Is there a simple way to disable the gsd-wacom service?
I’ve been mucking around most of the evening and haven’t been able to come up with a solution, I’ve tried adding ‘X-Gnome-Autostart-Enabler=false’ to the .desktop file in autostart but it doesn’t seem to work.
The only way I have stopped it is by deleting (i made a backup first) the gsd-wacom file in user/lib - I don’ think this is the best solution.
What is the service and file and exact path?
If it is a service you can view i with systemctl status XXXXX.service
Also to see if a package owns a file you can use pacman -Qo /path/to/XXXX
You don’t. gsd-wacom is part of gnome-settings-daemon which is called by gnome-session.
gnome-settings-daemon is a required component of the GNOME desktop, i.e. it is listed in the RequiredComponents field of /usr/share/gnome-session/sessions/gnome.session. It is started in the initialization phase of the session, and gnome-session will restart it if it crashes.
lists nothing to do with gsd-wacom. Even though when I look through the root files I can find gsd-wacom.target and gsd-wacom.service
When looking through all entries for systemctl (I forget the exact command) nothing under gsd-wacom is listed.
i think it might be for nothing though as the next post says you don’t disable… thanks for the tips though with pacman -Qo, I expect it will be owned by one of the packages mentioned by Yochanan.
Thanks I suspected as much. Perhaps then the ‘lighter-gnome’ package is redunant then? Again from memory they allegedly disable housekeeping, wacom, a11y keyboard and a couple of others. I couldn’t help but notice that they had the ‘exec=/usr/lib/gnome-settings/…’ in their .desktop files. This obviously cannot be right as now the services are in /usr/lib/ also this package was made in 2017 suggesting it may be outdated?
Is their perhaps a way I could write a script to kill the process when I login? Or is it recommended to just leave it alone?
I forgot about lighter-gnome. Yes, it is outdated as the paths have changed.
EDIT: Just updated it, the paths are fixed now with 20211216-1.
That’s my advice. However if you want to tinker:
You can accomplish the same thing that lighter-gnome does by copying the desktop file from the system autostart folder to your user autostart folder and adding X-GNOME-Autostart-enabled=false to the end of it (as long as that still works):
cp /etc/xdg/autostart/org.gnome.SettingsDaemon.Wacom.desktop ~/.config/autostart/
sed -i -e '$aX-GNOME-Autostart-enabled=false' ~/.config/autostart/org.gnome.SettingsDaemon.Wacom.desktop
