Graphical glitches and file thumbnails not rendering correctly
Hi i switched from pop os to manjaro and its a pretty nice experience so far. However theres graphical glitches throughout the ui whenever i try to scroll down too much. I have a suspicion this might be due to the drivers but i have ensured that nvidia-dkms 470.xxx is installed[my gpu is a gt 710]. Also all thumbnails for files like pdfs, images, and mp3 dont load and instead there is a blank space. Even the icons dont show
Welcome to the Manjaro community.
I’m sure someone will help with your issue when they are able.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
Well, 'GT 710` gives us a general idea of how old your system must be to support this card; however, some system information (as requested by @scotty65 ) will likely help.
Aside:- I had a few of these cards at one time; they were relatively cheap and just what was needed for a few machines I once had; though I’m uncertain how well they would fair generally now.
Hi and welcome,
This would seem to indicate you have done something abnormal and outside of usual support as video drivers are normally handled via mhwd, in your case profile video-nvidia-470xx, and would have garnered you a package like linux612-nvidia-470xx, not nvidia-470xx-dkms.
I would still suggest you provide us with an inxi
inxi -Farz
and we might as well ask for mhwd output while we are here
mhwd -li -l
But I am rather confident we will be advising you to undo what you have already done in regards to nvidia - that is remove any associated packages and/or configuration files and instead use
sudo mhwd -i pci video-nvidia-470xx
assuming of course that 470 is the correct series and that this is not a hybrid system.
This is the output of the command you requested
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=d31c4732-6551-4003-9684-fbe3ed012689 rw quiet splash apparmor=1
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Desktop System: Acidanthera product: iMac13,2 v: 1.0
serial: <superuser required> Chassis: type: 13 v: Mac-FC02E91DDD3FA6A4
Mobo: Acidanthera model: Mac-FC02E91DDD3FA6A4 v: iMac13,2
serial: <superuser required> uuid: <superuser required> UEFI: Acidanthera
v: 429.0.0.0.0 date: 03/18/2022
System RAM: total: 8 GiB available: 7.71 GiB used: 2.24 GiB (29.0%)
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Hynix/Hyundai part-no: DMT451E6AFR8C-PB serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
manufacturer: Kingston part-no: 99U5471-012.A00LF serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i5-3570 bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3800 min/max: 1600/3800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 3800 2: 3800 3: 3800 4: 3800 bogomips: 27149
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmovconstant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
disabled
STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ZOTAC driver: nvidia
v: 470.256.02 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Fermi-2 code: GF119/GK208
process: TSMC 28nm built: 2010-2016 pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: lanes: 8 ports: active: none off: HDMI-A-1 empty: DVI-D-1,VGA-1
bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
Device-2: Lenovo FHD Webcam Audio driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.3:4
chip-ID: 17ef:4831 class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch note: X driver n/a, try sudo/root
display-ID: :0 note: <missing: xdpyinfo/xrandr>
Monitor-1: HDMI-A-1 model: Dell D1918H serial: <filter> built: 2021
res: 1366x768 dpi: 85 gamma: 1.2 chroma: red: x: 0.635 y: 0.341 green:x: 0.329 y: 0.627 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9
modes: 1366x768, 1920x1080, 1280x1024, 1280x720, 1024x768, 800x600,
720x576, 720x480, 640x480
Monitor-2: Unknown-1 size-res: N/A modes: 800x600
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: swrast x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.256.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 710/PCIe/SSE2
memory: 1.95 GiB
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Device-3: Zoran Personal Media Division (Nogatech) USB Audio and HID
driver: snd-usb-audio type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 1-1.5:5 chip-ID: 0573:1573 class-ID: 0300 serial: <filter>
Device-4: Lenovo FHD Webcam Audio driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
chip-ID: 10ec:8136 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth:Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.2:3 chip-ID: 2357:0604
