%
( 517/1969) reinstalling kcoreaddons5 [######################] 100%
( 518/1969) reinstalling polkit-qt5 [######################] 100%
( 519/1969) reinstalling kauth5 [######################] 100%
( 520/1969) reinstalling kcodecs5 [######################] 100%
( 521/1969) reinstalling qt5-x11extras [######################] 100%
( 522/1969) reinstalling qt5-declarative [######################] 100%
( 523/1969) reinstalling qt5-wayland [######################] 100%
( 524/1969) reinstalling kguiaddons5 [######################] 100%
( 525/1969) reinstalling ki18n5 [######################] 100%
( 526/1969) reinstalling kconfigwidgets5 [######################] 100%
( 527/1969) reinstalling kwindowsystem5 [######################] 100%
( 528/1969) reinstalling libdbusmenu-qt5 [######################] 100%
( 529/1969) reinstalling cdparanoia [######################] 100%
( 530/1969) reinstalling gst-plugins-base [######################] 100%
( 531/1969) reinstalling openal [######################] 100%
( 532/1969) reinstalling qt5-multimedia [######################] 100%
( 533/1969) reinstalling qt5-speech [######################] 100%
( 534/1969) reinstalling knotifications5 [######################] 100%
( 535/1969) reinstalling kdbusaddons5 [######################] 100%
( 536/1969) reinstalling kservice5 [######################] 100%
( 537/1969) reinstalling qca-qt5 [######################] 100%
( 538/1969) reinstalling kwallet5 [######################] 100%
( 539/1969) reinstalling openssh [######################] 100%
( 540/1969) reinstalling gcr-4 [######################] 100%
( 541/1969) reinstalling gcr [######################] 100%
( 542/1969) reinstalling gnome-keyring [######################] 100%
( 543/1969) reinstalling bitwarden [######################] 100%
( 544/1969) reinstalling blas [######################] 100%
( 545/1969) reinstalling bluez [######################] 100%
( 546/1969) reinstalling bluez-libs [######################] 100%
( 547/1969) reinstalling libnm [######################] 100%
( 548/1969) reinstalling python-cairo [######################] 100%
( 549/1969) reinstalling libgirepository [######################] 100%
( 550/1969) reinstalling gobject-introspection... [######################] 100%
( 551/1969) reinstalling python-gobject [######################] 100%
( 552/1969) reinstalling blueman [######################] 100%
( 553/1969) reinstalling kpackage [######################] 100%
( 554/1969) reinstalling syndication [######################] 100%
( 555/1969) reinstalling knewstuff [######################] 100%
( 556/1969) reinstalling frameworkintegration [######################] 100%
( 557/1969) reinstalling kconfigwidgets [######################] 100%
( 558/1969) reinstalling kirigami [######################] 100%
( 559/1969) reinstalling kglobalaccel [######################] 100%
( 560/1969) reinstalling kxmlgui [######################] 100%
( 561/1969) reinstalling kcmutils [######################] 100%
( 562/1969) reinstalling kdecoration [######################] 100%
( 563/1969) reinstalling breeze [######################] 100%
( 564/1969) reinstalling solid5 [######################] 100%
( 565/1969) reinstalling kjobwidgets5 [######################] 100%
( 566/1969) reinstalling kglobalaccel5 [######################] 100%
( 567/1969) reinstalling qt5-svg [######################] 100%
( 568/1969) reinstalling karchive5 [######################] 100%
( 569/1969) reinstalling kiconthemes5 [######################] 100%
( 570/1969) reinstalling kitemviews5 [######################] 100%
( 571/1969) reinstalling kxmlgui5 [######################] 100%
( 572/1969) reinstalling kbookmarks5 [######################] 100%
( 573/1969) reinstalling kcompletion5 [######################] 100%
( 574/1969) reinstalling sonnet5 [######################] 100%
( 575/1969) reinstalling ktextwidgets5 [######################] 100%
( 576/1969) reinstalling kcrash5 [######################] 100%
( 577/1969) reinstalling kded5 [######################] 100%
( 578/1969) reinstalling kio5 [######################] 100%
( 579/1969) reinstalling kpackage5 [######################] 100%
( 580/1969) reinstalling syndication5 [######################] 100%
( 581/1969) reinstalling knewstuff5 [######################] 100%
( 582/1969) reinstalling frameworkintegration5 [######################] 100%
( 583/1969) reinstalling qt5-quickcontrols [######################] 100%
( 584/1969) reinstalling qt5-quickcontrols2 [######################] 100%
( 585/1969) reinstalling qt5-graphicaleffects [######################] 100%
( 586/1969) reinstalling kirigami2 [######################] 100%
( 587/1969) reinstalling breeze5 [######################] 100%
( 588/1969) reinstalling python-six [######################] 100%
( 589/1969) reinstalling python-configobj [######################] 100%
( 590/1969) reinstalling python-dulwich [######################] 100%
( 591/1969) reinstalling python-fastbencode [######################] 100%
( 592/1969) reinstalling python-merge3 [######################] 100%
( 593/1969) reinstalling python-patiencediff [######################] 100%
( 594/1969) reinstalling python-tzlocal [######################] 100%
( 595/1969) reinstalling python-yaml [######################] 100%
( 596/1969) reinstalling breezy [######################] 100%
( 597/1969) reinstalling bridge-utils [######################] 100%
( 598/1969) reinstalling btrfs-progs [######################] 100%
( 599/1969) reinstalling bubblewrap [######################] 100%
( 600/1969) reinstalling cairomm [######################] 100%
( 601/1969) reinstalling libsigc++-3.0 [######################] 100%
( 602/1969) reinstalling cairomm-1.16 [######################] 100%
( 603/1969) reinstalling capstone [######################] 100%
( 604/1969) reinstalling python-dbus [######################] 100%
( 605/1969) reinstalling python-ptyprocess [######################] 100%
( 606/1969) reinstalling python-pexpect [######################] 100%
( 607/1969) reinstalling libxfce4util [######################] 100%
( 608/1969) reinstalling xfconf [######################] 100%
( 609/1969) reinstalling catfish [######################] 100%
( 610/1969) reinstalling cblas [######################] 100%
( 611/1969) reinstalling chromaprint [######################] 100%
( 612/1969) reinstalling ttf-liberation [######################] 100%
( 613/1969) reinstalling chromium [######################] 100%
( 614/1969) reinstalling libwbclient [######################] 100%
( 615/1969) reinstalling talloc [######################] 100%
( 616/1969) reinstalling cifs-utils [######################] 100%
( 617/1969) reinstalling ckbcomp [######################] 100%
( 618/1969) reinstalling compiler-rt [######################] 100%
( 619/1969) reinstalling clang [######################] 100%
( 620/1969) reinstalling clazy [######################] 100%
( 621/1969) reinstalling cppdap [######################] 100%
( 622/1969) reinstalling jsoncpp [######################] 100%
( 623/1969) reinstalling rhash [######################] 100%
( 624/1969) reinstalling cmake [######################] 100%
( 625/1969) reinstalling cmatrix [######################] 100%
( 626/1969) reinstalling libgusb [######################] 100%
( 627/1969) reinstalling colord [######################] 100%
( 628/1969) reinstalling composefs [######################] 100%
( 629/1969) reinstalling confuse [######################] 100%
( 630/1969) reinstalling runc [######################] 100%
( 631/1969) reinstalling containerd [######################] 100%
( 632/1969) reinstalling cpio [######################] 100%
( 633/1969) reinstalling python-pygments [######################] 100%
( 634/1969) reinstalling tinyxml2 [######################] 100%
( 635/1969) reinstalling cppcheck [######################] 100%
( 636/1969) reinstalling cpupower [######################] 100%
( 637/1969) reinstalling run-parts [######################] 100%
( 638/1969) reinstalling cronie [######################] 100%
( 639/1969) reinstalling opencl-nvidia [######################] 100%
( 640/1969) reinstalling gcc13-libs [######################] 100%
( 641/1969) reinstalling gcc13 [######################] 100%
( 642/1969) reinstalling cuda [######################] 100%
- When you uninstall an old, unrequired version of GCC that was previously
required by cuda for the default host compiler ($NVCC_CCBIN), you may need
to source /etc/profile or restart your session. Additionally, you may need
to clear the build cache of your projects where the old path may be still
recorded.
