Hi,
When waking up from suspend the computer let’s me log back in as expected (I can se the desktop) but then almost immediately logs me out and gets back to suspend.
It’s not a huge deal, I just have to log back in again for my desktop to work as expected. But it had never done that before I replaced the Ethernet cable with a new PCI WiFi/BT card, and installed Manjaro’s latest updates (I now realize it was a bad idea to do both at the same time)
The WiFi/Bluetooth card is branded as ’ Ubit AX WiFi 6 WiFi Card Dual Band 3000 Mbps AX200 PCIE Wireless WLAN WiFi Card with Bluetooth 5.1 | MU-MIMO| OFDMA| Ultra-Low Latency’ (dixit Amazon) and it is marketed as Linux compatible too (it worked out of the box, with nothing to install).
Here is what inxi -F
tells me about it:
Intel Wi-Fi 6 AX200 driver: iwlwifi
The WiFi and Bluetooth are working fine, the only odd bug is this suspend thingy. Is there something I can do/check/invoke (not much into Cthulhu but if need be…)?
Thx in advance for any suggestion
