After several reinstalling Manjaro Gnome on my acer swift sf114-32, I still get this weird screen glitching from time to time. After one or two restarts it’s disappearing. Does anybody know what could cause this?
I think it could have something to do with the Manjaro splash screen.
It looks like this: https:// imgur. com/a/T6l5TGA
Can you post some hardware info ?
inxi -Fza
on console.
Kernel: 5.15.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=c6f8f65b-a9cd-4049-80fb-43cf3b6a5cd0 rw quiet
cryptdevice=UUID=f2544a74-69ea-4235-b922-c6c286cee681:luks-f2544a74-69ea-4235-b922-c6c286cee681
root=/dev/mapper/luks-f2544a74-69ea-4235-b922-c6c286cee681 splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-9c569be3-769d-4e17-890c-0553de802e42
udev.log_priority=3
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Acer product: Swift SF114-32 v: V1.15
serial: <superuser required>
Mobo: GLK model: Sapporo_GL v: V1.15 serial: <superuser required>
UEFI: Insyde v: 1.15 date: 11/03/2020
ID-1: BAT0 charge: 37.8 Wh (82.0%) condition: 46.1/54.2 Wh (85.1%)
volts: 12.0 min: 11.6 model: PANASONIC AP15O5L type: Li-ion
serial: <filter> status: discharging
Info: model: Intel Pentium Silver N5000 bits: 64 type: MCP
arch: Goldmont Plus built: 2017 process: Intel 14nm family: 6
model-id: 0x7A (122) stepping: 1 microcode: 0x3A
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2579 high: 2587 min/max: 800/2700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2586 2: 2566 3: 2587
4: 2580 bogomips: 8756
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel GeminiLake [UHD Graphics 605] vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3184
class-ID: 0300
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 04f2:b5c5 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x403d built: 2017 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 605 (GLK 3) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0403
Sound Server-1: ALSA v: k5.15.46-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
IF: wlp0s12f0 state: up mac: <filter>
IF-ID-1: notebook state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-9:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 223.57 GiB used: 19.38 GiB (8.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400M8240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 66.5 scheme: GPT
ID-1: / raw-size: 215.27 GiB size: 210.83 GiB (97.94%)
used: 19.37 GiB (9.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-f2544a74-69ea-4235-b922-c6c286cee681
used: 440 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8 GiB used: 3.5 MiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-9c569be3-769d-4e17-890c-0553de802e42
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 245 Uptime: 52m wakeups: 2 Memory: 3.64 GiB
used: 2.26 GiB (62.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1590
pacman: 1579 lib: 456 flatpak: 11 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.17
Can you post /var/log/Xorg.0.log
I think I don’t have a Xorg.0.log file (neither in $HOME/.local/share/xorg or /var/log)
