Gnome-shell crash theme
gnome
#1
Hey. The theme of the gnome-shell randomly crashes. This happens after a sleep or waiting mode. Here are the logs, if you need additional information please report it.
journalctl output
Jan 20 16:21:26 n9v9ap kernel: Freezing user space processes ... (elapsed 0.005 seconds) done.
Jan 20 16:21:26 n9v9ap kernel: OOM killer disabled.
Jan 20 16:21:26 n9v9ap kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Jan 20 16:21:26 n9v9ap kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jan 20 16:21:26 n9v9ap kernel: psmouse serio2: Failed to disable mouse on synaptics-pt/serio0
Jan 20 16:21:26 n9v9ap kernel: wlp5s0: deauthenticating from f0:b4:29:e4:43:e5 by local choice (Reason: 3=DEAUTH_LEAVING)
Jan 20 16:21:26 n9v9ap kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Jan 20 16:21:26 n9v9ap kernel: sd 0:0:0:0: [sda] Stopping disk
Jan 20 16:21:26 n9v9ap kernel: ACPI: EC: interrupt blocked
Jan 20 16:21:26 n9v9ap kernel: ACPI: Preparing to enter system sleep state S3
Jan 20 16:21:26 n9v9ap kernel: ACPI: EC: event blocked
Jan 20 16:21:26 n9v9ap kernel: ACPI: EC: EC stopped
Jan 20 16:21:26 n9v9ap kernel: PM: Saving platform NVS memory
Jan 20 16:21:26 n9v9ap kernel: Disabling non-boot CPUs ...
Jan 20 16:21:26 n9v9ap kernel: smpboot: CPU 1 is now offline
Jan 20 16:21:26 n9v9ap kernel: smpboot: CPU 2 is now offline
Jan 20 16:21:26 n9v9ap kernel: smpboot: CPU 3 is now offline
Jan 20 16:21:26 n9v9ap kernel: smpboot: CPU 4 is now offline
Jan 20 16:21:26 n9v9ap kernel: smpboot: CPU 5 is now offline
Jan 20 16:21:26 n9v9ap kernel: smpboot: CPU 6 is now offline
Jan 20 16:21:26 n9v9ap kernel: smpboot: CPU 7 is now offline
Jan 20 16:21:26 n9v9ap kernel: ACPI: Low-level resume complete
Jan 20 16:21:26 n9v9ap kernel: ACPI: EC: EC started
Jan 20 16:21:26 n9v9ap kernel: PM: Restoring platform NVS memory
Jan 20 16:21:26 n9v9ap kernel: Enabling non-boot CPUs ...
Jan 20 16:21:26 n9v9ap kernel: x86: Booting SMP configuration:
Jan 20 16:21:26 n9v9ap kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Jan 20 16:21:26 n9v9ap kernel:  cache: parent cpu1 should not be sleeping
Jan 20 16:21:26 n9v9ap kernel: CPU1 is up
Jan 20 16:21:26 n9v9ap kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Jan 20 16:21:26 n9v9ap kernel:  cache: parent cpu2 should not be sleeping
Jan 20 16:21:26 n9v9ap kernel: CPU2 is up
Jan 20 16:21:26 n9v9ap kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Jan 20 16:21:26 n9v9ap kernel:  cache: parent cpu3 should not be sleeping
Jan 20 16:21:26 n9v9ap kernel: CPU3 is up
Jan 20 16:21:26 n9v9ap kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
Jan 20 16:21:26 n9v9ap kernel:  cache: parent cpu4 should not be sleeping
Jan 20 16:21:26 n9v9ap kernel: CPU4 is up
Jan 20 16:21:26 n9v9ap kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
Jan 20 16:21:26 n9v9ap kernel:  cache: parent cpu5 should not be sleeping
Jan 20 16:21:26 n9v9ap kernel: CPU5 is up
Jan 20 16:21:26 n9v9ap kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
Jan 20 16:21:26 n9v9ap kernel:  cache: parent cpu6 should not be sleeping
Jan 20 16:21:26 n9v9ap kernel: CPU6 is up
Jan 20 16:21:26 n9v9ap kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
Jan 20 16:21:26 n9v9ap kernel:  cache: parent cpu7 should not be sleeping
Jan 20 16:21:26 n9v9ap kernel: CPU7 is up
Jan 20 16:21:26 n9v9ap kernel: ACPI: Waking up from system sleep state S3
Jan 20 16:21:26 n9v9ap kernel: ACPI: EC: interrupt unblocked
Jan 20 16:21:26 n9v9ap kernel: ACPI: EC: event unblocked
Jan 20 16:21:26 n9v9ap kernel: sd 0:0:0:0: [sda] Starting disk
Jan 20 16:21:26 n9v9ap kernel: usb 1-8: reset full-speed USB device number 4 using xhci_hcd
Jan 20 16:21:26 n9v9ap kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jan 20 16:21:26 n9v9ap kernel: ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
Jan 20 16:21:26 n9v9ap kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
Jan 20 16:21:26 n9v9ap kernel: ata1.00: supports DRM functions and may not be fully accessible
Jan 20 16:21:26 n9v9ap kernel: ata1.00: Trusted Computing capability qword not valid!