( 643/1969) reinstalling libexif [######################] 100%
( 644/1969) reinstalling qpdf [######################] 100%
( 645/1969) reinstalling libcupsfilters [######################] 100%
( 646/1969) reinstalling libppd [######################] 100%
( 647/1969) reinstalling cups-filters [######################] 100%
( 648/1969) reinstalling libpaper [######################] 100%
( 649/1969) reinstalling cups [######################] 100%
( 650/1969) reinstalling jbig2dec [######################] 100%
( 651/1969) reinstalling ijs [######################] 100%
( 652/1969) reinstalling libidn [######################] 100%
( 653/1969) reinstalling poppler-data [######################] 100%
( 654/1969) reinstalling ghostscript [######################] 100%
( 655/1969) reinstalling cups-pdf [######################] 100%
( 656/1969) reinstalling dbus-glib [######################] 100%
( 657/1969) reinstalling i2c-tools [######################] 100%
( 658/1969) reinstalling ddcutil [######################] 100%
( 659/1969) reinstalling distro-info-data [######################] 100%
( 660/1969) reinstalling distro-info [######################] 100%
( 661/1969) reinstalling wget [######################] 100%
( 662/1969) reinstalling debootstrap [######################] 100%
( 663/1969) reinstalling libmicrohttpd [######################] 100%
( 664/1969) reinstalling debuginfod [######################] 100%
( 665/1969) reinstalling dhclient [######################] 100%
( 666/1969) reinstalling dhcpcd [######################] 100%
( 667/1969) reinstalling dialog [######################] 100%
( 668/1969) reinstalling ding-libs [######################] 100%
( 669/1969) reinstalling discord [######################] 100%
( 670/1969) reinstalling discount [######################] 100%
( 671/1969) reinstalling djvulibre [######################] 100%
( 672/1969) reinstalling dkms [######################] 100%
( 673/1969) reinstalling dmidecode [######################] 100%
( 674/1969) reinstalling dmraid [######################] 100%
( 675/1969) reinstalling dnsmasq [######################] 100%
( 676/1969) reinstalling docbook-xml [######################] 100%
( 677/1969) reinstalling docbook-xsl [######################] 100%
( 678/1969) reinstalling docker [######################] 100%
( 679/1969) reinstalling docker-buildx [######################] 100%
( 680/1969) reinstalling dosfstools [######################] 100%
( 681/1969) reinstalling dotconf [######################] 100%
( 682/1969) reinstalling spdlog [######################] 100%
( 683/1969) reinstalling doxygen [######################] 100%
( 684/1969) reinstalling dtc [######################] 100%
( 685/1969) reinstalling libdv [######################] 100%
( 686/1969) reinstalling dvgrab [######################] 100%
( 687/1969) reinstalling potrace [######################] 100%
( 688/1969) reinstalling ffcall [######################] 100%
( 689/1969) reinstalling libyuv [######################] 100%
( 690/1969) reinstalling libavif [######################] 100%
( 691/1969) reinstalling libde265 [######################] 100%
( 692/1969) reinstalling libheif [######################] 100%
( 693/1969) reinstalling gd [######################] 100%
( 694/1969) reinstalling libsigsegv [######################] 100%
( 695/1969) reinstalling libsynctex [######################] 100%
( 696/1969) reinstalling libxaw [######################] 100%
( 697/1969) reinstalling zziplib [######################] 100%
( 698/1969) reinstalling texlive-bin [######################] 100%
( 699/1969) reinstalling woff2 [######################] 100%
( 700/1969) reinstalling dvisvgm [######################] 100%
( 701/1969) reinstalling ecl [######################] 100%
( 702/1969) reinstalling ecryptfs-utils [######################] 100%
( 703/1969) reinstalling ed [######################] 100%
( 704/1969) reinstalling editorconfig-core-c [######################] 100%
( 705/1969) reinstalling edk2-ovmf [######################] 100%
( 706/1969) reinstalling efivar [######################] 100%
( 707/1969) reinstalling efibootmgr [######################] 100%
( 708/1969) reinstalling electron30 [######################] 100%
( 709/1969) reinstalling electron31 [######################] 100%
( 710/1969) reinstalling elementary-icon-theme [######################] 100%
( 711/1969) reinstalling elfutils [######################] 100%
( 712/1969) reinstalling enchant [######################] 100%
( 713/1969) reinstalling unzip [######################] 100%
( 714/1969) reinstalling zip [######################] 100%
( 715/1969) reinstalling engrampa [######################] 100%
( 716/1969) reinstalling gnome-desktop-common [######################] 100%
( 717/1969) reinstalling gnome-desktop [######################] 100%
( 718/1969) reinstalling gsfonts [######################] 100%
( 719/1969) reinstalling gspell [######################] 100%
( 720/1969) reinstalling fuse3 [######################] 100%
( 721/1969) reinstalling libcdio [######################] 100%
( 722/1969) reinstalling libcdio-paranoia [######################] 100%
( 723/1969) reinstalling gvfs [######################] 100%
( 724/1969) reinstalling libgxps [######################] 100%
( 725/1969) reinstalling libhandy [######################] 100%
( 726/1969) reinstalling libspectre [######################] 100%
( 727/1969) reinstalling poppler-glib [######################] 100%
( 728/1969) reinstalling evince [######################] 100%
( 729/1969) reinstalling exfatprogs [######################] 100%
( 730/1969) reinstalling startup-notification [######################] 100%
( 731/1969) reinstalling libgtop [######################] 100%
( 732/1969) reinstalling libxfce4ui [######################] 100%
( 733/1969) reinstalling exo [######################] 100%
( 734/1969) reinstalling extra-cmake-modules [######################] 100%
( 735/1969) reinstalling f2fs-tools [######################] 100%
( 736/1969) reinstalling faac [######################] 100%
( 737/1969) reinstalling faad2 [######################] 100%
( 738/1969) reinstalling libmfx [######################] 100%
( 739/1969) reinstalling ffmpeg4.4 [######################] 100%
( 740/1969) reinstalling ffmpegthumbnailer [######################] 100%
( 741/1969) reinstalling figlet [######################] 100%
( 742/1969) reinstalling mailcap [######################] 100%
( 743/1969) reinstalling noto-fonts [######################] 100%
( 744/1969) reinstalling ttf-dejavu [######################] 100%
( 745/1969) reinstalling ttf-droid [######################] 100%
( 746/1969) reinstalling firefox [######################] 100%
( 747/1969) reinstalling libmalcontent [######################] 100%
( 748/1969) reinstalling ostree [######################] 100%
( 749/1969) reinstalling xdg-dbus-proxy [######################] 100%
( 750/1969) reinstalling libpipewire [######################] 100%
( 751/1969) reinstalling pipewire [######################] 100%
( 752/1969) reinstalling rtkit [######################] 100%
( 753/1969) reinstalling xdg-desktop-portal [######################] 100%
( 754/1969) reinstalling flatpak [######################] 100%
( 755/1969) reinstalling libinstpatch [######################] 100%
( 756/1969) reinstalling fluidsynth [######################] 100%
( 757/1969) reinstalling foomatic-db [######################] 100%
( 758/1969) reinstalling perl-capture-tiny [######################] 100%
( 759/1969) reinstalling perl-ffi-checklib [######################] 100%
( 760/1969) reinstalling perl-file-chdir [######################] 100%
( 761/1969) reinstalling perl-file-which [######################] 100%
( 762/1969) reinstalling perl-path-tiny [######################] 100%
( 763/1969) reinstalling perl-alien-build [######################] 100%
( 764/1969) reinstalling perl-alien-libxml2 [######################] 100%
( 765/1969) reinstalling perl-xml-sax-base [######################] 100%
( 766/1969) reinstalling perl-xml-namespacesupport [######################] 100%
( 767/1969) reinstalling perl-xml-sax [######################] 100%
( 768/1969) reinstalling perl-xml-libxml [######################] 100%
( 769/1969) reinstalling perl-clone [######################] 100%
( 770/1969) reinstalling perl-dbi [######################] 100%
( 771/1969) reinstalling foomatic-db-engine [######################] 100%
( 772/1969) reinstalling foomatic-db-gutenprin... [######################] 100%
( 773/1969) reinstalling foomatic-db-nonfree [######################] 100%
( 774/1969) reinstalling foomatic-db-nonfree-ppds [######################] 100%
( 775/1969) reinstalling foomatic-db-ppds [######################] 100%
( 776/1969) reinstalling freeglut [######################] 100%
( 777/1969) reinstalling imath [######################] 100%
( 778/1969) reinstalling libdeflate [######################] 100%
( 779/1969) reinstalling openexr [######################] 100%
( 780/1969) reinstalling glu [######################] 100%
( 781/1969) reinstalling jasper [######################] 100%
( 782/1969) reinstalling libraw [######################] 100%
( 783/1969) reinstalling jxrlib [######################] 100%
( 784/1969) reinstalling freeimage [######################] 100%
( 785/1969) reinstalling frei0r-plugins [######################] 100%
( 786/1969) reinstalling galculator [######################] 100%
( 787/1969) reinstalling garcon [######################] 100%
( 788/1969) reinstalling gcc-fortran [######################] 100%
( 789/1969) reinstalling libportal [######################] 100%
( 790/1969) reinstalling libportal-gtk3 [######################] 100%
( 791/1969) reinstalling gcolor3 [######################] 100%
( 792/1969) reinstalling gdb-common [######################] 100%
( 793/1969) reinstalling source-highlight [######################] 100%
( 794/1969) reinstalling gdb [######################] 100%
( 795/1969) reinstalling libmm-glib [######################] 100%
( 796/1969) reinstalling geoclue [######################] 100%
( 797/1969) reinstalling numactl [######################] 100%
( 798/1969) reinstalling ghc-libs [######################] 100%
WARNING: settings file doesn't exist "/usr/lib/ghc-9.2.8/lib/settings"
cannot know target platform so guessing target == host (native compiler).
