Most games just work because of Proton, yay Valve.
Otherwise, ProtonDB has info on if you need to change configs to make it work.
Indeed, gaming on linux feels alot easier on linux nowaydayās sometimes even easier then on windows.
I meant a topic in Manjaro forum (my question was lazy though), but this seams better. I still have problems playing some games from GOG especially, so Iām going to look there. Thanks!
Edit: I still have to get Proton working inside Lutris.
Dual-boot is always awkard. I do have a very small Windows partition as a dual-boot available, but that is only for things like firmware updaters in .exe format or something like that (things you rarely need, if at all). Even when I (rarely) have to do something in a Windows environment, I will NOT reboot into that Windows partition because itās just too disrupting. I simply use a Windows VM under Linux.
Rebooting into the other OS is just a major annoyance and so dual-boot is not really recommended. Also, when you have Windows installed, it does not care at all about any other OSses that might be out there. It always acts like itās the only thing there is (which is also why you pretty much have to install Windows first in a dual-boot system), and so thereās the risk that it will replace your grub bootloader at some point. Which is also annoying when it happens.
So for a user who doesnāt want to miss out on anything (meaning that a Windows partition also has to exist for those rare cases where you absolutely need to run something in it), Iād suggest:
