GreenWithEnvy does not start
That is a program to GUI the overclock of nvidia graphic cards. I don't use it, but I keep install it, just in case I want to do it. My graphic card is a gtx 1070ti, kernel 5.3.0-1-MANJARO.
I am on manjaro deepin, testing branch.
I has just tried to open it with no window opening.
So launching it from terminal I got:
~]$ gwe
File "/usr/bin/gwe", line 53, in
from gwe import main
File "/usr/lib/python3.7/site-packages/gwe/main.py", line 28, in
from rx.disposables import CompositeDisposable
ModuleNotFoundError: No module named 'rx.disposables'
:confused:
Installed now and working fine here. I'm on stable branch however
Check if you have installed python-rx and re-install it, it is in the program dependency
Hi @Lolix, thanks for quick answer even is not an urgency post : )
I uninstall it, Pamac also uninstalled gwe.
Then I re-installed python-rx then gwe, but same as before, nothing from grahical launch and from terminal same python error.
Could be using kernel 5.3 or 435.17 nvidia driver related with the problem?
I don't think so, I guess the problem is the update of python-rx
python-rx has been recently updated from v1.6.1 to v3.0.1 https://git.archlinux.org/svntogit/community.git/log/trunk?h=packages/python-rx
and the package is alredy in testing branch [Testing Update] 2019-08-17 - Kernels, Systemd, KDE-Git
@schinfo can you check since you're the packager of gwe, I guess it needs a rebuild
I'm on linux53 and 435 driver for nvidia. I can install GWE and check.
~  gwe                                                         127
  File "/usr/bin/gwe", line 53, in <module>
    from gwe import __main__
  File "/usr/lib/python3.7/site-packages/gwe/__main__.py", line 28, in <module>
There's a problem with the new python3 rx version.
An issue was opened and this is the answer from the programmer.
"I have already ported GWE to RxPY 3.x but I haven't released a new version with it yet.
I guess for now you have to downgrade the python-rx package."
So all we can do for now is to wait for the new release of GWE.
It came to my mind to downgrade the package temporarily, but why risk mess another programs with this updated version as dependency?
I will wait as you suggest @schinfo .
Thanks for contacting the programmer!
:slightly_smiling_face:
I've made an own fix for GWE (use the new code from the programmer).
It also fix the "X-Button Close" problem
(https://gitlab.com/leinardi/gwe/issues/77)
It's available in unstable and testing (0.13.0-0.2)
¡Gracias! Danke! herr @schinfo
Tested, it works, I am returning with it quickly to my testing place from unstable, : )
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