( 799/1969) reinstalling perl-error [######################] 100%
( 800/1969) reinstalling perl-timedate [######################] 100%
( 801/1969) reinstalling perl-mailtools [######################] 100%
( 802/1969) reinstalling git [######################] 100%
( 803/1969) reinstalling gl2ps [######################] 100%
( 804/1969) reinstalling glew [######################] 100%
( 805/1969) reinstalling python-packaging [######################] 100%
( 806/1969) reinstalling glib2-devel [######################] 100%
( 807/1969) reinstalling glibc-locales [######################] 100%
( 808/1969) reinstalling glibmm-2.68 [######################] 100%
( 809/1969) reinstalling glm [######################] 100%
( 810/1969) reinstalling gnome-menus [######################] 100%
( 811/1969) reinstalling gnome-themes-extra [######################] 100%
( 812/1969) reinstalling imlib2 [######################] 100%
( 813/1969) reinstalling libcaca [######################] 100%
( 814/1969) reinstalling libcerf [######################] 100%
( 815/1969) reinstalling lua [######################] 100%
( 816/1969) reinstalling gnuplot [######################] 100%
( 817/1969) reinstalling gnustep-base [######################] 100%
( 818/1969) reinstalling python-markupsafe [######################] 100%
( 819/1969) reinstalling python-mako [######################] 100%
( 820/1969) reinstalling python-markdown [######################] 100%
( 821/1969) reinstalling python-more-itertools [######################] 100%
( 822/1969) reinstalling python-jaraco.functools [######################] 100%
( 823/1969) reinstalling python-jaraco.context [######################] 100%
( 824/1969) reinstalling python-autocommand [######################] 100%
( 825/1969) reinstalling python-jaraco.text [######################] 100%
( 826/1969) reinstalling python-jaraco.collections [######################] 100%
( 827/1969) reinstalling python-platformdirs [######################] 100%
( 828/1969) reinstalling python-wheel [######################] 100%
( 829/1969) reinstalling python-setuptools [######################] 100%
( 830/1969) reinstalling gobject-introspection [######################] 100%
( 831/1969) reinstalling pangomm [######################] 100%
( 832/1969) reinstalling gtkmm3 [######################] 100%
( 833/1969) reinstalling gparted [######################] 100%
( 834/1969) reinstalling gptfdisk [######################] 100%
( 835/1969) reinstalling netpbm [######################] 100%
( 836/1969) reinstalling gts [######################] 100%
( 837/1969) reinstalling graphviz [######################] 100%
( 838/1969) reinstalling grub [######################] 100%
:: To use the new features provided in this GRUB update, it is recommended
to install it to the MBR or UEFI. Due to potential configuration
incompatibilities, it is advised to run both, installation and generation
of configuration:
# UEFI: https://wiki.archlinux.org/title/GRUB#Installation
# BIOS: https://wiki.archlinux.org/title/GRUB#Installation_2
( 839/1969) reinstalling grub-btrfs [######################] 100%
( 840/1969) reinstalling grub-theme-manjaro [######################] 100%
( 841/1969) reinstalling gssproxy [######################] 100%
( 842/1969) reinstalling gst-libav [######################] 100%
( 843/1969) reinstalling libavtp [######################] 100%
( 844/1969) reinstalling libdc1394 [######################] 100%
( 845/1969) reinstalling libdca [######################] 100%
( 846/1969) reinstalling libfdk-aac [######################] 100%
( 847/1969) reinstalling libfreeaptx [######################] 100%
( 848/1969) reinstalling libgme [######################] 100%
( 849/1969) reinstalling liblc3 [######################] 100%
( 850/1969) reinstalling libldac [######################] 100%
( 851/1969) reinstalling raptor [######################] 100%
( 852/1969) reinstalling liblrdf [######################] 100%
( 853/1969) reinstalling libltc [######################] 100%
( 854/1969) reinstalling libmicrodns [######################] 100%
( 855/1969) reinstalling libmpcdec [######################] 100%
( 856/1969) reinstalling libsrtp [######################] 100%
( 857/1969) reinstalling mjpegtools [######################] 100%
( 858/1969) reinstalling neon [######################] 100%
( 859/1969) reinstalling openh264 [######################] 100%
( 860/1969) reinstalling qrencode [######################] 100%
( 861/1969) reinstalling rtmpdump [######################] 100%
( 862/1969) reinstalling sbc [######################] 100%
( 863/1969) reinstalling spandsp [######################] 100%
( 864/1969) reinstalling svt-hevc [######################] 100%
( 865/1969) reinstalling webrtc-audio-processing-1 [######################] 100%
( 866/1969) reinstalling wildmidi [######################] 100%
( 867/1969) reinstalling liblqr [######################] 100%
( 868/1969) reinstalling libraqm [######################] 100%
( 869/1969) reinstalling imagemagick [######################] 100%
( 870/1969) reinstalling zbar [######################] 100%
( 871/1969) reinstalling zvbi [######################] 100%
( 872/1969) reinstalling zxing-cpp [######################] 100%
( 873/1969) reinstalling gst-plugins-bad [######################] 100%
( 874/1969) reinstalling libshout [######################] 100%
( 875/1969) reinstalling gst-plugins-good [######################] 100%
( 876/1969) reinstalling libmpeg2 [######################] 100%
( 877/1969) reinstalling gst-plugins-ugly [######################] 100%
( 878/1969) reinstalling gtk-layer-shell [######################] 100%
( 879/1969) reinstalling gtk-vnc [######################] 100%
( 880/1969) reinstalling gtk2 [######################] 100%
( 881/1969) reinstalling pangomm-2.48 [######################] 100%
( 882/1969) reinstalling gtkmm-4.0 [######################] 100%
( 883/1969) reinstalling gtksourceview3 [######################] 100%
( 884/1969) reinstalling gtksourceview4 [######################] 100%
( 885/1969) reinstalling ufw [######################] 100%
( 886/1969) reinstalling harfbuzz-icu [######################] 100%
( 887/1969) reinstalling hyphen [######################] 100%
( 888/1969) reinstalling libmanette [######################] 100%
( 889/1969) reinstalling libsoup [######################] 100%
( 890/1969) reinstalling webkit2gtk [######################] 100%
( 891/1969) reinstalling gufw [######################] 100%
( 892/1969) reinstalling gumbo-parser [######################] 100%
( 893/1969) reinstalling gutenprint [######################] 100%
>>please run /usr/bin/cups-genppdupdate
>>and restart cups daemon
( 894/1969) reinstalling usbmuxd [######################] 100%
( 895/1969) reinstalling gvfs-afc [######################] 100%
( 896/1969) reinstalling libgphoto2 [######################] 100%
( 897/1969) reinstalling gvfs-gphoto2 [######################] 100%
( 898/1969) reinstalling gvfs-mtp [######################] 100%
( 899/1969) reinstalling libnfs [######################] 100%
( 900/1969) reinstalling gvfs-nfs [######################] 100%
( 901/1969) reinstalling tevent [######################] 100%
( 902/1969) reinstalling ldb [######################] 100%
( 903/1969) reinstalling smbclient [######################] 100%
( 904/1969) reinstalling gvfs-smb [######################] 100%
( 905/1969) reinstalling haskell-base-orphans [######################] 100%
( 906/1969) reinstalling haskell-onetuple [######################] 100%
( 907/1969) reinstalling haskell-erf [######################] 100%
( 908/1969) reinstalling haskell-splitmix [######################] 100%
( 909/1969) reinstalling haskell-random [######################] 100%
( 910/1969) reinstalling haskell-quickcheck [######################] 100%
( 911/1969) reinstalling haskell-data-array-byte [######################] 100%
( 912/1969) reinstalling haskell-ghc-bignum-or... [######################] 100%
( 913/1969) reinstalling haskell-os-string [######################] 100%
( 914/1969) reinstalling haskell-hashable [######################] 100%
( 915/1969) reinstalling haskell-integer-logar... [######################] 100%
( 916/1969) reinstalling haskell-primitive [######################] 100%
( 917/1969) reinstalling haskell-scientific [######################] 100%
( 918/1969) reinstalling haskell-attoparsec [######################] 100%
( 919/1969) reinstalling haskell-base-compat [######################] 100%
( 920/1969) reinstalling haskell-base-compat-b... [######################] 100%
( 921/1969) reinstalling haskell-data-fix [######################] 100%
( 922/1969) reinstalling haskell-dlist [######################] 100%
( 923/1969) reinstalling haskell-generically [######################] 100%
( 924/1969) reinstalling haskell-tagged [######################] 100%
( 925/1969) reinstalling haskell-foldable1-cla... [######################] 100%
( 926/1969) reinstalling haskell-indexed-trave... [######################] 100%
( 927/1969) reinstalling haskell-unordered-con... [######################] 100%
( 928/1969) reinstalling haskell-vector-stream [######################] 100%
( 929/1969) reinstalling haskell-vector [######################] 100%
( 930/1969) reinstalling haskell-indexed-trave... [######################] 100%
( 931/1969) reinstalling haskell-distributive [######################] 100%
( 932/1969) reinstalling haskell-transformers-... [######################] 100%
( 933/1969) reinstalling haskell-comonad [######################] 100%
( 934/1969) reinstalling haskell-th-abstraction [######################] 100%
( 935/1969) reinstalling haskell-bifunctors [######################] 100%
( 936/1969) reinstalling haskell-statevar [######################] 100%
( 937/1969) reinstalling haskell-contravariant [######################] 100%