Local Storage: total: 1.14 TiB used: 33.09 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR313 temp: 29.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: EVM model: 256GB SSD size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD
serial: <filter> fw-rev: 0A0 scheme: GPT
ID-1: / raw-size: 238.18 GiB size: 233.38 GiB (97.99%)
used: 33.09 GiB (14.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: d31c4732-6551-4003-9684-fbe3ed012689
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: D342-65DA
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 200 MiB fs: vfat label: EFI
uuid: 67E3-17ED
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 683.04 GiB fs: apfs label: N/A
uuid: 75feb81c-e3ff-4a52-a82a-4ed41ec58bc7
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 248.28 GiB fs: apfs label: N/A
uuid: a9f71e6b-1129-4011-98d1-bfb5620ae42d
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
class-ID: 0900Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.1:3 info: INSTANT USB GAMING MOUSE type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 30fa:1440 class-ID: 0300
Device-2: 1-1.3:4 info: CASUE USB KB type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 300mA chip-ID: 2a7a:9007 class-ID: 0300
Device-3: 1-1.5:5 info: Zoran Personal Media Division (Nogatech) USB Audio
and HID type: audio,HID driver: snd-usb-audio interfaces: 4 rev: 2.0
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
Device-1: 2-1.2:3 info: TP-Link UB500 Adapter type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Device-2: 2-1.3:4 info: Lenovo FHD Webcam Audio type: video,audio
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 50%
Packages: 1256 pm: pacman pkgs: 1249 libs: 329
tools: gnome-software,pamac,yay pm: flatpak pkgs: 7
1: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
2: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
3: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 237
1: cpu: 28.7% command: firefox pid: 1526 mem: 719.9 MiB (9.1%)
2: cpu: 16.0% command: deja-dup pid: 2888 mem: 85.9 MiB (1.0%)
3: cpu: 9.8% command: firefox pid: 2125 mem: 240.8 MiB (3.0%)
4: cpu: 8.2% command: gnome-shell pid: 931 mem: 314.0 MiB (3.9%)5: cpu: 5.1% command: firefox pid: 2050 mem: 206.3 MiB (2.6%)
Memory top: 5 of 237
1: mem: 719.9 MiB (9.1%) command: firefox pid: 1526 cpu: 28.7%
2: mem: 314.0 MiB (3.9%) command: gnome-shell pid: 931 cpu: 8.2%
3: mem: 296.7 MiB (3.7%) command: firefox pid: 2142 cpu: 5.0%
4: mem: 240.8 MiB (3.0%) command: firefox pid: 2125 cpu: 9.8%
5: mem: 206.3 MiB (2.6%) command: firefox pid: 2050 cpu: 5.1%
Processes: 237 Power: uptime: 2m states: freeze,standby,mem,disk
suspend: s2idle avail: shallow wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 3.06 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.36
Also the name of the system shown is iMac13,2 is because i dualboot macos(hackintosh) and linux
mhwd -li -l
> Installed PCI configs:
    video-nvidia-470xx            2023.03.23               false            PCI
> 0000:01:00.0 (0300:10de:128b) Display controller nVidia Corporation:
    video-nvidia-390xx            2023.03.23               false            PCI
           video-linux            2024.05.06                true            PCI
also i did not install any drivers. I was wrong in my terminology. I simply meant that i had ensured the drivers are installed.
Yes, I maintain an iMac20,1 with Sequoia, myself.
However, your actual mainboard details might be beneficial for those wishing to help.
It is a local no name brand and i believe the chipset is h61
Unfortunate.
The actual brand and model number might have been useful to find any available BIOS updates and/or research other known contributing factors with the same hardware combination.
i have searched but there are no bios updates available. Also i am pretty sure this is not due to the mobo as pop os, ubuntu and fedora ran fine
I didn’t suggest it was.
Generally, the more information that is known, the better; and many things can potentially contribute to a given issue.
All I can say with any certainty right now is that the `video-nvidia-470xx’ series drivers mentioned earlier should be suitable for your Nvidia GT 710.
Yes, but that doesnt solve my issue.
No, it doesn’t.
However, it does confirm the driver should work with your GT 710; unless you find that to be useless information.
Beyond that, I’ll simply wish you luck. :vulcan_salute:
