I have some errors in my journal from booting. System looks ok, no problems, but not sure why they are there and how to fix them…
Errors:
Oct 24 17:07:05 am5manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7._PRW], AE_ALREADY_EXISTS (20220331/dswload2-326)
Oct 24 17:07:05 am5manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
Oct 24 17:07:05 am5manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP2._PRW], AE_ALREADY_EXISTS (20220331/dswload2-326)
Oct 24 17:07:05 am5manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_GPE._L08], AE_ALREADY_EXISTS (20220331/dswload2-326)
Oct 24 17:07:05 am5manjaro kernel: hub 10-0:1.0: config failed, hub doesn't have any ports! (err -19)
Oct 24 17:07:05 am5manjaro kernel: nouveau 0000:01:00.0: unknown chipset (193000a1)
Oct 24 17:07:06 am5manjaro bluetoothd[875]: Failed to set mode: Failed (0x03)
Oct 24 17:07:27 am5manjaro bluetoothd[875]: Failed to set mode: Failed (0x03)
Oct 24 20:14:15 am5manjaro pulseaudio[1653]: Error opening PCM device iec958:0: No such file or directory
inxi -F
Host: am5manjaro Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.8 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: X670E AORUS MASTER v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X670E AORUS MASTER serial: <superuser required>
UEFI: American Megatrends LLC. v: F12 date: 07/10/2023
Info: 16-core model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP cache:
L2: 16 MiB
Speed (MHz): avg: 3094 min/max: 3000/5759 cores: 1: 3557 2: 2884 3: 2882
4: 3000 5: 3000 6: 4200 7: 3000 8: 3000 9: 2828 10: 3000 11: 2879 12: 2862
13: 2863 14: 4844 15: 2874 16: 2846 17: 3640 18: 3000 19: 2883 20: 3000
21: 3000 22: 3000 23: 2882 24: 3000 25: 3000 26: 2786 27: 2822 28: 2882
29: 3000 30: 3595 31: 3000 32: 3000
Device-1: NVIDIA AD103 [GeForce RTX 4080] driver: vfio-pci v: N/A
Device-2: AMD Raphael driver: amdgpu v: kernel
Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1 driver: X:
loaded: amdgpu unloaded: modesetting dri: radeonsi gpu: amdgpu resolution:
1: 1080x1920~60Hz 2: 2560x1440~60Hz
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
renderer: AMD Radeon Graphics (raphael_mendocino LLVM 16.0.6 DRM 3.49
6.1.55-1-MANJARO)
API: Vulkan v: 1.3.264 drivers: radv surfaces: xcb,xlib
Device-1: NVIDIA driver: vfio-pci
Device-2: Creative Sound Blaster X5
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB
type: USB
API: ALSA v: k6.1.55-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
Device-1: Intel Ethernet I225-V driver: igc
IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: 74:56:3c:4b:74:7e
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
IF: wlp14s0 state: down mac: 8e:7e:86:7a:04:30
IF-ID-1: virbr0 state: down mac: 52:54:00:88:a1:68
Device-1: Intel AX210 Bluetooth driver: btusb type: USB
Local Storage: total: 5.52 TiB used: 1.12 TiB (20.2%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SKC3000D2048G size: 1.86 TiB
ID-2: /dev/nvme1n1 vendor: Seagate model: XPG GAMMIX S50 Lite
ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 970 EVO 500GB
ID-4: /dev/sda vendor: Crucial model: CT2000BX500SSD1 size: 1.82 TiB
ID-5: /dev/sdb vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
ID-1: / size: 448.43 GiB used: 25.14 GiB (5.6%) fs: ext4 dev: /dev/nvme2n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme2n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 7.5 MiB (0.1%)
dev: /dev/nvme2n1p3
System Temperatures: cpu: 42.5 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (rpm): N/A
Processes: 578 Uptime: 2h 28m Memory: total: 64 GiB available: 61.95 GiB
used: 42.41 GiB (68.5%) Shell: Zsh inxi: 3.3.30
lspci -nnv
00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14d8]
Subsystem: Advanced Micro Devices, Inc. [AMD] Device [1022:14d8]
Flags: fast devsel
00:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Device [1022:14d9]
Subsystem: Gigabyte Technology Co., Ltd Device [1458:d000]
Flags: bus master, fast devsel, latency 0, IRQ 26
Capabilities: <access denied>
00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14da]
Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:14db] (prog-if 00 [Normal decode])
Subsystem: Advanced Micro Devices, Inc. [AMD] Device [1022:1453]
Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 1
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: f000-ffff [size=4K] [16-bit]
Memory behind bridge: fa000000-fb0fffff [size=17M] [32-bit]
Prefetchable memory behind bridge: fcc0000000-fcd1ffffff [size=288M] [32-bit]
Kernel driver in use: pcieport
00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:14db] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 2
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled] [32-bit]
Memory behind bridge: fc100000-fc1fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14da]
Flags: fast devsel, IOMMU group 3
00:02.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:14db] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 4
Bus: primary=00, secondary=03, subordinate=13, sec-latency=0
Memory behind bridge: 80000000-807fffff [size=8M] [32-bit]