Jan 20 16:21:26 n9v9ap kernel: ata1.00: configured for UDMA/133
Jan 20 16:21:26 n9v9ap kernel: usb 1-6: reset high-speed USB device number 3 using xhci_hcd
Jan 20 16:21:26 n9v9ap kernel: psmouse serio1: synaptics: queried max coordinates: x [..5676], y [..4690]
Jan 20 16:21:26 n9v9ap kernel: psmouse serio1: synaptics: queried min coordinates: x [1266..], y [1162..]
Jan 20 16:21:26 n9v9ap kernel: acpi LNXPOWER:01: Turning OFF
Jan 20 16:21:26 n9v9ap kernel: OOM killer enabled.
Jan 20 16:21:26 n9v9ap kernel: Restarting tasks ... done.
Jan 20 16:21:26 n9v9ap systemd-logind[492]: Lid opened.
Jan 20 16:21:26 n9v9ap wpa_supplicant[693]: wlp5s0: CTRL-EVENT-DISCONNECTED bssid=f0:b4:29:e4:43:e5 reason=3 locally_generated=1
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <warn>  [1547994086.3122] sup-iface[0x5619e28a05a0,wlp5s0]: connection disconnected (reason -3)
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.3134] device (wlp5s0): supplicant interface state: completed -> disconnected
Jan 20 16:21:26 n9v9ap gnome-shell[11631]: An active wireless connection, in infrastructure mode, involves no access point?
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.4084] device (wlp5s0): supplicant interface state: disconnected -> scanning
Jan 20 16:21:26 n9v9ap systemd-sleep[14523]: System resumed.
Jan 20 16:21:26 n9v9ap kernel: PM: suspend exit
Jan 20 16:21:26 n9v9ap systemd[1]: Started Suspend.
Jan 20 16:21:26 n9v9ap kernel: audit: type=1130 audit(1547994086.480:419): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:26 n9v9ap kernel: audit: type=1131 audit(1547994086.480:420): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:26 n9v9ap audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:26 n9v9ap audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:26 n9v9ap systemd[1]: sleep.target: Unit not needed anymore. Stopping.
Jan 20 16:21:26 n9v9ap systemd[1]: Stopped target Sleep.
Jan 20 16:21:26 n9v9ap systemd[1]: tlp-sleep.service: Unit not needed anymore. Stopping.
Jan 20 16:21:26 n9v9ap systemd[1]: Stopping TLP suspend/resume...
Jan 20 16:21:26 n9v9ap systemd[1]: Reached target Suspend.
Jan 20 16:21:26 n9v9ap systemd[1]: suspend.target: Unit not needed anymore. Stopping.
Jan 20 16:21:26 n9v9ap systemd[1]: Stopped target Suspend.
Jan 20 16:21:26 n9v9ap systemd-logind[492]: Operation 'sleep' finished.
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.4938] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.4940] device (enp3s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.5243] device (wlp5s0): state change: activated -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.5245] dhcp4 (wlp5s0): canceled DHCP transaction
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.5245] dhcp4 (wlp5s0): state changed bound -> done
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.5369] manager: NetworkManager state is now CONNECTED_GLOBAL
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.5446] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Jan 20 16:21:26 n9v9ap kernel: IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
Jan 20 16:21:26 n9v9ap kernel: enp3s0: 0xffffb0c1c1a9d000, 8c:16:45:15:99:9a, IRQ 138
Jan 20 16:21:26 n9v9ap wpa_supplicant[693]: nl80211: Failed to open /proc/sys/net/ipv4/conf/p2p-dev-wlp5s0/drop_unicast_in_l2_multicast: No such file or directory
Jan 20 16:21:26 n9v9ap wpa_supplicant[693]: nl80211: Failed to set IPv4 unicast in multicast filter
Jan 20 16:21:26 n9v9ap dbus-daemon[494]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=496 comm="/usr/bin/NetworkManager --no-daemon ")
Jan 20 16:21:26 n9v9ap gsd-sharing[11719]: Failed to StopUnit service: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit rygel.service not loaded.
Jan 20 16:21:26 n9v9ap gsd-sharing[11719]: Failed to StopUnit service: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit gnome-remote-desktop.service not loaded.
Jan 20 16:21:26 n9v9ap systemd[1]: Starting Network Manager Script Dispatcher Service...
Jan 20 16:21:26 n9v9ap dbus-daemon[494]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 20 16:21:26 n9v9ap audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:26 n9v9ap systemd[1]: Started Network Manager Script Dispatcher Service.
Jan 20 16:21:26 n9v9ap nm-dispatcher[14607]: req:1 'down' [wlp5s0]: new request (0 scripts)
Jan 20 16:21:26 n9v9ap nm-dispatcher[14607]: req:1 'down' [wlp5s0]: completed: no scripts
Jan 20 16:21:26 n9v9ap kernel: audit: type=1130 audit(1547994086.553:421): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:26 n9v9ap wpa_supplicant[693]: nl80211: deinit ifname=p2p-dev-wlp5s0 disabled_11b_rates=0
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.5956] device (wlp5s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Jan 20 16:21:26 n9v9ap kernel: IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.6005] device (wlp5s0): set-hw-addr: set MAC address to B2:6B:18:D3:F2:3F (scanning)
Jan 20 16:21:26 n9v9ap wpa_supplicant[693]: nl80211: deinit ifname=wlp5s0 disabled_11b_rates=0
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.8009] sup-iface[0x5619e28a04f0,wlp5s0]: supports 5 scan SSIDs
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.8028] device (wlp5s0): supplicant interface state: starting -> ready
Jan 20 16:21:26 n9v9ap NetworkManager[496]: <info>  [1547994086.8030] device (wlp5s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Jan 20 16:21:26 n9v9ap systemd[1]: Stopped TLP suspend/resume.
Jan 20 16:21:26 n9v9ap kernel: audit: type=1131 audit(1547994086.803:422): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:26 n9v9ap audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:29 n9v9ap ModemManager[490]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.4/0000:03:00.0': not supported by any plugin
Jan 20 16:21:29 n9v9ap ModemManager[490]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.2/0000:05:00.0': not supported by any plugin
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3586] policy: auto-activating connection 'Event Horizon 2' (b4ba110a-8098-4430-8a37-d21fcda5df95)
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3613] device (wlp5s0): Activation: starting connection 'Event Horizon 2' (b4ba110a-8098-4430-8a37-d21fcda5df95)
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3617] device (wlp5s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3633] manager: NetworkManager state is now CONNECTING
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3736] device (wlp5s0): set-hw-addr: reset MAC address to 34:41:5D:D3:8B:91 (preserve)
Jan 20 16:21:30 n9v9ap kernel: IPv6: ADDRCONF(NETDEV_UP): wlp5s0: link is not ready
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3759] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3779] device (wlp5s0): Activation: (wifi) access point 'Event Horizon 2' has security, but secrets are required.
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3780] device (wlp5s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3886] device (wlp5s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3903] device (wlp5s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3923] device (wlp5s0): Activation: (wifi) connection 'Event Horizon 2' has security, and secrets exist.  No new secrets needed.
