Yeah, will try that, I just created a new account to see if my user config was the problem but the issue ws still there
Installed linux515, the problem persists
this is the log of the test account
[ 2987.877] (--) Log file renamed from "/home/test/.local/share/xorg/Xorg.pid-6961.log" to "/home/test/.local/share/xorg/Xorg.0.log"
[ 2987.881]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
[ 2987.881]
X.Org X Server 1.21.1.1
[ 2987.881] Current Operating System: Linux luis-x453sa 5.13.19-2-MANJARO #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021 x86_64
[ 2987.882] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=3bfd2053-4404-49ab-a024-fc509aee2a12 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 2987.883]
[ 2987.883] Current version of pixman: 0.40.0
[ 2987.883] Before reporting problems, check http://wiki.x.org
[ 2987.883] Markers: (--) probed, (**) from config file, (==) default setting,
[ 2987.883] (==) Log file: "/home/test/.local/share/xorg/Xorg.0.log", Time: Wed Dec 1 17:34:38 2021
[ 2987.921] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2987.921] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2987.948] (==) No Layout section. Using the first Screen section.
[ 2987.948] (==) No screen section available. Using defaults.
[ 2987.948] (**) |-->Screen "Default Screen Section" (0)
[ 2987.949] (**) | |-->Monitor "<default monitor>"
[ 2987.950] (==) No monitor specified for screen "Default Screen Section".
[ 2987.950] (==) Automatically adding devices
[ 2987.951] (==) Automatically enabling devices
[ 2987.951] (==) Automatically adding GPU devices
[ 2987.951] (==) Automatically binding GPU devices
[ 2987.951] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2987.952] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 2987.952] Entry deleted from font path.
[ 2987.953] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 2987.953] Entry deleted from font path.
[ 2987.953] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 2987.954] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 2987.954] Entry deleted from font path.
[ 2987.954] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 2987.955] (==) FontPath set to:
/usr/share/fonts/TTF
[ 2987.955] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2987.955] (II) The server relies on udev to provide the list of input devices.
[ 2987.956] (II) Module ABI versions:
[ 2987.956] X.Org ANSI C Emulation: 0.4
[ 2987.956] X.Org Video Driver: 25.2
[ 2987.957] X.Org XInput driver : 24.4
[ 2987.957] X.Org Server Extension : 10.0
[ 2987.961] (++) using VT number 2
[ 2987.969] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_39
[ 2987.972] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 2987.972] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 2987.975] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[ 2987.984] (--) PCI:*(0@0:2:0) 8086:22b1:1043:1cbd rev 33, Mem @ 0x80000000/16777216, 0x90000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 2987.985] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 2987.985] (II) LoadModule: "glx"
[ 2988.038] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2988.073] (II) Module glx: vendor="X.Org Foundation"
[ 2988.073] compiled for 1.21.1.1, module version = 1.0.0
[ 2988.074] ABI class: X.Org Server Extension, version 10.0
[ 2988.074] (==) Matched modesetting as autoconfigured driver 0
[ 2988.074] (==) Matched fbdev as autoconfigured driver 1
[ 2988.074] (==) Matched vesa as autoconfigured driver 2
[ 2988.074] (==) Assigned the driver to the xf86ConfigLayout
[ 2988.074] (II) LoadModule: "modesetting"
[ 2988.075] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 2988.098] (II) Module modesetting: vendor="X.Org Foundation"
[ 2988.098] compiled for 1.21.1.1, module version = 1.21.1
[ 2988.099] Module class: X.Org Video Driver
[ 2988.099] ABI class: X.Org Video Driver, version 25.2
[ 2988.099] (II) LoadModule: "fbdev"
[ 2988.102] (WW) Warning, couldn't open module fbdev
[ 2988.102] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 2988.102] (II) LoadModule: "vesa"
[ 2988.105] (WW) Warning, couldn't open module vesa
[ 2988.105] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 2988.105] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 2988.106] (II) modeset(0): using drv /dev/dri/card0
[ 2988.106] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 2988.107] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 2988.107] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 2988.107] (==) modeset(0): RGB weight 888
[ 2988.107] (==) modeset(0): Default visual is TrueColor
[ 2988.107] (II) Loading sub module "glamoregl"
[ 2988.108] (II) LoadModule: "glamoregl"
[ 2988.108] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 2988.144] (II) Module glamoregl: vendor="X.Org Foundation"
[ 2988.145] compiled for 1.21.1.1, module version = 1.0.1
[ 2988.145] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2988.204] (II) modeset(0): glamor X acceleration enabled on Mesa DRI Intel(R) HD Graphics 400 (BSW)
[ 2988.204] (II) modeset(0): glamor initialized
[ 2988.204] (==) modeset(0): VariableRefresh: disabled
[ 2988.204] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 2988.206] (II) modeset(0): Output eDP-1 has no monitor section
[ 2988.206] (II) modeset(0): Output DP-1 has no monitor section
[ 2988.208] (II) modeset(0): Output HDMI-1 has no monitor section
[ 2988.209] (II) modeset(0): Output DP-2 has no monitor section
[ 2988.210] (II) modeset(0): Output HDMI-2 has no monitor section
[ 2988.229] (II) modeset(0): EDID for output eDP-1
[ 2988.230] (II) modeset(0): Manufacturer: CMN Model: 1493 Serial#: 0
[ 2988.230] (II) modeset(0): Year: 2013 Week: 40
[ 2988.230] (II) modeset(0): EDID Version: 1.4
[ 2988.230] (II) modeset(0): Digital Display Input
[ 2988.230] (II) modeset(0): 6 bits per channel
[ 2988.230] (II) modeset(0): Digital interface is DisplayPort
[ 2988.230] (II) modeset(0): Max Image Size [cm]: horiz.: 31 vert.: 17
[ 2988.230] (II) modeset(0): Gamma: 2.20
[ 2988.230] (II) modeset(0): No DPMS capabilities specified
[ 2988.230] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 2988.230] (II) modeset(0): First detailed timing is preferred mode
[ 2988.230] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 2988.230] (II) modeset(0): redX: 0.575 redY: 0.335 greenX: 0.327 greenY: 0.580
[ 2988.230] (II) modeset(0): blueX: 0.157 blueY: 0.137 whiteX: 0.313 whiteY: 0.329
[ 2988.230] (II) modeset(0): Manufacturer's mask: 0
[ 2988.230] (II) modeset(0): Supported detailed timing:
[ 2988.231] (II) modeset(0): clock: 76.4 MHz Image Size: 309 x 173 mm
[ 2988.231] (II) modeset(0): h_active: 1366 h_sync: 1434 h_sync_end 1479 h_blank_end 1592 h_border: 0
[ 2988.231] (II) modeset(0): v_active: 768 v_sync: 772 v_sync_end 779 v_blanking: 800 v_border: 0
[ 2988.231] (II) modeset(0): N140BGE-E43
[ 2988.231] (II) modeset(0): CMN
[ 2988.231] (II) modeset(0): EDID (in hex):
[ 2988.231] (II) modeset(0): 00ffffffffffff000dae931400000000
[ 2988.231] (II) modeset(0): 28170104951f1178027e459355539428
[ 2988.231] (II) modeset(0): 23505400000001010101010101010101
[ 2988.231] (II) modeset(0): 010101010101da1d56e250002030442d
[ 2988.231] (II) modeset(0): 470035ad10000018000000fe004e3134
[ 2988.231] (II) modeset(0): 304247452d4534330a20000000fe0043
[ 2988.231] (II) modeset(0): 4d4e0a202020202020202020000000fe
[ 2988.231] (II) modeset(0): 004e3134304247452d4534330a200095
[ 2988.232] (II) modeset(0): Printing probed modes for output eDP-1
[ 2988.232] (II) modeset(0): Modeline "1366x768"x60.0 76.42 1366 1434 1479 1592 768 772 779 800 -hsync -vsync (48.0 kHz eP)
[ 2988.232] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 2988.232] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 2988.232] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 2988.232] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 2988.233] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 2988.233] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 2988.233] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 2988.233] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 2988.233] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 2988.233] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 2988.233] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 2988.233] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 2988.233] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 2988.233] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 2988.233] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 2988.233] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 2988.233] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 2988.233] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 2988.233] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 2988.233] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 2988.233] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 2988.234] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 