00:02.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:14db] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 5
Bus: primary=00, secondary=14, subordinate=14, sec-latency=0
Memory behind bridge: fc000000-fc0fffff [size=1M] [32-bit]
00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14da]
Flags: fast devsel, IOMMU group 6
00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14da]
Flags: fast devsel, IOMMU group 7
00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14da]
Flags: fast devsel, IOMMU group 8
00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:14dd] (prog-if 00 [Normal decode])
Subsystem: Advanced Micro Devices, Inc. [AMD] Device [1022:14dd]
Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 9
Bus: primary=00, secondary=15, subordinate=15, sec-latency=0
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: fbb00000-fbefffff [size=4M] [32-bit]
Prefetchable memory behind bridge: fce0000000-fcf01fffff [size=258M] [32-bit]
00:08.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:14dd] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 10
Bus: primary=00, secondary=16, subordinate=16, sec-latency=0
Memory behind bridge: fbf00000-fbffffff [size=1M] [32-bit]
00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 71)
Subsystem: Gigabyte Technology Co., Ltd FCH SMBus Controller [1458:5001]
Flags: 66MHz, medium devsel, IOMMU group 11
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
Subsystem: Gigabyte Technology Co., Ltd FCH LPC Bridge [1458:5001]
Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 11
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14e0]
Flags: fast devsel, IOMMU group 12
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14e1]
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14e2]
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14e3]
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14e4]
00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14e5]
00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14e6]
00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:14e7]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation AD103 [GeForce RTX 4080] [10de:2704] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Gigabyte Technology Co., Ltd AD103 [GeForce RTX 4080] [1458:40bc]
Flags: fast devsel, IRQ 187, IOMMU group 13
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at fcc0000000 (64-bit, prefetchable) [size=256M]
Memory at fcd0000000 (64-bit, prefetchable) [size=32M]
I/O ports at f000 [size=128]
Expansion ROM at fb000000 [disabled] [size=512K]
Kernel driver in use: vfio-pci
Kernel modules: nouveau
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:22bb] (rev a1)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:40bc]
Flags: fast devsel, IRQ 204, IOMMU group 14
Memory at fb080000 (32-bit, non-prefetchable) [size=16K]
Kernel modules: snd_hda_intel
02:00.0 Non-Volatile memory controller [0108]: Kingston Technology Company, Inc. KC3000/Renegade NVMe SSD [2646:5013] (rev 01) (prog-if 02 [NVM Express])
Subsystem: Kingston Technology Company, Inc. FURY Renegade NVMe SSD [2646:5013]
Flags: bus master, fast devsel, latency 0, IRQ 57, NUMA node 0, IOMMU group 15
Memory at fc100000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
Kernel modules: nvme
03:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f4] (rev 01) (prog-if 00 [Normal decode])
Subsystem: ASMedia Technology Inc. Device [1b21:3328]
Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 16
Bus: primary=03, secondary=04, subordinate=13, sec-latency=0
04:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Subsystem: Device [3328:3328]
Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 17
Bus: primary=04, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: [disabled] [32-bit]
04:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 18
Bus: primary=04, secondary=06, subordinate=06, sec-latency=0
04:05.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 19
Bus: primary=04, secondary=07, subordinate=07, sec-latency=0
04:06.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 39, IOMMU group 20
Bus: primary=04, secondary=08, subordinate=08, sec-latency=0
04:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 21
Bus: primary=04, secondary=09, subordinate=11, sec-latency=0
Memory behind bridge: 80000000-805fffff [size=6M] [32-bit]
04:0c.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 41, IOMMU group 22
Bus: primary=04, secondary=12, subordinate=12, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: 80600000-806fffff [size=1M] [32-bit]
04:0d.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 42, IOMMU group 23
Bus: primary=04, secondary=13, subordinate=13, sec-latency=0
Memory behind bridge: 80700000-807fffff [size=1M] [32-bit]
09:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f4] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 43, IOMMU group 24
Bus: primary=09, secondary=0a, subordinate=11, sec-latency=0
0a:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 44, IOMMU group 25