( 938/1969) reinstalling haskell-semigroupoids [######################] 100%
( 939/1969) reinstalling haskell-assoc [######################] 100%
( 940/1969) reinstalling haskell-these [######################] 100%
( 941/1969) reinstalling haskell-semialign [######################] 100%
( 942/1969) reinstalling haskell-strict [######################] 100%
( 943/1969) reinstalling haskell-text-short [######################] 100%
( 944/1969) reinstalling haskell-time-compat [######################] 100%
( 945/1969) reinstalling haskell-uuid-types [######################] 100%
( 946/1969) reinstalling haskell-witherable [######################] 100%
( 947/1969) reinstalling haskell-aeson [######################] 100%
( 948/1969) reinstalling haskell-attoparsec-aeson [######################] 100%
( 949/1969) reinstalling haskell-cmdargs [######################] 100%
( 950/1969) reinstalling haskell-aeson-pretty [######################] 100%
( 951/1969) reinstalling haskell-colour [######################] 100%
( 952/1969) reinstalling haskell-ansi-terminal... [######################] 100%
( 953/1969) reinstalling haskell-ansi-terminal [######################] 100%
( 954/1969) reinstalling haskell-ansi-wl-pprint [######################] 100%
( 955/1969) reinstalling haskell-appar [######################] 100%
( 956/1969) reinstalling haskell-hourglass [######################] 100%
( 957/1969) reinstalling haskell-basement [######################] 100%
( 958/1969) reinstalling haskell-memory [######################] 100%
( 959/1969) reinstalling haskell-asn1-types [######################] 100%
( 960/1969) reinstalling haskell-asn1-encoding [######################] 100%
( 961/1969) reinstalling haskell-asn1-parse [######################] 100%
( 962/1969) reinstalling haskell-async [######################] 100%
( 963/1969) reinstalling haskell-attoparsec-is... [######################] 100%
( 964/1969) reinstalling haskell-auto-update [######################] 100%
( 965/1969) reinstalling haskell-base-unicode-... [######################] 100%
( 966/1969) reinstalling haskell-base16-bytestring [######################] 100%
( 967/1969) reinstalling haskell-base64 [######################] 100%
( 968/1969) reinstalling haskell-base64-bytestring [######################] 100%
( 969/1969) reinstalling haskell-bitvec [######################] 100%
( 970/1969) reinstalling haskell-blaze-builder [######################] 100%
( 971/1969) reinstalling haskell-blaze-markup [######################] 100%
( 972/1969) reinstalling haskell-blaze-html [######################] 100%
( 973/1969) reinstalling haskell-boring [######################] 100%
( 974/1969) reinstalling haskell-bsb-http-chunked [######################] 100%
( 975/1969) reinstalling haskell-byteorder [######################] 100%
( 976/1969) reinstalling haskell-call-stack [######################] 100%
( 977/1969) reinstalling haskell-case-insensitive [######################] 100%
( 978/1969) reinstalling haskell-only [######################] 100%
( 979/1969) reinstalling haskell-cassava [######################] 100%
( 980/1969) reinstalling haskell-cereal [######################] 100%
( 981/1969) reinstalling haskell-data-default-... [######################] 100%
( 982/1969) reinstalling haskell-data-default-... [######################] 100%
( 983/1969) reinstalling haskell-data-default-... [######################] 100%
( 984/1969) reinstalling haskell-old-locale [######################] 100%
( 985/1969) reinstalling haskell-data-default-... [######################] 100%
( 986/1969) reinstalling haskell-data-default [######################] 100%
( 987/1969) reinstalling haskell-file-embed [######################] 100%
( 988/1969) reinstalling haskell-syb [######################] 100%
( 989/1969) reinstalling haskell-pandoc-types [######################] 100%
( 990/1969) reinstalling haskell-safe [######################] 100%
( 991/1969) reinstalling haskell-text-icu [######################] 100%
( 992/1969) reinstalling haskell-th-lift [######################] 100%
( 993/1969) reinstalling haskell-th-lift-instances [######################] 100%
( 994/1969) reinstalling haskell-unicode-collation [######################] 100%
( 995/1969) reinstalling haskell-uniplate [######################] 100%
( 996/1969) reinstalling haskell-split [######################] 100%
( 997/1969) reinstalling haskell-vector-algorithms [######################] 100%
( 998/1969) reinstalling haskell-mono-traversable [######################] 100%
( 999/1969) reinstalling haskell-unliftio-core [######################] 100%
(1000/1969) reinstalling haskell-resourcet [######################] 100%
(1001/1969) reinstalling haskell-conduit [######################] 100%
(1002/1969) reinstalling haskell-network [######################] 100%
(1003/1969) reinstalling haskell-zlib [######################] 100%
(1004/1969) reinstalling haskell-streaming-commons [######################] 100%
(1005/1969) reinstalling haskell-typed-process [######################] 100%
(1006/1969) reinstalling haskell-conduit-extra [######################] 100%
(1007/1969) reinstalling haskell-xml-types [######################] 100%
(1008/1969) reinstalling haskell-xml-conduit [######################] 100%
(1009/1969) reinstalling haskell-citeproc [######################] 100%
(1010/1969) reinstalling haskell-unicode-data [######################] 100%
(1011/1969) reinstalling haskell-unicode-trans... [######################] 100%
(1012/1969) reinstalling haskell-commonmark [######################] 100%
(1013/1969) reinstalling haskell-emojis [######################] 100%
(1014/1969) reinstalling haskell-th-compat [######################] 100%
(1015/1969) reinstalling haskell-network-uri [######################] 100%
(1016/1969) reinstalling haskell-commonmark-ex... [######################] 100%
(1017/1969) reinstalling haskell-commonmark-pandoc [######################] 100%
(1018/1969) reinstalling haskell-type-equality [######################] 100%
(1019/1969) reinstalling haskell-constraints [######################] 100%
(1020/1969) reinstalling haskell-cookie [######################] 100%
(1021/1969) reinstalling haskell-crypton [######################] 100%
(1022/1969) reinstalling haskell-pem [######################] 100%
(1023/1969) reinstalling haskell-crypton-x509 [######################] 100%
(1024/1969) reinstalling haskell-crypton-x509-... [######################] 100%
(1025/1969) reinstalling haskell-crypton-x509-... [######################] 100%
(1026/1969) reinstalling haskell-crypton-x509-... [######################] 100%
(1027/1969) reinstalling haskell-socks [######################] 100%
(1028/1969) reinstalling haskell-old-time [######################] 100%
(1029/1969) reinstalling haskell-unix-time [######################] 100%
(1030/1969) reinstalling haskell-tls [######################] 100%
(1031/1969) reinstalling haskell-crypton-conne... [######################] 100%
(1032/1969) reinstalling haskell-dec [######################] 100%
(1033/1969) reinstalling haskell-digest [######################] 100%
(1034/1969) reinstalling haskell-digits [######################] 100%
(1035/1969) reinstalling haskell-doclayout [######################] 100%
(1036/1969) reinstalling haskell-text-conversions [######################] 100%
(1037/1969) reinstalling haskell-doctemplates [######################] 100%
(1038/1969) reinstalling haskell-easy-file [######################] 100%
(1039/1969) reinstalling haskell-unix-compat [######################] 100%
(1040/1969) reinstalling haskell-fast-logger [######################] 100%
(1041/1969) reinstalling haskell-glob [######################] 100%
(1042/1969) reinstalling haskell-gridtables [######################] 100%
(1043/1969) reinstalling haskell-haddock-library [######################] 100%
(1044/1969) reinstalling haskell-lua [######################] 100%
(1045/1969) reinstalling haskell-hslua-core [######################] 100%
(1046/1969) reinstalling haskell-hslua-marshalling [######################] 100%
(1047/1969) reinstalling haskell-hslua-aeson [######################] 100%
(1048/1969) reinstalling haskell-hslua-classes [######################] 100%
(1049/1969) reinstalling haskell-hslua-typing [######################] 100%
(1050/1969) reinstalling haskell-hslua-objecto... [######################] 100%
(1051/1969) reinstalling haskell-hslua-packaging [######################] 100%
(1052/1969) reinstalling haskell-hslua [######################] 100%
(1053/1969) reinstalling haskell-hslua-list [######################] 100%
(1054/1969) reinstalling haskell-hslua-module-... [######################] 100%
(1055/1969) reinstalling haskell-hslua-module-path [######################] 100%
(1056/1969) reinstalling haskell-temporary [######################] 100%
(1057/1969) reinstalling haskell-hslua-module-... [######################] 100%
(1058/1969) reinstalling haskell-hslua-module-text [######################] 100%
(1059/1969) reinstalling haskell-hslua-module-... [######################] 100%
(1060/1969) reinstalling haskell-zip-archive [######################] 100%
(1061/1969) reinstalling haskell-hslua-module-zip [######################] 100%
(1062/1969) reinstalling haskell-isocline [######################] 100%
(1063/1969) reinstalling haskell-hslua-repl [######################] 100%
(1064/1969) reinstalling haskell-http-types [######################] 100%
(1065/1969) reinstalling haskell-http-api-data [######################] 100%
(1066/1969) reinstalling haskell-iproute [######################] 100%
(1067/1969) reinstalling haskell-mime-types [######################] 100%
(1068/1969) reinstalling haskell-http-client [######################] 100%
