I tested with a simple Python script with GPU under the Manjaro distro and found that the floating error is vital even if the operation is simple, where in Windows boot, or other worse GPU machine there is no that floating error. Any idea how to deal with this? Thank you! The script for reproducing:
import random
import numpy as np
import torch
from torch.optim import Adam
seed = 1
device = "cuda"
torch.manual_seed(seed)
torch.cuda.manual_seed(seed)
random.seed(seed)
np.random.seed(seed)
input = torch.tensor([1.0, 2.0], device=device)
target = torch.tensor([4.0, 5.0], device=device)
model = torch.nn.Linear(2, 2, bias=False)
model.to(device)
optimizer = Adam(model.parameters(), lr=0.1)
for i in range(2):
print(model.weight)
optimizer.zero_grad()
optimizer.step()
output = model(input)
print(f"{i} output: {output}")
loss = (target - output).sum()
print(f"{i} loss: {loss}")
loss.backward()
optimizer.step()
The output:
Parameter containing:
tensor([[ 0.3643, -0.3121],
[-0.1371, 0.3319]], device='cuda:0', requires_grad=True)
0 output: tensor([-0.2598, 0.5265], device='cuda:0', grad_fn=<SqueezeBackward3>)
0 loss: 8.7332763671875
tensor([[ 0.4643, -0.2121],
[-0.0371, 0.4319]], device='cuda:0', requires_grad=True)
1 output: tensor([0.2410, 1.0275], device='cuda:0', grad_fn=<SqueezeBackward3>)
1 loss: 7.7315521240234375
and using CPU, the result is correct, which is
[-0.1371, 0.3319]], requires_grad=True)
0 output: tensor([-0.2599, 0.5267], grad_fn=<SqueezeBackward3>)
0 loss: 8.733150482177734
[-0.0371, 0.4319]], requires_grad=True)
1 output: tensor([0.2412, 1.0277], grad_fn=<SqueezeBackward3>)
1 loss: 7.731115341186523
The model weights will be the same across the machines & cpu, so the problem would just be the multiplication and sum operation for [1.0, 2] @ weights. Any suggestions here?
system info:
Kernel: 5.17.15-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=17a57bc5-4569-4d1b-8454-2c7d491f058c rw quiet apparmor=1
security=apparmor udev.log_priority=3 snd_hda_intel.power_save=0
button.lid_init_state=open
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29
info: vala-panel, xfce4-panel, plank wm: xfwm v: 4.16.1 vt: 7 dm: LightDM
v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Razer product: Blade 15 (2022) - RZ09-0421 v: 8.04
Mobo: Razer model: CH580 v: 4 serial: <superuser required> UEFI: Razer
v: 1.09 date: 02/22/2022
ID-1: BAT0 charge: 80.3 Wh (100.0%) condition: 80.3/80.2 Wh (100.1%)
volts: 17.5 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: full
ID-2: hidpp_battery_0 charge: 76% condition: N/A volts: 4.0 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: discharging
Info: model: 12th Gen Intel Core i7-12800H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x41C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1266 high: 2170 min/max: 400/2400:1800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1816 2: 636 3: 1062
4: 694 5: 915 6: 999 7: 2170 8: 1999 9: 1253 10: 808 11: 1861 12: 1974
13: 1793 14: 1640 15: 1088 16: 979 17: 1069 18: 509 19: 1106 20: 959
bogomips: 112160
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Razer USA
driver: i915 v: kernel arch: Gen12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: NVIDIA GA103M [GeForce RTX 3080 Ti Laptop GPU] vendor: Razer USA
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2460 class-ID: 0300
Device-3: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 1-2:2 chip-ID: 13d3:5279 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: xfwm v: 4.16.1 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4608x2011 s-dpi: 96 s-size: 1219x532mm (47.99x20.94")
s-diag: 1330mm (52.36")
Monitor-1: HDMI-1-0 pos: primary,top-right res: 2560x1440 hz: 60 dpi: 108
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: eDP-1 pos: bottom-l res: 2048x1152 hz: 60 dpi: 151
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Razer USA
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Razer USA driver: N/A alternate: snd_hda_intel
pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2288 class-ID: 0403
Sound Server-1: ALSA v: k5.17.15-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:6
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 247.39 GiB (25.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVMe CA6-8D1024 size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
type: SSD serial: <filter> rev: ERA0902 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 672.78 GiB size: 661.15 GiB (98.27%)
used: 247.34 GiB (37.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 50.7 MiB (52.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 256 MiB used: 40.2 MiB (15.7%) priority: 50
file: /var/lib/systemd-swap/swapfc/1
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 486 Uptime: 2d 22h 58m wakeups: 87 Memory: 31.04 GiB
used: 10.87 GiB (35.0%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1482
pacman: 1459 lib: 335 flatpak: 10 snap: 13 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.19
