Gnucash fails to update (‘cairo<=1.14.8’ required by gnucash)
#1
running manajro xfce, totay received an update for gnucash. Was unable to update, got the following message:
could no satisfy dependencies:
unable to satisfy dependency ‘cairo<=1.14.8’ required by gnucash
Presently I have cairo 1.15.8-2 installed?
#2
This means that to install gnucash, one needs to have cairo version 1.14.8 or below. And why is that you ask?
https://aur.archlinux.org/packages/gnucash/
Solutions? Downgrade cairo to 1.14.8 for now
(Also I moved this to #technical-issues-and-assistance:aur , because gnucash is an aur package)
Gnucash - latest update - missing
#3
thanks thefallenrat, I tried it but only got:
Available packages:
  1. cairo-1.15.8-2-x86_64.pkg.tar.xz (local)
  2. cairo-1.14.10-1-x86_64.pkg.tar.xz (local)
Those are newer than cairo 1.14.8
#4
Try this :
sudo pacman -U https://archive.archlinux.org/packages/c/cairo/cairo-1.14.8-1-$(uname -m).pkg.tar.xz
#5
Thank This did the job.
#6
I made the Cairo change and got gnucash to update from AUR. Now Octopi wants to update Cairo. Will this break gnucash? What happens on the next Manjaro update which I assume will occur in a few days?
#7
Yes, as evidenced in my previous posts
Don’t update cairo if you want to still keep using gnucash
Also be wary that AUR is not officially supported by manjaro
https://wiki.manjaro.org/index.php/Arch_User_Repository
#8
Ok. I’m relatively new to manjaro and only use AUR for a few things like gnucash. I guess the old version of cairo is needed just during the build process. As an experiment, after building gnucash with the old cairo, I updated cairo with octopi and gnucash seems to run normally. So it appears that I need to watch out for further gnucash updates until they introduce their next full version which seems to be a ways off in the future. Thanks for you assisstance.
#9
