Hi all
recently (maybe past 2-3 weeks) whenever I come back to my locked PC after a brief absence I find the password box does not initially display on the lock screen - the mouse cursor happily swims around
I previously learned the TTY Console trick and use Ctrl+Alt+F2 then switch instantly back to desktop with Ctrl+Alt+F1 and then it does display the login password, and I unlock and everything works.
On rare occasions I find the PC seems to have rebooted and all my opened apps were closed
Any suggestions/explanations most appreciated
Thanks
System: Kernel: 5.4.57-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=f207a1c4-dc91-4716-921a-8d8d983f7cc1 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Intel model: NUC5i5RYB v: H40999-504 serial: <filter> UEFI: Intel
v: RYBDWi35.86A.0350.2015.0812.1722 date: 08/12/2015
Battery: Device-1: hidpp_battery_0 model: Logitech K800 serial: <filter> charge: 70% (should be ignored) rechargeable: yes
status: Discharging
Memory: RAM: total: 15.53 GiB used: 9.01 GiB (58.0%)
CPU: Topology: Dual Core model: Intel Core i5-5250U bits: 64 type: MT MCP arch: Broadwell family: 6 model-id: 3D (61)
stepping: 4 microcode: 2F L2 cache: 3072 KiB bogomips: 12779
Speed: 881 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 881 2: 850 3: 876 4: 824
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 6000 driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:1626
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 96 size: 510x290mm (20.1x11.4") diag: 587mm (23.1")
OpenGL: renderer: Mesa Intel HD Graphics 6000 (BDW GT3) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Intel Broadwell-U Audio driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:9ca0
Device-3: ARC Camera type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-4.2:5 chip ID: 05a3:9331 serial: <filter>
Sound Server: ALSA v: k5.4.57-1-MANJARO
Network: Device-1: Intel Ethernet I218-V driver: e1000e v: 3.2.6-k port: 3080 bus ID: 00:19.0 chip ID: 8086:15a3
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3040 bus ID: 02:00.0 chip ID: 8086:095a
IF: wlp2s0 state: down mac: <filter>
Drives: Local Storage: total: 3.87 TiB used: 139.37 GiB (3.5%)
ID-1: /dev/sda vendor: Crucial model: CT250MX200SSD4 size: 232.89 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: MU02 scheme: GPT
ID-2: /dev/sdb type: USB vendor: Toshiba model: External USB 3.0 size: 3.64 TiB block size: physical: 4096 B
logical: 512 B serial: <filter> rev: 5438 scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 97.66 GiB size: 95.12 GiB (97.41%) used: 36.78 GiB (38.7%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: f207a1c4-dc91-4716-921a-8d8d983f7cc1
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1
label: N/A uuid: C94B-408A
ID-3: /home raw size: 134.93 GiB size: 131.82 GiB (97.69%) used: 75.58 GiB (57.3%) fs: ext4 dev: /dev/sda3
label: DATA uuid: 29456bd3-f500-4071-9ab1-aed88f8436aa
ID-4: /home/<filter>/onedrive-mount raw size: N/A size: 100.00 GiB used: 27.01 GiB (27.0%) fs: fuse.rclone
source: ERR-102 label: N/A uuid: N/A
ID-5: /run/timeshift/backup raw size: 134.93 GiB size: <superuser/root required> used: <superuser/root required>
fs: ext4 dev: /dev/sda3 label: DATA uuid: 29456bd3-f500-4071-9ab1-aed88f8436aa
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/sdb1 size: 128.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-2: /dev/sdb2 size: 3.64 TiB fs: ntfs label: TOSHIBA EXT uuid: B21E14AB1E146A9D
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-4:3 info: VIA Labs VL812 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 2109:2812
Device-1: 1-4.2:5 info: ARC Camera type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s chip ID: 05a3:9331 serial: <filter>
Device-2: 1-4.3:6 info: MosArt Wireless Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1
speed: 12 Mb/s chip ID: 062a:4102
Device-3: 1-4.4:7 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c52b
Device-4: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:0a2a
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8001
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Device-1: 3-3:3 info: Toshiba America MQ04UBF100 type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0
speed: 5 Gb/s chip ID: 0480:0900 serial: <filter>
Hub: 3-4:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 2109:0812
Sensors: System Temperatures: cpu: 47.0 C mobo: 29.8 C
Info: Processes: 306 Uptime: 7d 19h 53m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1405 pacman: 1401 lib: 402
flatpak: 0 snap: 4 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