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3924] Config: added 'ssid' value 'Event Horizon 2'
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3924] Config: added 'scan_ssid' value '1'
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3925] Config: added 'bgscan' value 'simple:30:-80:86400'
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3926] Config: added 'key_mgmt' value 'WPA-PSK'
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3926] Config: added 'auth_alg' value 'OPEN'
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.3927] Config: added 'psk' value '<hidden>'
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.4114] device (wlp5s0): supplicant interface state: ready -> disabled
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.4499] device (wlp5s0): supplicant interface state: disabled -> inactive
Jan 20 16:21:30 n9v9ap NetworkManager[496]: <info>  [1547994090.4769] device (wlp5s0): supplicant interface state: inactive -> scanning
Jan 20 16:21:31 n9v9ap wpa_supplicant[693]: wlp5s0: SME: Trying to authenticate with f0:b4:29:e4:43:e5 (SSID='Event Horizon 2' freq=2472 MHz)
Jan 20 16:21:31 n9v9ap kernel: wlp5s0: authenticate with f0:b4:29:e4:43:e5
Jan 20 16:21:31 n9v9ap kernel: wlp5s0: send auth to f0:b4:29:e4:43:e5 (try 1/3)
Jan 20 16:21:31 n9v9ap wpa_supplicant[693]: wlp5s0: Trying to associate with f0:b4:29:e4:43:e5 (SSID='Event Horizon 2' freq=2472 MHz)
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.3175] device (wlp5s0): supplicant interface state: scanning -> authenticating
Jan 20 16:21:31 n9v9ap kernel: wlp5s0: authenticated
Jan 20 16:21:31 n9v9ap kernel: wlp5s0: associate with f0:b4:29:e4:43:e5 (try 1/3)
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.3233] device (wlp5s0): supplicant interface state: authenticating -> associating
Jan 20 16:21:31 n9v9ap wpa_supplicant[693]: RRM: Ignoring radio measurement request: Not associated
Jan 20 16:21:31 n9v9ap kernel: wlp5s0: RX AssocResp from f0:b4:29:e4:43:e5 (capab=0xc31 status=0 aid=2)
Jan 20 16:21:31 n9v9ap wpa_supplicant[693]: wlp5s0: Associated with f0:b4:29:e4:43:e5
Jan 20 16:21:31 n9v9ap wpa_supplicant[693]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Jan 20 16:21:31 n9v9ap kernel: wlp5s0: associated
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.3416] device (wlp5s0): supplicant interface state: associating -> associated
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4289] device (wlp5s0): supplicant interface state: associated -> 4-way handshake
Jan 20 16:21:31 n9v9ap wpa_supplicant[693]: wlp5s0: WPA: Key negotiation completed with f0:b4:29:e4:43:e5 [PTK=CCMP GTK=CCMP]
Jan 20 16:21:31 n9v9ap wpa_supplicant[693]: wlp5s0: CTRL-EVENT-CONNECTED - Connection to f0:b4:29:e4:43:e5 completed [id=0 id_str=]
Jan 20 16:21:31 n9v9ap kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp5s0: link becomes ready
Jan 20 16:21:31 n9v9ap wpa_supplicant[693]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-55 noise=9999 txrate=1000
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4386] device (wlp5s0): supplicant interface state: 4-way handshake -> completed
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4387] device (wlp5s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Event Horizon 2"
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4392] device (wlp5s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4401] dhcp4 (wlp5s0): activation: beginning transaction (timeout in 45 seconds)
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4732] dhcp4 (wlp5s0):   address 192.168.1.173
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4733] dhcp4 (wlp5s0):   plen 24
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4734] dhcp4 (wlp5s0):   expires in 86400 seconds
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4735] dhcp4 (wlp5s0):   nameserver '8.8.8.8'
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4735] dhcp4 (wlp5s0):   nameserver '8.8.4.4'
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4736] dhcp4 (wlp5s0):   hostname 'n9v9ap'
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4736] dhcp4 (wlp5s0):   gateway 192.168.1.1
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4742] dhcp4 (wlp5s0): state changed unknown -> bound
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4783] device (wlp5s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4809] device (wlp5s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4817] device (wlp5s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4835] manager: NetworkManager state is now CONNECTED_GLOBAL
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4926] policy: set 'Event Horizon 2' (wlp5s0) as default for IPv4 routing and DNS
Jan 20 16:21:31 n9v9ap NetworkManager[496]: <info>  [1547994091.4977] device (wlp5s0): Activation: successful, device activated.
