Im running in to a weird issue where when i try to move a folder to my samba server (hosted on manjaro) from my desktop (garuda) it will move the directories and sub directories but not the files inside, I can move the files individually but that would take forever.
Im usually pretty good at figuring stuff out but i dont know where to start with this one
testparm -s
Global parameters
[global]
map to guest = Bad User
name resolve order = bcast host
security = USER
server string = mainframe
idmap config * : backend = tdb[data 1]
create mask = 0664
directory mask = 0775
force create mode = 0664
force directory mode = 0775
force group = sambashare
force user = sambauser
guest ok = Yes
path = /media/data1
read only = No[data 8tb]
create mask = 0664
guest ok = Yes
path = /media/8tbdata
read only = No[data 2]
create mask = 0664
guest ok = Yes
path = /media/data2
read only = No
