Hey all, recently updated my computer running Manjaro 20.1.2 to the latest version(20.2), and I immediately began having problems with the graphics flickering/tearing. Never had this problem before, so I decided to try a clean install to see if it was an issue with the update process but unfortunately still the same issue. I tried to include a photo example or link but it’s not allowed apparently. Any help would be appreciated, thanks so much
System -
Asrock J5005 motherboard
Intel 605 integrated graphics over HDMI
8gb ddr
Hisense 4k 50" TV
Output of inxi -Fza --no-host
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=ce266562-5461-4f3f-b724-4cfe65166558 rw quiet apparmor=1
Console: tty 2 DM: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: J5005-ITX serial: <filter>
UEFI: American Megatrends v: L1.99 date: 01/21/2020
Device-1: hidpp_battery_0
model: Logitech Wireless Touch Keyboard K400 serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
Info: Quad Core model: Intel Pentium Silver J5005 bits: 64
type: MCP arch: Goldmont Plus family: 6 model-id: 7A (122)
stepping: 1 microcode: 34 L2 cache: 4 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 11984
Speed: 1314 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 1314
2: 2137 3: 799 4: 974
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user
pointer sanitization
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Device-1: Intel UHD Graphics 605 vendor: ASRock driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3184
Display: server: X.org 1.20.10 driver: intel unloaded: modesetting
alternate: fbdev,vesa tty: 72x46
Message: Advanced graphics data unavailable in console. Try -G
--display
Device-1: Intel Celeron/Pentium Silver Processor High Definition
Audio
vendor: ASRock driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:0e.0
chip ID: 8086:3198
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: ASRock driver: r8169 v: kernel port: e000 bus ID: 03:00.0
chip ID: 10ec:8168
Local Storage: total: 7.72 TiB used: 7.4 GiB (0.1%)
SMART Message: Required tool smartctl not installed. Check
--recommends
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD80EDAZ-11TA3A0 size: 7.28 TiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 0A81
ID-2: /dev/sdb maj-min: 8:16 vendor: PNY model: CS900 240GB SSD
size: 223.57 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 0613
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk
model: Ultra Fit size: 233.25 GiB block size: physical: 512 B
logical: 512 B serial: <filter> rev: 1.00
ID-1: / raw size: 223.27 GiB size: 218.77 GiB (97.98%)
used: 7.4 GiB (3.4%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 176 Uptime: 33m wakeups: 3 Memory: 7.43 GiB
used: 1.09 GiB (14.7%) Init: systemd v: 247 Compilers: gcc: N/A
Packages: pacman: 1120 lib: 367 flatpak: 0 Shell: Bash v: 5.1.0
running in: tty 2 (SSH) inxi: 3.2.01