Jan 20 16:21:31 n9v9ap wpa_supplicant[693]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-65 noise=9999 txrate=150000
Jan 20 16:21:31 n9v9ap gsd-sharing[11719]: Failed to StopUnit service: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit rygel.service not loaded.
Jan 20 16:21:31 n9v9ap gsd-sharing[11719]: Failed to StopUnit service: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit gnome-remote-desktop.service not loaded.
Jan 20 16:21:31 n9v9ap nm-dispatcher[14607]: req:2 'up' [wlp5s0]: new request (0 scripts)
Jan 20 16:21:31 n9v9ap nm-dispatcher[14607]: req:2 'up' [wlp5s0]: completed: no scripts
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d81d3bb0' has no handler with id '297123'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d81d3bb0' has no handler with id '297124'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d87467c0' has no handler with id '297125'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d87467c0' has no handler with id '297126'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d90227b0' has no handler with id '297133'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d90227b0' has no handler with id '297134'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602da546b90' has no handler with id '297135'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602da546b90' has no handler with id '297136'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d81d2c30' has no handler with id '297137'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d81d2c30' has no handler with id '297138'
Jan 20 16:21:34 n9v9ap gnome-shell[11631]: Object Meta.WindowActor (0x5602d8747740), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: == Stack trace for context 0x5602d5c97270 ==
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #0   7ffee1ba8aa0 b   resource:///org/gnome/gjs/modules/overrides/GObject.js:468 (7fefcf1cc040 @ 25)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #1   7ffee1ba9670 b   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/theming.js:416 (7fefafc84a60 @ 20)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #2   7ffee1baa0f0 b   self-hosted:261 (7fefcf1c1dc0 @ 223)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #3   5602d906cb70 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/theming.js:415 (7fefafc849d0 @ 172)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #4   7ffee1bab1f0 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #5   5602d906caf0 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/theming.js:424 (7fefafc84af0 @ 17)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #6   7ffee1bac150 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #7   5602d906ca70 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/theming.js:89 (7fefafc841f0 @ 42)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #8   7ffee1bad0b0 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #9   5602d906c9e8 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:456 (7fefafc77040 @ 82)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #10   7ffee1bae010 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #11   5602d906c950 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1784 (7fefafc7e430 @ 116)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #12   7ffee1baef70 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #13   5602d906c8d0 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1903 (7fefafc7e820 @ 37)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #14   7ffee1bafed0 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #15   5602d906c858 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/extension.js:20 (7fefafc6b820 @ 12)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #16   5602d906c798 i   resource:///org/gnome/shell/ui/extensionSystem.js:83 (7fefcef54af0 @ 436)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #17   5602d906c718 i   resource:///org/gnome/shell/ui/extensionSystem.js:354 (7fefcef5b670 @ 13)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #18   7ffee1bb1010 b   self-hosted:261 (7fefcf1c1dc0 @ 223)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #19   5602d906c698 i   resource:///org/gnome/shell/ui/extensionSystem.js:353 (7fefcef5b5e0 @ 64)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #20   5602d906c618 i   resource:///org/gnome/shell/ui/extensionSystem.js:371 (7fefcef5b700 @ 87)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #21   7ffee1bb2140 b   resource:///org/gnome/gjs/modules/signals.js:128 (7fefcf1c18b0 @ 386)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #22   7ffee1bb2f60 b   resource:///org/gnome/shell/ui/sessionMode.js:206 (7fefcec415e0 @ 254)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #23   7ffee1bb3bd0 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #24   5602d906c408 i   resource:///org/gnome/shell/ui/sessionMode.js:168 (7fefcec413a0 @ 40)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #25   7ffee1bb4b40 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #26   5602d906c370 i   resource:///org/gnome/shell/ui/screenShield.js:1038 (7fefcec27790 @ 421)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #27   7ffee1bb5ab0 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #28   5602d906c2c8 i   resource:///org/gnome/shell/ui/screenShield.js:1282 (7fefcec28310 @ 223)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #29   7ffee1bb6a20 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #30   5602d906c218 i   resource:///org/gnome/shell/ui/screenShield.js:1328 (7fefcec283a0 @ 391)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #31   7ffee1bb7990 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #32   5602d906c190 i   resource:///org/gnome/shell/ui/shellDBus.js:371 (7fefcec32670 @ 67)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #33   7ffee1bb8900 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #34   5602d906c0c8 i   resource:///org/gnome/gjs/modules/overrides/Gio.js:295 (7fefcf1bd5e0 @ 604)
Jan 20 16:21:34 n9v9ap org.gnome.Shell.desktop[11631]: #35   5602d906c020 i   resource:///org/gnome/gjs/modules/overrides/Gio.js:326 (7fefcf1bd820 @ 34)
Jan 20 16:21:36 n9v9ap dbus-daemon[494]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.6852' (uid=1000 pid=11631 comm="/usr/bin/gnome-shell ")
Jan 20 16:21:36 n9v9ap systemd[1]: Starting Fingerprint Authentication Daemon...
