Gnome shell trava ao alternar usuário
gnome
#1
Olá pessoal, estou com problema para alternar entre usuários no gnome; possuo 2 usuários no computador e quando eu vou alternar entre eles o gnome shell trava e fica numa tela preta. Só consigo voltar dando reset pelo botão. Por favor quem soube de algo me fale.
#2
Quando te aparece a tela preta, concegues mudar de terminal (CTRL+ALT+F1, F2, F3, etc.)?
#3
Oi, eu não consigo.
#4
Então reproduz o problema, reinicia e depois cola aqui o output de
journalctl -xe -p3 -b-1
#5
– Logs begin at Sat 2018-05-12 22:11:14 -03, end at Thu 2018-05-17 01:05:31 -0>
mai 17 00:40:42 anderson-pc kernel: sp5100_tco: I/O address 0x0cd6 already in u>
mai 17 00:40:42 anderson-pc kernel: amdgpu 0000:01:00.0: Invalid PCI ROM header>
mai 17 00:41:06 anderson-pc systemd-logind[421]: Failed to remove runtime direc>
mai 17 01:02:43 anderson-pc systemd-logind[421]: Failed to remove runtime direc>
mai 17 01:03:56 anderson-pc gdm[467]: GLib: g_hash_table_find: assertion 'versi>
lines 1-6/6 (END)…skipping…
– Logs begin at Sat 2018-05-12 22:11:14 -03, end at Thu 2018-05-17 01:05:31 -03. –
mai 17 00:40:42 anderson-pc kernel: sp5100_tco: I/O address 0x0cd6 already in use
mai 17 00:40:42 anderson-pc kernel: amdgpu 0000:01:00.0: Invalid PCI ROM header signature: expecting 0xaa55, got 0xffff
mai 17 00:41:06 anderson-pc systemd-logind[421]: Failed to remove runtime directory /run/user/120 (before unmounting): Permission denied
mai 17 01:02:43 anderson-pc systemd-logind[421]: Failed to remove runtime directory /run/user/120 (before unmounting): Permission denied
mai 17 01:03:56 anderson-pc gdm[467]: GLib: g_hash_table_find: assertion ‘version == hash_table->version’ failed
Aqui o log, descobrir que consegui usar ctrl+alt+F1-7, mas não consegui voltar para a interface gráfica (area de trabalho).
#6
-- Logs begin at Sat 2018-05-12 22:11:14 -03, end at Thu 2018-05-17 01:05:31 -0>
lines 1-6/6 (END)...skipping...
-- Logs begin at Sat 2018-05-12 22:11:14 -03, end at Thu 2018-05-17 01:05:31 -03. --
mai 17 01:03:56 anderson-pc gdm[467]: GLib: g_hash_table_find: assertion 'version == hash_table->version' failed
#7
Não consigo encontrar nada definitivo. Qual é a gráfica?
inxi -G
Já experimentaste escolher uma sessão Xorg em vez de Wayland? Procura na roda dentada do ecrã de login.
#8
Uso uma radeon RX 460. Testei esse cenário no virtualbox e acontece o mesmo, alterno entre os usuários da máquina e fico preso na tela preta. Deve ser problema do Manjaro Gnome.
#9