2988.234] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 2988.234] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 2988.234] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 2988.234] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 2988.234] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 2988.234] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 2988.234] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 2988.234] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 2988.234] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 2988.234] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 2988.234] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 2988.234] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 2988.234] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 2988.234] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 2988.235] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 2988.235] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 2988.235] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 2988.235] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 2988.235] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 2988.235] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 2988.235] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 2988.235] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 2988.235] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 2988.235] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 2988.235] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 2988.235] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 2988.235] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 2988.235] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 2988.235] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 2988.235] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 2988.236] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 2988.236] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 2988.236] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 2988.236] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 2988.236] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 2988.236] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 2988.236] (II) modeset(0): EDID for output DP-1
[ 2988.237] (II) modeset(0): EDID for output HDMI-1
[ 2988.237] (II) modeset(0): EDID for output DP-2
[ 2988.239] (II) modeset(0): EDID for output HDMI-2
[ 2988.239] (II) modeset(0): Output eDP-1 connected
[ 2988.239] (II) modeset(0): Output DP-1 disconnected
[ 2988.239] (II) modeset(0): Output HDMI-1 disconnected
[ 2988.239] (II) modeset(0): Output DP-2 disconnected
[ 2988.239] (II) modeset(0): Output HDMI-2 disconnected
[ 2988.239] (II) modeset(0): Using exact sizes for initial modes
[ 2988.239] (II) modeset(0): Output eDP-1 using initial mode 1366x768 +0+0
[ 2988.239] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2988.239] (==) modeset(0): DPI set to (96, 96)
[ 2988.239] (II) Loading sub module "fb"
[ 2988.240] (II) LoadModule: "fb"
[ 2988.240] (II) Module "fb" already built-in
[ 2988.595] (==) modeset(0): Backing store enabled
[ 2988.596] (==) modeset(0): Silken mouse enabled
[ 2988.733] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 2988.733] (==) modeset(0): DPMS enabled
[ 2988.734] (II) modeset(0): [DRI2] Setup complete
[ 2988.734] (II) modeset(0): [DRI2] DRI driver: i965
[ 2988.734] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 2988.734] (II) Initializing extension Generic Event Extension
[ 2988.735] (II) Initializing extension SHAPE
[ 2988.736] (II) Initializing extension MIT-SHM
[ 2988.737] (II) Initializing extension XInputExtension
[ 2988.739] (II) Initializing extension XTEST
[ 2988.740] (II) Initializing extension BIG-REQUESTS
[ 2988.742] (II) Initializing extension SYNC
[ 2988.743] (II) Initializing extension XKEYBOARD
[ 2988.744] (II) Initializing extension XC-MISC
[ 2988.745] (II) Initializing extension SECURITY
[ 2988.746] (II) Initializing extension XFIXES
[ 2988.747] (II) Initializing extension RENDER
[ 2988.749] (II) Initializing extension RANDR
[ 2988.751] (II) Initializing extension COMPOSITE
[ 2988.752] (II) Initializing extension DAMAGE
[ 2988.753] (II) Initializing extension MIT-SCREEN-SAVER
[ 2988.754] (II) Initializing extension DOUBLE-BUFFER
[ 2988.755] (II) Initializing extension RECORD
[ 2988.756] (II) Initializing extension DPMS
[ 2988.758] (II) Initializing extension Present
[ 2988.759] (II) Initializing extension DRI3