Jan 20 16:21:36 n9v9ap dbus-daemon[494]: [system] Successfully activated service 'net.reactivated.Fprint'
Jan 20 16:21:36 n9v9ap systemd[1]: Started Fingerprint Authentication Daemon.
Jan 20 16:21:36 n9v9ap audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:36 n9v9ap kernel: audit: type=1130 audit(1547994096.776:423): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d81d3bb0' has no handler with id '297123'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d81d3bb0' has no handler with id '297124'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d87467c0' has no handler with id '297125'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d87467c0' has no handler with id '297126'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d90227b0' has no handler with id '297133'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d90227b0' has no handler with id '297134'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602da546b90' has no handler with id '297135'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602da546b90' has no handler with id '297136'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d81d2c30' has no handler with id '297137'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: ../glib/gobject/gsignal.c:2641: instance '0x5602d81d2c30' has no handler with id '297138'
Jan 20 16:21:36 n9v9ap gnome-shell[11631]: Object Meta.WindowActor (0x5602d8747740), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: == Stack trace for context 0x5602d5c97270 ==
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #0   7ffee1baa7a0 b   resource:///org/gnome/gjs/modules/overrides/GObject.js:468 (7fefcf1cc040 @ 25)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #1   7ffee1baa840 b   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/theming.js:416 (7fefafc84a60 @ 20)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #2   7ffee1baa930 b   self-hosted:261 (7fefcf1c1dc0 @ 223)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #3   7ffee1baa9f0 b   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/theming.js:415 (7fefafc849d0 @ 172)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #4   7ffee1bab660 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #5   5602d906c830 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/theming.js:424 (7fefafc84af0 @ 17)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #6   7ffee1bac5c0 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #7   5602d906c7b0 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/theming.js:89 (7fefafc841f0 @ 42)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #8   7ffee1bad520 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #9   5602d906c728 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:456 (7fefafc77040 @ 82)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #10   7ffee1bae480 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #11   5602d906c690 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1784 (7fefafc7e430 @ 116)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #12   7ffee1baf3e0 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #13   5602d906c610 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/docking.js:1903 (7fefafc7e820 @ 37)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #14   7ffee1bb0340 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #15   5602d906c598 i   /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/extension.js:20 (7fefafc6b820 @ 12)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #16   5602d906c4d8 i   resource:///org/gnome/shell/ui/extensionSystem.js:83 (7fefcef54af0 @ 436)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #17   5602d906c458 i   resource:///org/gnome/shell/ui/extensionSystem.js:354 (7fefcef5b670 @ 13)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #18   7ffee1bb12d0 b   self-hosted:261 (7fefcf1c1dc0 @ 223)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #19   5602d906c3d8 i   resource:///org/gnome/shell/ui/extensionSystem.js:353 (7fefcef5b5e0 @ 64)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #20   5602d906c358 i   resource:///org/gnome/shell/ui/extensionSystem.js:371 (7fefcef5b700 @ 87)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #21   7ffee1bb2400 b   resource:///org/gnome/gjs/modules/signals.js:128 (7fefcf1c18b0 @ 386)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #22   7ffee1bb24c0 b   