Today i installed the standard version of Manjaro < manjaro-kde-26.1.0-260812-linux71 > and i found 2 errors . 1) the display with the Screen Brightness at 100% was very dark. If i move the cursor lower, the display coming to normal. 2) No wifi. WHY ?
The darkness is a known bug in some systems but honestly i have forgotten the details. Make sure to change the kernel, since 7.1. is EOL anyway - i think this got fixed somewhere in the newer kernels.
Generally we have the principle of one problem pro topic, but about the darkness there is not much you can do besides going to kernel 6.18, or 7.2 or 7.3, so there is not much to discuss and i guess we can concentrate on the wifi problem.
For the wifi you have to provide info, at least inxi and lspci:
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
- man inxi (The
inximanual)
Command output should be presented as pre-formatted text in accordance with forum guidelines. ![]()
- Add
--color=0to the long-form command, or… - Change the short-form command to
inxi -zv8c0
Your privacy is respected
Note: Grave accent (or, backtick) characters are used. ![]()
- please follow this simple example:
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
Actually changing the kernel is also the first troubleshooting step for the wifi too, if the card is too new maybe there is a driver or fix in the newest kernels.
Hello and welcome to the Manjaro Community @sordelflor! ![]()
It does look like we could do with another Manjaro .ISO. IMHO it would be better to stick with LTS kernels on the releases.
@philm
I should note that, as per Forum practice, it is always advised to post some essential System Information, to give us a better starting point for finding the issue(s). To that end:
Please open a terminal and enter
inxi -zv8
Copy the entire output and paste here.
Note that the output produced by this command is privacy-filtered.
Please also remember to use proper code formatting as this makes it much easier to read on the Forum:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks
or three tildes
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
Cheers! ![]()