(1069/1969) reinstalling haskell-http-client-tls [######################] 100%
(1070/1969) reinstalling haskell-http-date [######################] 100%
(1071/1969) reinstalling haskell-utf8-string [######################] 100%
(1072/1969) reinstalling haskell-http-media [######################] 100%
(1073/1969) reinstalling haskell-network-byte-... [######################] 100%
(1074/1969) reinstalling haskell-psqueues [######################] 100%
(1075/1969) reinstalling haskell-safe-exceptions [######################] 100%
(1076/1969) reinstalling haskell-unliftio [######################] 100%
(1077/1969) reinstalling haskell-time-manager [######################] 100%
(1078/1969) reinstalling haskell-http2 [######################] 100%
(1079/1969) reinstalling haskell-hunit [######################] 100%
(1080/1969) reinstalling haskell-ipynb [######################] 100%
(1081/1969) reinstalling haskell-jira-wiki-markup [######################] 100%
(1082/1969) reinstalling haskell-juicypixels [######################] 100%
(1083/1969) reinstalling haskell-lexer [######################] 100%
(1084/1969) reinstalling haskell-libyaml [######################] 100%
(1085/1969) reinstalling lua-lpeg [######################] 100%
(1086/1969) reinstalling haskell-lpeg [######################] 100%
(1087/1969) reinstalling haskell-mmorph [######################] 100%
(1088/1969) reinstalling haskell-transformers-base [######################] 100%
(1089/1969) reinstalling haskell-monad-control [######################] 100%
(1090/1969) reinstalling haskell-optparse-appl... [######################] 100%
(1091/1969) reinstalling haskell-ordered-conta... [######################] 100%
(1092/1969) reinstalling haskell-sha [######################] 100%
(1093/1969) reinstalling haskell-pretty-show [######################] 100%
(1094/1969) reinstalling haskell-skylighting-core [######################] 100%
(1095/1969) reinstalling haskell-skylighting-f... [######################] 100%
(1096/1969) reinstalling haskell-skylighting-f... [######################] 100%
(1097/1969) reinstalling haskell-skylighting-f... [######################] 100%
(1098/1969) reinstalling haskell-skylighting-f... [######################] 100%
(1099/1969) reinstalling haskell-skylighting [######################] 100%
(1100/1969) reinstalling haskell-tagsoup [######################] 100%
(1101/1969) reinstalling haskell-typst-symbols [######################] 100%
(1102/1969) reinstalling haskell-xml [######################] 100%
(1103/1969) reinstalling haskell-texmath [######################] 100%
(1104/1969) reinstalling haskell-regex-base [######################] 100%
(1105/1969) reinstalling haskell-regex-tdfa [######################] 100%
(1106/1969) reinstalling haskell-prettyprinter [######################] 100%
(1107/1969) reinstalling haskell-toml-parser [######################] 100%
(1108/1969) reinstalling haskell-yaml [######################] 100%
(1109/1969) reinstalling haskell-typst [######################] 100%
(1110/1969) reinstalling haskell-pandoc [######################] 100%
(1111/1969) reinstalling haskell-pandoc-lua-ma... [######################] 100%
(1112/1969) reinstalling haskell-pandoc-lua-engine [######################] 100%
(1113/1969) reinstalling haskell-sop-core [######################] 100%
(1114/1969) reinstalling haskell-some [######################] 100%
(1115/1969) reinstalling haskell-singleton-bool [######################] 100%
(1116/1969) reinstalling haskell-vault [######################] 100%
(1117/1969) reinstalling haskell-servant [######################] 100%
(1118/1969) reinstalling haskell-wai [######################] 100%
(1119/1969) reinstalling haskell-wai-logger [######################] 100%
(1120/1969) reinstalling haskell-recv [######################] 100%
(1121/1969) reinstalling haskell-simple-sendfile [######################] 100%
(1122/1969) reinstalling haskell-word8 [######################] 100%
(1123/1969) reinstalling haskell-warp [######################] 100%
(1124/1969) reinstalling haskell-wai-extra [######################] 100%
(1125/1969) reinstalling haskell-wai-app-static [######################] 100%
(1126/1969) reinstalling haskell-servant-server [######################] 100%
(1127/1969) reinstalling haskell-wai-cors [######################] 100%
(1128/1969) reinstalling haskell-pandoc-server [######################] 100%
(1129/1969) reinstalling haskell-string-conver... [######################] 100%
(1130/1969) reinstalling haveged [######################] 100%
(1131/1969) reinstalling libaec [######################] 100%
(1132/1969) reinstalling hdf5 [######################] 100%
(1133/1969) reinstalling helvum [######################] 100%
(1134/1969) reinstalling hivex [######################] 100%
(1135/1969) reinstalling hslua-cli [######################] 100%
(1136/1969) reinstalling htop [######################] 100%
(1137/1969) reinstalling http-parser [######################] 100%
(1138/1969) reinstalling hunspell [######################] 100%
(1139/1969) reinstalling hunspell-en_us [######################] 100%
(1140/1969) reinstalling libx86emu [######################] 100%
(1141/1969) reinstalling perl-encode-locale [######################] 100%
(1142/1969) reinstalling perl-http-date [######################] 100%
(1143/1969) reinstalling perl-file-listing [######################] 100%
(1144/1969) reinstalling perl-html-tagset [######################] 100%
(1145/1969) reinstalling perl-io-html [######################] 100%
(1146/1969) reinstalling perl-lwp-mediatypes [######################] 100%
(1147/1969) reinstalling perl-uri [######################] 100%
(1148/1969) reinstalling perl-http-message [######################] 100%
(1149/1969) reinstalling perl-html-parser [######################] 100%
(1150/1969) reinstalling perl-http-cookies [######################] 100%
(1151/1969) reinstalling perl-http-daemon [######################] 100%
(1152/1969) reinstalling perl-http-cookiejar [######################] 100%
(1153/1969) reinstalling perl-http-negotiate [######################] 100%
(1154/1969) reinstalling perl-net-http [######################] 100%
(1155/1969) reinstalling perl-try-tiny [######################] 100%
(1156/1969) reinstalling perl-www-robotrules [######################] 100%
(1157/1969) reinstalling perl-libwww [######################] 100%
(1158/1969) reinstalling perl-xml-parser [######################] 100%
(1159/1969) reinstalling perl-xml-writer [######################] 100%
(1160/1969) reinstalling hwinfo [######################] 100%
(1161/1969) reinstalling hwloc [######################] 100%
(1162/1969) reinstalling hyperfine [######################] 100%
(1163/1969) reinstalling libdbusmenu-glib [######################] 100%
(1164/1969) reinstalling libdbusmenu-gtk3 [######################] 100%
(1165/1969) reinstalling libibus [######################] 100%
(1166/1969) reinstalling ibus [######################] 100%
(1167/1969) reinstalling illyria-wallpaper [######################] 100%
(1168/1969) reinstalling inetutils [######################] 100%
(1169/1969) reinstalling iniparser [######################] 100%
(1170/1969) reinstalling innoextract [######################] 100%
(1171/1969) reinstalling intel-gmmlib [######################] 100%
(1172/1969) reinstalling intel-graphics-compiler [######################] 100%
(1173/1969) reinstalling intel-compute-runtime [######################] 100%
(1174/1969) reinstalling intel-ucode [######################] 100%
(1175/1969) reinstalling inxi [######################] 100%
(1176/1969) reinstalling iw [######################] 100%
(1177/1969) reinstalling java-environment-common [######################] 100%
(1178/1969) reinstalling java-runtime-common [######################] 100%
(1179/1969) reinstalling libnet [######################] 100%
(1180/1969) reinstalling jdk-openjdk [######################] 100%
(1181/1969) reinstalling jdk17-openjdk [######################] 100%
(1182/1969) reinstalling jfsutils [######################] 100%
(1183/1969) reinstalling oniguruma [######################] 100%
(1184/1969) reinstalling jq [######################] 100%
(1185/1969) reinstalling jre8-openjdk-headless [######################] 100%
(1186/1969) reinstalling jre8-openjdk [######################] 100%
(1187/1969) reinstalling signon-kwallet-extension [######################] 100%
(1188/1969) reinstalling signon-plugin-oauth2 [######################] 100%
(1189/1969) reinstalling libxkbfile [######################] 100%
(1190/1969) reinstalling qt6-positioning [######################] 100%
(1191/1969) reinstalling qt6-webchannel [######################] 100%
(1192/1969) reinstalling re2 [######################] 100%
(1193/1969) reinstalling qt6-webengine [######################] 100%
(1194/1969) reinstalling signon-ui [######################] 100%
(1195/1969) reinstalling kaccounts-integration [######################] 100%
(1196/1969) reinstalling kactivitymanagerd [######################] 100%
(1197/1969) reinstalling libutempter [######################] 100%
(1198/1969) reinstalling kpty [######################] 100%
(1199/1969) reinstalling kdesu [######################] 100%
(1200/1969) reinstalling kparts [######################] 100%
(1201/1969) reinstalling kde-cli-tools [######################] 100%
(1202/1969) reinstalling kdeclarative [######################] 100%
(1203/1969) reinstalling kded [######################] 100%
(1204/1969) reinstalling kdegraphics-mobipocket [######################] 100%
(1205/1969) reinstalling knotifyconfig [######################] 100%
(1206/1969) reinstalling qt6-multimedia-ffmpeg [######################] 100%
(1207/1969) reinstalling qt6-multimedia [######################] 100%