[ 2988.760] (II) Initializing extension X-Resource
[ 2988.761] (II) Initializing extension XVideo
[ 2988.762] (II) Initializing extension XVideo-MotionCompensation
[ 2988.762] (II) Initializing extension GLX
[ 2988.777] (II) AIGLX: Loaded and initialized i965
[ 2988.777] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 2988.777] (II) Initializing extension XFree86-VidModeExtension
[ 2988.778] (II) Initializing extension XFree86-DGA
[ 2988.779] (II) Initializing extension XFree86-DRI
[ 2988.779] (II) Initializing extension DRI2
[ 2988.782] (II) modeset(0): Damage tracking initialized
[ 2988.782] (II) modeset(0): Setting screen physical size to 361 x 203
[ 2989.000] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 2989.000] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 2989.000] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 2989.000] (**) Power Button: Applying InputClass "system-keyboard"
[ 2989.000] (II) LoadModule: "libinput"
[ 2989.001] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 2989.023] (II) Module libinput: vendor="X.Org Foundation"
[ 2989.023] compiled for 1.21.1, module version = 1.2.0
[ 2989.023] Module class: X.Org XInput Driver
[ 2989.023] ABI class: X.Org XInput driver, version 24.4
[ 2989.023] (II) Using input driver 'libinput' for 'Power Button'
[ 2989.029] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 22 paused 0
[ 2989.030] (**) Power Button: always reports core events
[ 2989.030] (**) Option "Device" "/dev/input/event2"
[ 2989.031] (**) Option "_source" "server/udev"
[ 2989.041] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 2989.041] (II) event2 - Power Button: device is a keyboard
[ 2989.042] (II) event2 - Power Button: device removed
[ 2989.042] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 2989.043] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 2989.043] (**) Option "xkb_layout" "latam"
[ 2989.115] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 2989.115] (II) event2 - Power Button: device is a keyboard
[ 2989.118] (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event4)
[ 2989.118] (**) Asus Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[ 2989.118] (**) Asus Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[ 2989.118] (**) Asus Wireless Radio Control: Applying InputClass "system-keyboard"
[ 2989.118] (II) Using input driver 'libinput' for 'Asus Wireless Radio Control'
[ 2989.124] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 25 paused 0
[ 2989.124] (**) Asus Wireless Radio Control: always reports core events
[ 2989.124] (**) Option "Device" "/dev/input/event4"
[ 2989.124] (**) Option "_source" "server/udev"
[ 2989.130] (II) event4 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 2989.130] (II) event4 - Asus Wireless Radio Control: device is a keyboard
[ 2989.131] (II) event4 - Asus Wireless Radio Control: device removed
[ 2989.131] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input8/event4"
[ 2989.131] (II) XINPUT: Adding extended input device "Asus Wireless Radio Control" (type: KEYBOARD, id 7)
[ 2989.131] (**) Option "xkb_layout" "latam"
[ 2989.141] (II) event4 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 2989.141] (II) event4 - Asus Wireless Radio Control: device is a keyboard
[ 2989.147] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[ 2989.147] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 2989.147] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 2989.147] (**) Video Bus: Applying InputClass "system-keyboard"
[ 2989.147] (II) Using input driver 'libinput' for 'Video Bus'
[ 2989.150] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 26 paused 0
[ 2989.150] (**) Video Bus: always reports core events
[ 2989.150] (**) Option "Device" "/dev/input/event7"
[ 2989.150] (**) Option "_source" "server/udev"
[ 2989.160] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 2989.161] (II) event7 - Video Bus: device is a keyboard
[ 2989.161] (II) event7 - Video Bus: device removed
[ 2989.161] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input14/event7"
[ 2989.161] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 2989.162] (**) Option "xkb_layout" "latam"
[ 2989.166] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 2989.167] (II) event7 - Video Bus: device is a keyboard
[ 2989.170] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 2989.170] (II) No input driver specified, ignoring this device.
[ 2989.170] (II) This device may have been added with another device file.