Bus: primary=0a, secondary=0b, subordinate=0b, sec-latency=0
0a:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 45, IOMMU group 26
Bus: primary=0a, secondary=0c, subordinate=0c, sec-latency=0
0a:06.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 46, IOMMU group 27
Bus: primary=0a, secondary=0d, subordinate=0d, sec-latency=0
Memory behind bridge: 80000000-801fffff [size=2M] [32-bit]
0a:07.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 48, IOMMU group 28
Bus: primary=0a, secondary=0e, subordinate=0e, sec-latency=0
Memory behind bridge: 80200000-802fffff [size=1M] [32-bit]
0a:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 49, IOMMU group 29
Bus: primary=0a, secondary=0f, subordinate=0f, sec-latency=0
Memory behind bridge: 80300000-803fffff [size=1M] [32-bit]
0a:0c.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 50, IOMMU group 30
Bus: primary=0a, secondary=10, subordinate=10, sec-latency=0
Memory behind bridge: 80400000-804fffff [size=1M] [32-bit]
0a:0d.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f5] (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 51, IOMMU group 31
Bus: primary=0a, secondary=11, subordinate=11, sec-latency=0
Memory behind bridge: 80500000-805fffff [size=1M] [32-bit]
0d:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller I225-V [8086:15f3] (rev 01)
Subsystem: Gigabyte Technology Co., Ltd Ethernet Controller I225-V [1458:e000]
Flags: bus master, fast devsel, latency 0, IRQ 38, IOMMU group 32
Memory at 80000000 (32-bit, non-prefetchable) [size=1M]
Memory at 80100000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: igc
Kernel modules: igc
0e:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz [8086:2725] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz [8086:0024]
Flags: bus master, fast devsel, latency 0, IRQ 47, IOMMU group 33
Memory at 80200000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
0f:00.0 Non-Volatile memory controller [0108]: ADATA Technology Co., Ltd. XPG GAMMIX S50 NVMe SSD [1cc1:5350] (rev 03) (prog-if 02 [NVM Express])
Subsystem: ADATA Technology Co., Ltd. XPG GAMMIX S50 NVMe SSD [1cc1:5350]
Flags: bus master, fast devsel, latency 0, IRQ 24, NUMA node 0, IOMMU group 34
Memory at 80300000 (64-bit, non-prefetchable) [size=16K]
10:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f7] (rev 01) (prog-if 30 [XHCI])
Subsystem: ASMedia Technology Inc. Device [1b21:1142]
Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 35
Memory at 80400000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
11:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f6] (rev 01) (prog-if 01 [AHCI 1.0])
Subsystem: ASMedia Technology Inc. Device [1b21:1062]
Flags: bus master, fast devsel, latency 0, IRQ 52, IOMMU group 36
Memory at 80580000 (32-bit, non-prefetchable) [size=1K]
Expansion ROM at 80500000 [disabled] [size=512K]
Kernel driver in use: ahci
12:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f7] (rev 01) (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 37
Memory at 80600000 (64-bit, non-prefetchable) [size=32K]
13:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] Device [1022:43f6] (rev 01) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 53, IOMMU group 38
Memory at 80780000 (32-bit, non-prefetchable) [size=1K]
Expansion ROM at 80700000 [disabled] [size=512K]
14:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808] (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd SSD 970 EVO [144d:a801]
Flags: bus master, fast devsel, latency 0, IRQ 24, NUMA node 0, IOMMU group 39
Memory at fc000000 (64-bit, non-prefetchable) [size=16K]
15:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Raphael [1002:164e] (rev c9) (prog-if 00 [VGA controller])
Subsystem: Gigabyte Technology Co., Ltd Raphael [1458:d000]
Flags: bus master, fast devsel, latency 0, IRQ 165, IOMMU group 40
Memory at fce0000000 (64-bit, prefetchable) [size=256M]
Memory at fcf0000000 (64-bit, prefetchable) [size=2M]
I/O ports at e000 [size=256]
Memory at fbe00000 (32-bit, non-prefetchable) [size=512K]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
15:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] VanGogh PSP/CCP [1022:1649]
Subsystem: Advanced Micro Devices, Inc. [AMD] VanGogh PSP/CCP [1022:1649]
Flags: bus master, fast devsel, latency 0, IRQ 54, IOMMU group 41
Memory at fbd00000 (32-bit, non-prefetchable) [size=1M]
Memory at fbe80000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: ccp
Kernel modules: ccp
15:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:15b6] (prog-if 30 [XHCI])
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5007]
Flags: fast devsel, IRQ 156, IOMMU group 42
Memory at fbc00000 (64-bit, non-prefetchable) [size=1M]
15:00.4 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:15b7] (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 165, IOMMU group 43
Memory at fbb00000 (64-bit, non-prefetchable) [size=1M]
16:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:15b8] (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 44
Memory at fbf00000 (64-bit, non-prefetchable) [size=1M]