(1208/1969) reinstalling qt6-speech [######################] 100%
(1209/1969) reinstalling sonnet [######################] 100%
(1210/1969) reinstalling ktextwidgets [######################] 100%
(1211/1969) reinstalling libebur128 [######################] 100%
(1212/1969) reinstalling mlt [######################] 100%
(1213/1969) reinstalling purpose [######################] 100%
(1214/1969) reinstalling qqc2-desktop-style [######################] 100%
(1215/1969) reinstalling qt6-networkauth [######################] 100%
(1216/1969) reinstalling kdenlive [######################] 100%
(1217/1969) reinstalling kdnssd [######################] 100%
(1218/1969) reinstalling kdoctools5 [######################] 100%
(1219/1969) reinstalling kdsoap-qt6 [######################] 100%
(1220/1969) reinstalling kdsoap-ws-discovery-c... [######################] 100%
(1221/1969) reinstalling kglobalacceld [######################] 100%
(1222/1969) reinstalling kholidays [######################] 100%
(1223/1969) reinstalling ngspice [######################] 100%
(1224/1969) reinstalling tcl [######################] 100%
(1225/1969) reinstalling tk [######################] 100%
(1226/1969) reinstalling onetbb [######################] 100%
(1227/1969) reinstalling pugixml [######################] 100%
(1228/1969) reinstalling vtk [######################] 100%
(1229/1969) reinstalling opencascade [######################] 100%
(1230/1969) reinstalling python-wxpython [######################] 100%
(1231/1969) reinstalling unixodbc [######################] 100%
(1232/1969) reinstalling libgit2 [######################] 100%
(1233/1969) reinstalling kicad [######################] 100%
(1234/1969) reinstalling kicad-library [######################] 100%
(1235/1969) reinstalling kicad-library-3d [######################] 100%
(1236/1969) reinstalling libkexiv2 [######################] 100%
(1237/1969) reinstalling libdvbpsi [######################] 100%
(1238/1969) reinstalling libebml [######################] 100%
(1239/1969) reinstalling libmatroska [######################] 100%
(1240/1969) reinstalling libtar [######################] 100%
(1241/1969) reinstalling libupnp [######################] 100%
(1242/1969) reinstalling libvlc [######################] 100%
(1243/1969) reinstalling vlc [######################] 100%
(1244/1969) reinstalling phonon-qt6-vlc [######################] 100%
(1245/1969) reinstalling phonon-qt6 [######################] 100%
(1246/1969) reinstalling plasma-activities [######################] 100%
(1247/1969) reinstalling syntax-highlighting [######################] 100%
(1248/1969) reinstalling kio-extras [######################] 100%
(1249/1969) reinstalling kio-fuse [######################] 100%
(1250/1969) reinstalling kitemmodels [######################] 100%
(1251/1969) reinstalling ksvg [######################] 100%
(1252/1969) reinstalling kirigami-addons [######################] 100%
(1253/1969) reinstalling kitemmodels5 [######################] 100%
(1254/1969) reinstalling kmenuedit [######################] 100%
(1255/1969) reinstalling kpipewire [######################] 100%
(1256/1969) reinstalling kquickcharts [######################] 100%
(1257/1969) reinstalling krunner [######################] 100%
(1258/1969) reinstalling layer-shell-qt [######################] 100%
(1259/1969) reinstalling libkscreen [######################] 100%
(1260/1969) reinstalling libplasma [######################] 100%
(1261/1969) reinstalling libksysguard [######################] 100%
(1262/1969) reinstalling plasma5support [######################] 100%
(1263/1969) reinstalling qt6-sensors [######################] 100%
(1264/1969) reinstalling kscreen [######################] 100%
(1265/1969) reinstalling kscreenlocker [######################] 100%
(1266/1969) reinstalling kstatusnotifieritem [######################] 100%
(1267/1969) reinstalling ksystemstats [######################] 100%
(1268/1969) reinstalling ktexteditor [######################] 100%
(1269/1969) reinstalling kunitconversion [######################] 100%
(1270/1969) reinstalling kuserfeedback [######################] 100%
(1271/1969) reinstalling kvantum [######################] 100%
(1272/1969) reinstalling kvantum-theme-matcha [######################] 100%
(1273/1969) reinstalling kwayland [######################] 100%
(1274/1969) reinstalling kwayland5 [######################] 100%
(1275/1969) reinstalling libdisplay-info [######################] 100%
(1276/1969) reinstalling libei [######################] 100%
(1277/1969) reinstalling libqaccessibilityclie... [######################] 100%
(1278/1969) reinstalling libxcvt [######################] 100%
(1279/1969) reinstalling libwireplumber [######################] 100%
(1280/1969) reinstalling wireplumber [######################] 100%
(1281/1969) reinstalling qt6-tools [######################] 100%
(1282/1969) reinstalling kwin [######################] 100%
(1283/1969) reinstalling ladspa [######################] 100%
(1284/1969) reinstalling lapack [######################] 100%
(1285/1969) reinstalling less [######################] 100%
(1286/1969) reinstalling lib32-glibc [######################] 100%
(1287/1969) reinstalling lib32-gcc-libs [######################] 100%
(1288/1969) reinstalling lib32-e2fsprogs [######################] 100%
(1289/1969) reinstalling lib32-keyutils [######################] 100%
(1290/1969) reinstalling lib32-openssl [######################] 100%
(1291/1969) reinstalling lib32-libxcrypt [######################] 100%
(1292/1969) reinstalling lib32-libldap [######################] 100%
(1293/1969) reinstalling lib32-krb5 [######################] 100%
(1294/1969) reinstalling lib32-libtirpc [######################] 100%
(1295/1969) reinstalling lib32-libnsl [######################] 100%
(1296/1969) reinstalling lib32-pam [######################] 100%
(1297/1969) reinstalling lib32-libcap [######################] 100%
(1298/1969) reinstalling lib32-libgpg-error [######################] 100%
(1299/1969) reinstalling lib32-libgcrypt [######################] 100%
(1300/1969) reinstalling lib32-xz [######################] 100%
(1301/1969) reinstalling lib32-zstd [######################] 100%
(1302/1969) reinstalling lib32-systemd [######################] 100%
(1303/1969) reinstalling lib32-dbus [######################] 100%
(1304/1969) reinstalling lib32-libffi [######################] 100%
(1305/1969) reinstalling lib32-pcre2 [######################] 100%
(1306/1969) reinstalling lib32-util-linux [######################] 100%
(1307/1969) reinstalling lib32-zlib [######################] 100%
(1308/1969) reinstalling lib32-glib2 [######################] 100%
(1309/1969) reinstalling lib32-libxdmcp [######################] 100%
(1310/1969) reinstalling lib32-libxau [######################] 100%
(1311/1969) reinstalling lib32-libxcb [######################] 100%
(1312/1969) reinstalling lib32-libx11 [######################] 100%
(1313/1969) reinstalling lib32-libxext [######################] 100%
(1314/1969) reinstalling lib32-libxfixes [######################] 100%
(1315/1969) reinstalling lib32-libxi [######################] 100%
(1316/1969) reinstalling lib32-libxtst [######################] 100%
(1317/1969) reinstalling lib32-at-spi2-core [######################] 100%
(1318/1969) reinstalling lib32-brotli [######################] 100%
(1319/1969) reinstalling lib32-bzip2 [######################] 100%
(1320/1969) reinstalling lib32-expat [######################] 100%
(1321/1969) reinstalling lib32-libpng [######################] 100%
(1322/1969) reinstalling lib32-harfbuzz [######################] 100%
(1323/1969) reinstalling lib32-freetype2 [######################] 100%
(1324/1969) reinstalling lib32-fontconfig [######################] 100%
Rebuilding 32-bit fontconfig cache...
(1325/1969) reinstalling lib32-libxrender [######################] 100%
(1326/1969) reinstalling lib32-pixman [######################] 100%
(1327/1969) reinstalling lib32-cairo [######################] 100%
(1328/1969) reinstalling lib32-libjpeg-turbo [######################] 100%
(1329/1969) reinstalling lib32-libtiff [######################] 100%
(1330/1969) reinstalling lib32-lcms2 [######################] 100%
(1331/1969) reinstalling lib32-colord [######################] 100%
(1332/1969) reinstalling lib32-libunistring [######################] 100%
(1333/1969) reinstalling lib32-libidn2 [######################] 100%
(1334/1969) reinstalling lib32-libnghttp2 [######################] 100%
(1335/1969) reinstalling lib32-libnghttp3 [######################] 100%
(1336/1969) reinstalling lib32-libpsl [######################] 100%
(1337/1969) reinstalling lib32-libssh2 [######################] 100%
(1338/1969) reinstalling lib32-curl [######################] 100%
(1339/1969) reinstalling lib32-libpciaccess [######################] 100%
(1340/1969) reinstalling lib32-libdrm [######################] 100%
(1341/1969) reinstalling lib32-json-c [######################] 100%
(1342/1969) reinstalling lib32-libelf [######################] 100%
(1343/1969) reinstalling lib32-libxshmfence [######################] 100%
(1344/1969) reinstalling lib32-libxxf86vm [######################] 100%
(1345/1969) reinstalling lib32-ncurses [######################] 100%
(1346/1969) reinstalling lib32-icu [######################] 100%
(1347/1969) reinstalling lib32-libxml2 [######################] 100%
(1348/1969) reinstalling lib32-llvm-libs [######################] 100%
(1349/1969) reinstalling lib32-lm_sensors [######################] 100%
(1350/1969) reinstalling lib32-wayland [######################] 100%
(1351/1969) reinstalling lib32-mesa [######################] 100%
(1352/1969) reinstalling lib32-nvidia-utils [######################] 100%
xorg configuration symlink valid...
