Hi,
I’m receiving hotspot login popoup with 404 status each time my computer connects to wifi network, I’ve figured out that it is caused by gnome-shell-portal-helper. Modifying NetworkManager configuration doesn’t help with that issue. Is there any resolution for that issue?
Hi and welcome to the forum
I don’t use wifi and I can’t check right now, a quick search leads me here with this solution:
Go to Settings/Privacy and turn off Network connectivity checking
The post links to a more elaborate explanation of this behavior. If the option does not exist more searching with the keyword gnome-shell-portal-helper
could yield more results.
What did you modify? See Can i safely disable NetworkManager connectivity check?
This is Manjaro, not Ubuntu. They used to use a patch (<=21.10) to add that feature.
I was trying to switch url for connectivity verification with following entries
[connectivity]
#uri=http://ping.manjaro.org/check_network_status.txt
uri=http://nmcheck.gnome.org/check_network_status.txt
in /lib/NetworkManager/conf.d/20-connectivity.conf and /etc/NetworkManager/conf.d/20-connectivity.conf but there were no difference. After greping my / directory I found out that the url with 404 response is hardcoded directly in /lib/gnome-shell-portal-helper file
Do not edit /usr/lib/NetworkManager/conf.d/20-connectivity.conf
, edit /etc/NetworkManager/conf.d/20-connectivity.conf
instead. The latter will override the former.
I’ve modified also that file. URL with 404 response is hardcoded directly in gnome-shell-portal-helper and I think that it doesn’t respect any configuration.
@andrescaroc I haven’t solved that
I guess that the easiest way of resolving that would be disabling gnome-shell-portal-helper from checking Internet access but I’ve no time to find way of doing that.
Is there no solution yet? Would chattr +i on the conf files do it?
