That seems to have stopped GNOME from starting at all. I just have a terminal login prompt now. Trying to revert…
Tried removing the changes but got an error …
Canceled: File is empty
When trying to save (or similar).
I saved it by replacing the changed stuff with a comment like this…
#Comment here
Which then got my DE back up after a reboot so I could look around, then found this…
systemctl revert gdm.service
which is supposed to reset the unit changes properly. After another reboot all is still working and loading up OK (although I had to reset my background wallpaper - odd).
I then tried the concept again with some minor changes following some Google trawling…
[Service]
ExecStartPre=-/bin/sleep 1
The -
is supposed to make it so it doesn’t matter if it fails (so this may just be doing nothing) and I wasn’t sure if the duplication of ExecStart=/usr/bin/gdm
was problematic at all.
It boots, whether I actually effectively achieved anything or not is a completely different question…
Maybe it just slows it down a fraction of a second but long enough to make it work…
If your issue comes up again, please let us know!
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
Tty2 is reserved in gnome. Try TTY3 instead (F3 instead of F2)