(1353/1969) reinstalling lib32-libglvnd [######################] 100%
(1354/1969) reinstalling lib32-libxrandr [######################] 100%
(1355/1969) reinstalling lib32-freeglut [######################] 100%
(1356/1969) reinstalling lib32-fribidi [######################] 100%
(1357/1969) reinstalling lib32-gdk-pixbuf2 [######################] 100%
(1358/1969) reinstalling lib32-libice [######################] 100%
(1359/1969) reinstalling lib32-libsm [######################] 100%
(1360/1969) reinstalling lib32-libxt [######################] 100%
(1361/1969) reinstalling lib32-libxmu [######################] 100%
(1362/1969) reinstalling lib32-glu [######################] 100%
(1363/1969) reinstalling lib32-glew [######################] 100%
(1364/1969) reinstalling lib32-gmp [######################] 100%
(1365/1969) reinstalling lib32-nettle [######################] 100%
(1366/1969) reinstalling lib32-libtasn1 [######################] 100%
(1367/1969) reinstalling lib32-p11-kit [######################] 100%
(1368/1969) reinstalling lib32-gnutls [######################] 100%
(1369/1969) reinstalling lib32-libcups [######################] 100%
(1370/1969) reinstalling lib32-libepoxy [######################] 100%
(1371/1969) reinstalling lib32-libdatrie [######################] 100%
(1372/1969) reinstalling lib32-libthai [######################] 100%
(1373/1969) reinstalling lib32-libxft [######################] 100%
(1374/1969) reinstalling lib32-pango [######################] 100%
(1375/1969) reinstalling lib32-librsvg [######################] 100%
(1376/1969) reinstalling lib32-libxcomposite [######################] 100%
(1377/1969) reinstalling lib32-libxcursor [######################] 100%
(1378/1969) reinstalling lib32-libxdamage [######################] 100%
(1379/1969) reinstalling lib32-libxinerama [######################] 100%
(1380/1969) reinstalling lib32-libxkbcommon [######################] 100%
(1381/1969) reinstalling lib32-gtk3 [######################] 100%
(1382/1969) reinstalling libdecor [######################] 100%
(1383/1969) reinstalling lib32-libdecor [######################] 100%
(1384/1969) reinstalling lib32-libva [######################] 100%
(1385/1969) reinstalling lib32-libva-intel-driver [######################] 100%
(1386/1969) reinstalling lib32-libvdpau [######################] 100%
(1387/1969) reinstalling lib32-libxkbcommon-x11 [######################] 100%
(1388/1969) reinstalling mesa-demos [######################] 100%
(1389/1969) reinstalling lib32-mesa-demos [######################] 100%
(1390/1969) reinstalling lib32-vulkan-icd-loader [######################] 100%
(1391/1969) reinstalling lib32-xcb-util-keysyms [######################] 100%
(1392/1969) reinstalling vulkan-intel [######################] 100%
(1393/1969) reinstalling lib32-vulkan-intel [######################] 100%
(1394/1969) reinstalling vulkan-radeon [######################] 100%
(1395/1969) reinstalling lib32-vulkan-radeon [######################] 100%
(1396/1969) reinstalling libaio [######################] 100%
(1397/1969) reinstalling libao [######################] 100%
(1398/1969) reinstalling libappindicator-gtk3 [######################] 100%
(1399/1969) reinstalling libburn [######################] 100%
(1400/1969) reinstalling libc++abi [######################] 100%
(1401/1969) reinstalling libc++ [######################] 100%
(1402/1969) reinstalling pcsclite [######################] 100%
(1403/1969) reinstalling libcacard [######################] 100%
(1404/1969) reinstalling libcamera-ipa [######################] 100%
(1405/1969) reinstalling libcamera [######################] 100%
(1406/1969) reinstalling libconfig [######################] 100%
(1407/1969) reinstalling libjuice [######################] 100%
(1408/1969) reinstalling libdatachannel [######################] 100%
(1409/1969) reinstalling libdispatch [######################] 100%
(1410/1969) reinstalling libdmtx [######################] 100%
(1411/1969) reinstalling libdvdcss [######################] 100%
(1412/1969) reinstalling libewf [######################] 100%
(1413/1969) reinstalling libfabric [######################] 100%
(1414/1969) reinstalling xorg-fonts-encodings [######################] 100%
(1415/1969) reinstalling libfontenc [######################] 100%
(1416/1969) reinstalling libfprint [######################] 100%
(1417/1969) reinstalling libftdi [######################] 100%
(1418/1969) reinstalling libgee [######################] 100%
(1419/1969) reinstalling xorg-xkbcomp [######################] 100%
(1420/1969) reinstalling libxklavier [######################] 100%
(1421/1969) reinstalling libgnomekbd [######################] 100%
(1422/1969) reinstalling librest [######################] 100%
(1423/1969) reinstalling libgovirt [######################] 100%
(1424/1969) reinstalling libgsf [######################] 100%
(1425/1969) reinstalling sleuthkit [######################] 100%
(1426/1969) reinstalling libnbd [######################] 100%
(1427/1969) reinstalling libvirt [######################] 100%
warning: directory permissions differ on /var/lib/libvirt/swtpm/
filesystem: 755 package: 711
(1428/1969) reinstalling perl-libintl-perl [######################] 100%
(1429/1969) reinstalling qemu-common [######################] 100%
(1430/1969) reinstalling liburing [######################] 100%
==> For setting up Syslinux BIOS using the syslinux-install_update script follow
https://wiki.archlinux.org/index.php/Syslinux#Automatic_Install
==> For setting up Syslinux EFI follow
https://wiki.archlinux.org/index.php/Syslinux#UEFI_Systems
==> The syslinux-install_update script does not currently support EFI install
(1462/1969) reinstalling vim-runtime [######################] 100%
(1463/1969) reinstalling vim [######################] 100%
(1464/1969) reinstalling xfsprogs [######################] 100%
(1465/1969) reinstalling yara [######################] 100%
(1466/1969) reinstalling libguestfs [######################] 100%
==> Checking for 'os-prober' setup ...
'os-prober' was already disabled by the user.
We don't change those settings.
(1564/1969) reinstalling manjaro-wallpapers-18.0 [######################] 100%
(1565/1969) reinstalling matcha-gtk-theme [######################] 100%
To force Libadwaita appliations to use the gtk-4.0 theme,
symlink the gtk-4.0 theme to config folder
(replace Matcha-dark-sea with chosen theme variant):
mkdir -p ~/.config/gtk-4.0/
ln -sf /usr/share/themes/Matcha-dark-sea/gtk-4.0/{assets,gtk.css,gtk-dark.css} ~/.config/gtk-4.0/
(1566/1969) reinstalling papirus-icon-theme [######################] 100%
(1567/1969) reinstalling papirus-maia-icon-theme [######################] 100%
(1568/1969) reinstalling qt5ct [######################] 100%
(1569/1969) reinstalling xcape [######################] 100%
Theme=manjaro
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
==> Starting build: '6.6.63-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> WARNING: No fsck helpers found. fsck will not be run on boot.
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
error: command failed to execute correctly
(1720/1969) reinstalling polkit-gnome [######################] 100%
(1721/1969) reinstalling postgresql-libs [######################] 100%
( 1/50) Creating system user accounts...
Assertion 'path_is_absolute(p)' failed at src/basic/chase.c:648, function chase(). Aborting.
/usr/share/libalpm/scripts/systemd-hook: line 30: 50678 Aborted (core dumped) /usr/bin/systemd-sysusers
( 2/50) Registering binary formats...
Skipped: Running in chroot.
( 3/50) Updating journal message catalog...
/usr/share/libalpm/scripts/systemd-hook: line 30: 50682 Aborted (core dumped) /usr/bin/journalctl --update-catalog
( 4/50) Reloading system manager configuration...
( 5/50) Reloading user manager configuration...
( 6/50) Updating udev hardware database...
/usr/share/libalpm/scripts/systemd-hook: line 30: 50688 Aborted (core dumped) /usr/bin/systemd-hwdb --usr update
( 7/50) Applying kernel sysctl settings...
( 8/50) Creating temporary files...
/usr/share/libalpm/scripts/systemd-hook: line 30: 50692 Aborted (core dumped) /usr/bin/systemd-tmpfiles --create
( 9/50) Reloading device manager configuration...
(10/50) Arming ConditionNeedsUpdate...
(11/50) Updating the MIME type database...
(12/50) Rebuilding certificate stores...
(13/50) Updating module dependencies...
