Google-Earth-Pro (7.3.4.8248-1)
has flyby-problem - doesnot fly to the point you enter in search box.
Solution:
/opt/google/earth/pro/googleearth
change file to this:
googleearth
googleearth
#!/bin/bash
# This script configures any environment prerequisites needed by Google Earth.
# Start Google Earth using this script rather than googleearth-bin directly.
# If you want to use an external copy of GPSBabel, you can specify it here.
# if [[ -z "$GPSBABEL" ]]; then export GPSBABEL="$(which gpsbabel)"; fi
# If DISPLAY is not set, try to autodetect a value.
if [[ -z "$DISPLAY" ]]; then
echo "WARNING: DISPLAY environment variable is not set."
x_displays=(/tmp/.X11-unix/X*)
display="${x_displays[0]}"
if [[ -e "$display" ]]; then
export DISPLAY=":${display/*X/}"
echo " Found ${display}; setting DISPLAY=\"${DISPLAY}\"."
else
echo " X11 display not detected; Google Earth may not run correctly."
fi
fi
unset LC_ALL
export LC_NUMERIC=C
"$(dirname "$(readlink -f "$0")")/googleearth-bin" "$@"
