I know it is weird to ask in this forum but I couldn’t find a eligible place to put this problem while deal with it. Their wiki related forum looks made for advance users.
Do u know anywhere Gnucash forum like this?
Need to ask about after data transfer problem weird thing?
You could start with the documentation
sudo pacman -Syu gnucash-docs
In any case you should ask in the Support
You should make clear statmen on app version and whether it is aquired as flatpak or from repo - even snap.
Always include basic system info retrieved using
inxi -Fc0
I’m not sure I understand.
This official site works, no?
For more ‘interactive’ help there is the IRC
https://wiki.gnucash.org/wiki/IRC
Or is that what you are calling ‘too advanced’ ?
I echo this sentiment. Raise the query here unless you have some reason not to.
You are both TL3 members, and TL3s have the ability to move threads and edit thread titles, you know?
Call to arms: Help the moderators reclassify / tag posts, please? — post by @Fabby
Thread moved to Software & Applications…
TL3 members
Am I ?
Yes; your profiles — for the both of you — state that you are Regulars, which is TL3.
