Hello,
On a fresh install of Manjaro 21.1, I have no sound output. The laptop is a Dell Latitude 9520.
Here are some useful outputs I think:
sudo dmesg | grep -iE 'snd|sof'
[ 0.508245] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.628123] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.628124] software IO TLB: mapped [mem 0x0000000051d96000-0x0000000055d96000] (64MB)
[ 2.311870] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 2.311891] snd_hda_intel 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
[ 2.439034] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 2.439049] sof-audio-pci 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
[ 2.439075] sof-audio-pci 0000:00:1f.3: enabling device (0000 -> 0002)
[ 2.439288] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040380
[ 3.505669] sof-audio-pci 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 3.512728] sof-audio-pci 0000:00:1f.3: use msi interrupt mode
[ 3.534534] sof-audio-pci 0000:00:1f.3: hda codecs found, mask 4
[ 3.536610] sof-audio-pci 0000:00:1f.3: warning: unknown sof_ext_man header type 6 size 0x20
[ 3.536613] sof-audio-pci 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[ 3.536615] sof-audio-pci 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:17:0
[ 3.536617] sof-audio-pci 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 3.536624] sof-audio-pci 0000:00:1f.3: warning: unknown sof_ext_man header type 3 size 0x30
[ 3.536625] sof-audio-pci 0000:00:1f.3: warning: unknown sof_ext_man header type 5 size 0x20
[ 3.624346] sof-audio-pci 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
[ 3.624349] sof-audio-pci 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:17:0
[ 3.624350] sof-audio-pci 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 3.636149] sof-audio-pci 0000:00:1f.3: Topology: ABI 3:18:1 Kernel ABI 3:17:0
[ 3.636150] sof-audio-pci 0000:00:1f.3: warn: topology ABI is more recent than kernel
[ 3.649831] sof-audio-pci 0000:00:1f.3: ASoC: physical link SDW0-Capture (id 4) not exist
[ 3.649832] sof-audio-pci 0000:00:1f.3: ASoC: topology: could not load header: -22
[ 3.650557] sof-audio-pci 0000:00:1f.3: error: tplg component load failed -22
[ 3.650561] sof-audio-pci 0000:00:1f.3: error: failed to load DSP topology -22
[ 3.650563] sof-audio-pci 0000:00:1f.3: ASoC: error at snd_soc_component_probe on 0000:00:1f.3: -22
[ 3.650563] sof-audio-pci 0000:00:1f.3: ASoC: failed to probe component -22
[ 3.650579] sof_sdw sof_sdw: ASoC: failed to instantiate card -22
[ 7.815255] sof_sdw sof_sdw: snd_soc_register_card failed -22
[ 7.815269] sof_sdw: probe of sof_sdw failed with error -22
arecord -l
arecord: device_list:274: no soundcards found...
pacmd list-sources
1 source(s) available.
* index: 0
driver: <module-null-sink.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max rewind: 344 KiB
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
monitor_of: 0
module: 15
properties:
device.description = "Monitor of Dummy Output"
device.class = "monitor"
Thank you in advance for any help you could provide.