(14/50) Install DKMS modules
==> ERROR: Missing 6.6.63-1-MANJARO kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing run kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing 6.1.119-1-MANJARO kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing lib64 kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing sbin kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing lib kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing boot kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing etc kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing srv kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing proc kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing 4.19.324-1-MANJARO kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing root kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing lost+found kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing dev kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing var kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing sys kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing home kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing opt kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing rootfs-pkgs.txt kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing usr kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing bin kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing desktopfs-pkgs.txt kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing mnt kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing tmp kernel headers for module v4l2loopback/0.13.2.
==> ERROR: Missing snap kernel headers for module v4l2loopback/0.13.2.
(15/50) Updating TeXLive filename database...
(16/50) Updating TeXLive language files...
(17/50) Updating TeXLive format files...
(18/50) Updating TeXLive font maps...
(19/50) Restarting cronie for libc upgrade...
Running in chroot, ignoring command 'try-restart'
(20/50) Updating ConTeXt database...
(21/50) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
-> -k /boot/vmlinuz-4.19-x86_64 -g /boot/initramfs-4.19-x86_64.img
==> Starting build: '4.19.324-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-4.19-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
-> -k /boot/vmlinuz-4.19-x86_64 -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: '/boot/initramfs-4.19-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
==> Using configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img
==> Starting build: '6.1.119-1-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
(22/50) Updating Kernel initcpios for Nvidia-DRM...
(23/50) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
(24/50) Updating the appstream cache...
? Metadata cache was updated successfully.
(25/50) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(26/50) Restarting accounts-daemon...
(27/50) Reloading system bus configuration...
(28/50) Updating system dconf databases...
(29/50) Warn about old perl modules
(30/50) Copy Firefox Distribution Settings
(31/50) Updating fontconfig cache...
(32/50) Updating 32-bit fontconfig cache...
(33/50) Probing GDK-Pixbuf loader modules...
(34/50) Probing 32-bit GDK-Pixbuf loader modules...
(35/50) Registering Haskell modules...
(36/50) Updating GIO module cache...
(37/50) Compiling GSettings XML schema files...
(38/50) Probing GTK2 input method modules...
(39/50) Probing GTK3 input method modules...
(40/50) Probing 32-bit GTK3 input method modules...
(41/50) Updating icon theme caches...
(42/50) Updating GTK4 module cache...
(43/50) Reloading GVFS config...
(44/50) Creating background picture sym-links for XFCE...
'/usr/share/backgrounds/xfce/illyria-default-lockscreen.jpg' -> '/usr/share/backgrounds/illyria-default-lockscreen.jpg'
'/usr/share/backgrounds/xfce/illyria-default.jpg' -> '/usr/share/backgrounds/illyria-default.jpg'
'/usr/share/backgrounds/xfce/xfce4.jpg' -> '/usr/share/backgrounds/xfce4.jpg'
(45/50) Changing NetworkManager Connectivity-Ping to manjaro.org
(46/50) Configuring pacman-mirrors ...
::INFO => Mirror status: https://repo.manjaro.org/status.json
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
(47/50) Updating the info directory file...
(48/50) Updating the desktop file MIME type cache...
(49/50) Updating the vlc plugin cache...
(50/50) Updating X fontdir indices...
(The process took a while to complete).
P.S.
How can I understand if there are applications that use PackageKit
[manjaro /]# pactree -r packagekit
packagekit
└─packagekit-qt5
[manjaro /]# pacman -Qi packagekit
Version : 1.3.0-1
Description : A system designed to make installation and updates of packages
easier
Architecture : x86_64
URL : https://www.freedesktop.org/software/PackageKit/
Licenses : GPL-2.0-or-later
Groups : None
Provides : None
Depends On : libpackagekit-glib pacman libalpm.so=15-64 polkit sqlite
Optional Deps : bash-completion: command completion in bash [installed]
Required By : packagekit-qt5
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 2.64 MiB
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Sat Sep 14 11:51:47 2024
Install Date : Fri Dec 6 11:26:48 2024
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
cscs
6 December 2024 11:12
8
Berna:
warning: could not get file information
This usually indicates the file is missing on the system.
It can largely be ignored as its being noticed because a file is being installed there.
Berna:
(1/4) Creating Timeshift snapshot before upgrade...
/usr/bin/timeshift-autosnap: line 5: [: too many arguments
/usr/bin/timeshift-autosnap: line 36: [: too many arguments
I dont know about timeshift. But it shouldnt be required to move forward.
Berna:
( 130/1969) reinstalling systemd [######################] 100%
/tmp/alpm_u98qeI/.INSTALL: line 7: 36913 Aborted (core dumped) systemd-sysusers
/tmp/alpm_u98qeI/.INSTALL: line 7: 36914 Aborted (core dumped) journalctl --update-catalog
This is curious. I wonder if it is the product of the chroot?
Berna:
of configuration:
This can be remedied semi automagically with install-grub
Probably from a living system;
sudo pacman -Syu install-grub
sudo install-grub
Berna:
Again … curious. Maybe chroot?
Berna:
This means you dont have the headers for your kernels.
You need those for dkms.
ex;
sudo pacman -Syu $(ls /boot | awk -F "-" '/^linux/ { print $1"-headers" }')
Berna:
4.19?
Thats very old. And its also EOL.
Should be removed.
sudo pacman -Rns $(pacman -Qsq linux419)
PS
That did it.
Besides, it does not matter.
packagekit
for example can be used with discover to manage packages.
But it should never be used. Its buggy and a security hole.
Should be removed.
BG405
6 December 2024 12:04
9
Worth noting that this indicates the .pacnew files haven’t been dealt with in some time:
Berna:
community is up to date
… May not be a direct cause of your present issues but will need attending to.
I expect pacdiff -o
will produce a fairly long list.
Berna
6 December 2024 12:26
10
Report of command that I use now:
[manjaro /]# sudo pacman -Rns $(pacman -Qsq packagekit)
checking dependencies...
:: frameworkintegration5 optionally requires packagekit-qt5: dependency resolving via AppStream
Packages (3) libpackagekit-glib-1.3.0-1 packagekit-1.3.0-1
packagekit-qt5-1.1.2-1
Total Removed Size: 4.87 MiB
:: Do you want to remove these packages? [Y/n]
(1/3) removing packagekit-qt5 [######################] 100%
(2/3) removing packagekit [######################] 100%
(3/3) removing libpackagekit-glib [######################] 100%
(1/3) Reloading system manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Reloading system bus configuration...
next:
[manjaro /]# sudo pacman -Syu $(ls /boot | awk -F "-" '/^linux/ { print $1"-headers" }')
core is up to date
extra is up to date
multilib is up to date
warning: linux419-headers-4.19.324-1 is up to date -- reinstalling
warning: linux61-headers-6.1.119-1 is up to date -- reinstalling
warning: linux66-headers-6.6.63-1 is up to date -- reinstalling
resolving dependencies...
Packages (3) linux419-headers-4.19.324-1 linux61-headers-6.1.119-1
Total Installed Size: 362.94 MiB
Net Upgrade Size: 0.00 MiB
(3/3) checking keys in keyring [######################] 100%
(3/3) checking package integrity [######################] 100%
(3/3) loading package files [######################] 100%
(3/3) checking for file conflicts [######################] 100%
(3/3) checking available disk space [######################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Remove upgraded DKMS modules
==> dkms remove --no-depmod v4l2loopback/0.13.2 -k 6.1.119-1-MANJARO
==> dkms remove --no-depmod v4l2loopback/0.13.2 -k 4.19.324-1-MANJARO
==> dkms remove --no-depmod v4l2loopback/0.13.2 -k 6.6.63-1-MANJARO
(1/3) reinstalling linux419-headers [######################] 100%
(2/3) reinstalling linux61-headers [######################] 100%
(3/3) reinstalling linux66-headers [######################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Install DKMS modules
==> dkms install --no-depmod v4l2loopback/0.13.2 -k 6.6.63-1-MANJARO
==> dkms install --no-depmod v4l2loopback/0.13.2 -k 6.1.119-1-MANJARO
==> dkms install --no-depmod v4l2loopback/0.13.2 -k 4.19.324-1-MANJARO
==> depmod 6.1.119-1-MANJARO
==> depmod 4.19.324-1-MANJARO
==> depmod 6.6.63-1-MANJARO
and next:
core is up to date
extra is up to date
Now I use:
core is up to date
extra is up to date
and:
[manjaro /]# sudo install-grub
WARNING: EFI directory not found! Grub couldn't be installed.
Berna
6 December 2024 12:27
11
I obtain:
[manjaro /]# pacdiff -o
/etc/passwd.pacnew
/etc/shells.pacnew
/etc/locale.gen.pacnew
/etc/default/grub.pacnew
/etc/pam.d/kde.pacnew
/etc/lightdm/lightdm-gtk-greeter.conf.pacnew
/etc/mkinitcpio.conf.pacnew
/etc/pacman.conf.pacnew
/etc/makepkg.conf.d/rust.conf.pacnew
/etc/pacman-mirrors.conf.pacnew
/etc/texmf/web2c/fmtutil.cnf.pacsave
Berna
10 December 2024 23:23
12
Having full disk access via manjaro-chroot -a
I saved all my sensitive files to another computer and reinstalled manjaro from scratch. Thanks everyone for the help.
system
Closed
13 December 2024 23:24
13