[ 2989.173] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 2989.173] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 2989.173] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 2989.173] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 2989.173] (II) Using input driver 'libinput' for 'Sleep Button'
[ 2989.180] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 27 paused 0
[ 2989.181] (**) Sleep Button: always reports core events
[ 2989.181] (**) Option "Device" "/dev/input/event1"
[ 2989.181] (**) Option "_source" "server/udev"
[ 2989.186] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 2989.186] (II) event1 - Sleep Button: device is a keyboard
[ 2989.186] (II) event1 - Sleep Button: device removed
[ 2989.187] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 2989.187] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 2989.187] (**) Option "xkb_layout" "latam"
[ 2989.192] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 2989.192] (II) event1 - Sleep Button: device is a keyboard
[ 2989.198] (II) config/udev: Adding input device USB2.0 VGA UVC WebCam: USB2.0 V (/dev/input/event12)
[ 2989.198] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "evdev keyboard catchall"
[ 2989.198] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "libinput keyboard catchall"
[ 2989.198] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "system-keyboard"
[ 2989.198] (II) Using input driver 'libinput' for 'USB2.0 VGA UVC WebCam: USB2.0 V'
[ 2989.201] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 28 paused 0
[ 2989.202] (**) USB2.0 VGA UVC WebCam: USB2.0 V: always reports core events
[ 2989.202] (**) Option "Device" "/dev/input/event12"
[ 2989.202] (**) Option "_source" "server/udev"
[ 2989.207] (II) event12 - USB2.0 VGA UVC WebCam: USB2.0 V: is tagged by udev as: Keyboard
[ 2989.208] (II) event12 - USB2.0 VGA UVC WebCam: USB2.0 V: device is a keyboard
[ 2989.208] (II) event12 - USB2.0 VGA UVC WebCam: USB2.0 V: device removed
[ 2989.208] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/input/input19/event12"
[ 2989.208] (II) XINPUT: Adding extended input device "USB2.0 VGA UVC WebCam: USB2.0 V" (type: KEYBOARD, id 10)
[ 2989.208] (**) Option "xkb_layout" "latam"
[ 2989.213] (II) event12 - USB2.0 VGA UVC WebCam: USB2.0 V: is tagged by udev as: Keyboard
[ 2989.213] (II) event12 - USB2.0 VGA UVC WebCam: USB2.0 V: device is a keyboard
[ 2989.216] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event9)
[ 2989.216] (II) No input driver specified, ignoring this device.
[ 2989.216] (II) This device may have been added with another device file.
[ 2989.217] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event10)
[ 2989.217] (II) No input driver specified, ignoring this device.
[ 2989.217] (II) This device may have been added with another device file.
[ 2989.219] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event11)
[ 2989.219] (II) No input driver specified, ignoring this device.
[ 2989.219] (II) This device may have been added with another device file.
[ 2989.221] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event8)
[ 2989.221] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 2989.221] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 2989.221] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[ 2989.221] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[ 2989.224] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 29 paused 0
[ 2989.224] (**) Asus WMI hotkeys: always reports core events
[ 2989.224] (**) Option "Device" "/dev/input/event8"
[ 2989.224] (**) Option "_source" "server/udev"
[ 2989.232] (II) event8 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 2989.232] (II) event8 - Asus WMI hotkeys: device is a keyboard
[ 2989.232] (II) event8 - Asus WMI hotkeys: device removed
[ 2989.232] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input15/event8"
[ 2989.232] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 11)
[ 2989.232] (**) Option "xkb_layout" "latam"
[ 2989.235] (II) event8 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 2989.236] (II) event8 - Asus WMI hotkeys: device is a keyboard
[ 2989.238] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 2989.238] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 2989.238] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 2989.238] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 2989.238] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 2989.241] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 30 paused 0
[ 2989.241] (**) AT Translated Set 2 keyboard: always reports core events
[ 2989.242] (**) Option "Device" "/dev/input/event3"
[ 2989.242] (**) Option "_source" "server/udev"
[ 2989.246] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 2989.246] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 2989.253] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 2989.254] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 2989.254] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[ 2989.254] (**) Option "xkb_layout" "latam"
[ 2989.257] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 2989.258] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 2989.263] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event6)
[ 2989.263] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 2989.263] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[ 2989.263] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 2989.271] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 31 paused 0
[ 2989.271] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 2989.271] (**) Option "Device" "/dev/input/event6"
[ 2989.271] (**) Option "_source" "server/udev"
[ 2989.275] (II) event6 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 2989.281] (II) event6 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 2989.281] (II) event6 - ETPS/2 Elantech Touchpad: device removed
[ 2989.282] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input13/event6"
[ 2989.283] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 13)
[ 2989.288] (**) Option "AccelerationScheme" "none"
[ 2989.288] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[ 2989.288] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 2989.288] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 2989.291] (II) event6 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 2989.296] (II) event6 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 2989.298] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[ 2989.298] (II) No input driver specified, ignoring this device.
