I have downloaded the file from gologin website.
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=42afc5bd-6b47-4b00-a928-fe64c89408c6 rw quiet apparmor=1
security=apparmor resume=UUID=4f624507-5959-4d4f-b32e-b241e784db39
udev.log_priority=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B550 Phantom Gaming 4/ac
serial: <superuser required> BIOS: American Megatrends LLC. v: P2.10
date: 08/02/2021
RAM: total: 70.6 GiB used: 12.62 GiB (17.9%)
RAM Report:
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3090 high: 3872 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3207 2: 2931
3: 2798 4: 2661 5: 2869 6: 2864 7: 2874 8: 3592 9: 2898 10: 2907 11: 2885
12: 3707 13: 3872 14: 2902 15: 2873 16: 3602 bogomips: 121415
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: eVga.com. driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.0 chip-ID: 10de:2503
class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.4x13.5")
s-diag: 1252mm (49.3")
Monitor-1: DP-1 pos: right res: 1920x1080 hz: 75 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 80
size: 609x349mm (24.0x13.7") diag: 702mm (27.6")
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
direct render: Yes
Device-1: NVIDIA vendor: eVga.com. driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 10de:228e
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Corsair VIRTUOSO SE USB Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:11 chip-ID: 1b1c:0a3d
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-9:3 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 953.87 GiB used: 52.29 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 1T02
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1000 scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 18.51 GiB (18.9%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 42afc5bd-6b47-4b00-a928-fe64c89408c6
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 63.3 MiB (12.4%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: NO_LABEL
uuid: 9D8E-5753
ID-3: /home raw-size: 803.36 GiB size: 789.68 GiB (98.30%)
used: 33.72 GiB (4.3%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 7695ca94-9e3a-4b3e-8afc-459b963b37ea
ID-1: swap-1 type: partition size: 50 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 4f624507-5959-4d4f-b32e-b241e784db39
ID-1: /dev/sda1 maj-min: 8:1 size: 8 MiB fs: <superuser required> label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-4:10 info: Corsair VIRTUOSO SE Wireless Gaming Headset
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1b1c:0a46 class-ID: 0300 serial: <filter>
Device-2: 1-6:11 info: Corsair VIRTUOSO SE USB Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 5
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:0a3d class-ID: 0300
serial: <filter>
Device-3: 1-9:3 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Device-4: 1-10:4 info: ASRock LED Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 26ce:01a2 class-ID: 0300 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Razer USA BlackWidow V3 Pro type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:025a class-ID: 0300
Hub-4: 3-4:3 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Hub-5: 3-4.1:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 3-4.1.1:5
info: Razer USA Gaming Mouse [Basilisk Ultimate Wireless Receiver]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0088 class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-4:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 045b:0210 class-ID: 0900
Hub-8: 4-4.1:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 46 C
Processes: 388 Uptime: 11h 35m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1422
pacman: 1403 lib: 390 flatpak: 9 snap: 10 Shell: Zsh v: 5.8.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.13
How would i continue to install it properly?