[ 2989.299] (II) This device may have been added with another device file.
[ 2989.300] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 2989.300] (II) No input driver specified, ignoring this device.
[ 2989.300] (II) This device may have been added with another device file.
[ 2991.378] (II) modeset(0): EDID vendor "CMN", prod id 5267
[ 2991.378] (II) modeset(0): Printing DDC gathered Modelines:
[ 2991.378] (II) modeset(0): Modeline "1366x768"x0.0 76.42 1366 1434 1479 1592 768 772 779 800 -hsync -vsync (48.0 kHz eP)
[ 3007.477] (II) modeset(0): EDID vendor "CMN", prod id 5267
[ 3007.477] (II) modeset(0): Printing DDC gathered Modelines:
[ 3007.477] (II) modeset(0): Modeline "1366x768"x0.0 76.42 1366 1434 1479 1592 768 772 779 800 -hsync -vsync (48.0 kHz eP)
[ 3154.503] (**) Option "fd" "22"
[ 3154.503] (II) event2 - Power Button: device removed
[ 3154.504] (**) Option "fd" "25"
[ 3154.504] (II) event4 - Asus Wireless Radio Control: device removed
[ 3154.504] (**) Option "fd" "26"
[ 3154.504] (II) event7 - Video Bus: device removed
[ 3154.504] (**) Option "fd" "27"
[ 3154.504] (II) event1 - Sleep Button: device removed
[ 3154.504] (**) Option "fd" "28"
[ 3154.504] (II) event12 - USB2.0 VGA UVC WebCam: USB2.0 V: device removed
[ 3154.504] (**) Option "fd" "29"
[ 3154.505] (II) event8 - Asus WMI hotkeys: device removed
[ 3154.505] (**) Option "fd" "30"
[ 3154.505] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 3154.505] (**) Option "fd" "31"
[ 3154.521] (II) event6 - ETPS/2 Elantech Touchpad: device removed
[ 3154.563] (II) UnloadModule: "libinput"
[ 3154.563] (II) systemd-logind: releasing fd for 13:70
[ 3154.997] (II) UnloadModule: "libinput"
[ 3154.998] (II) systemd-logind: releasing fd for 13:67
[ 3155.039] (II) UnloadModule: "libinput"
[ 3155.039] (II) systemd-logind: releasing fd for 13:72
[ 3155.065] (II) UnloadModule: "libinput"
[ 3155.065] (II) systemd-logind: releasing fd for 13:76
[ 3155.069] (II) UnloadModule: "libinput"
[ 3155.069] (II) systemd-logind: releasing fd for 13:65
[ 3155.071] (II) UnloadModule: "libinput"
[ 3155.071] (II) systemd-logind: releasing fd for 13:71
[ 3155.073] (II) UnloadModule: "libinput"
[ 3155.073] (II) systemd-logind: releasing fd for 13:68
[ 3155.077] (II) UnloadModule: "libinput"
[ 3155.077] (II) systemd-logind: releasing fd for 13:66
[ 3155.111] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 3155.111] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 3155.171] (II) Server terminated successfully (0). Closing log file.
anything unusual?
I just ran retroarch on x11 and realiced that instead of calling it black and blue is more accurrate to say that the green color is not being displayer, on the legend of zelda and retroarch the blue and red elements are presented (albeit with a satured look) but the green is nowhere to be found, is there any setting that could cause such issue? and no, is not a hardware problem, wayland works fine.