resource:///org/gnome/shell/ui/sessionMode.js:206 (7fefcec415e0 @ 254)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #23   7ffee1bb2580 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #24   5602d906c2c8 i   resource:///org/gnome/shell/ui/sessionMode.js:175 (7fefcec41430 @ 100)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #25   7ffee1bb34f0 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #26   5602d906c230 i   resource:///org/gnome/shell/ui/screenShield.js:922 (7fefcec27550 @ 55)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #27   7ffee1bb4450 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #28   7ffee1bb5020 b   self-hosted:975 (7fefcf1edf70 @ 392)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #29   5602d906c1a8 i   resource:///org/gnome/shell/ui/tweener.js:91 (7fefcf1ccf70 @ 37)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #30   7ffee1bb71f0 b   resource:///org/gnome/gjs/modules/tweener/tweener.js:208 (7fefcf1dd790 @ 54)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #31   7ffee1bb7340 b   resource:///org/gnome/gjs/modules/tweener/tweener.js:342 (7fefcf1dd820 @ 1742)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #32   7ffee1bb73f0 b   resource:///org/gnome/gjs/modules/tweener/tweener.js:355 (7fefcf1dd8b0 @ 100)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #33   5602d906c130 i   resource:///org/gnome/gjs/modules/tweener/tweener.js:370 (7fefcf1dd940 @ 10)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #34   7ffee1bb8380 b   resource:///org/gnome/gjs/modules/signals.js:128 (7fefcf1c18b0 @ 386)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #35   5602d906c0a0 i   resource:///org/gnome/shell/ui/tweener.js:207 (7fefcf1d9790 @ 159)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #36   7ffee1bb92f0 b   resource:///org/gnome/gjs/modules/_legacy.js:82 (7fefcf1b0b80 @ 71)
Jan 20 16:21:36 n9v9ap org.gnome.Shell.desktop[11631]: #37   5602d906c020 i   resource:///org/gnome/shell/ui/tweener.js:182 (7fefcf1d9700 @ 15)
Jan 20 16:21:37 n9v9ap audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:37 n9v9ap kernel: audit: type=1131 audit(1547994097.050:424): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:21:49 n9v9ap gdm-password][14743]: gkr-pam: unlocked login keyring
Jan 20 16:21:49 n9v9ap NetworkManager[496]: <info>  [1547994109.7246] agent-manager: req[0x5619e29ac490, :1.6852/org.gnome.Shell.NetworkAgent/1000]: agent registered
Jan 20 16:22:01 n9v9ap wpa_supplicant[693]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=9999 txrate=150000
Jan 20 16:22:04 n9v9ap sudo[14771]: pam_unix(sudo:auth): authentication failure; logname= uid=1000 euid=0 tty=/dev/pts/0 ruser=null rhost=  user=null
Jan 20 16:22:07 n9v9ap audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:22:07 n9v9ap kernel: audit: type=1131 audit(1547994127.079:425): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 20 16:22:07 n9v9ap gsd-power[839]: Error setting property 'PowerSaveMode' on interface org.gnome.Mutter.DisplayConfig: Timeout was reached (g-io-error-quark, 24)
Jan 20 16:22:13 n9v9ap sudo[14771]:     null : TTY=pts/0 ; PWD=/home/null ; USER=root ; COMMAND=/usr/bin/journalctl
Jan 20 16:22:13 n9v9ap sudo[14771]: pam_unix(sudo:session): session opened for user root by (uid=0)Jan 20 16:21:26 n9v9ap kernel: Freezing user space processes ... (elapsed 0.005 seconds) done.
#2
I am getting the same error. Haven’t noticed it after waking from sleep/suspend, only when it’s been left locked (from timeout or Meta+L).
Seems to be related to this line in the logs:
Object Meta.WindowActor (0x55893f1b5b60), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using ...
#3
Can you try to set dash to dock appareance from ADAPTIVE to FIXED?
In most of cases, gnome-shell crashes due to gnome extensions. Which extensions do you use? It seems like enable or destroy function doesn’t work properly in gnome extension that you used.
#5
Pretty sure this was happening with all the default Manjaro extensions, but I’ve disabled the two extensions I added and will see if it happens again.
@Ste74 I’ve changed opacity to Fixed, and now my settings are like this:
We’ll see if this makes a difference…
#6
Well, after re-enabling the extensions I had in addition to Manjaro defaults, I haven’t seen the problem again, leading me to believe it’s the Dynamic opacity on Dash to Dock.
Thanks @Ste74!
Switched, I will watch.
#8
Setting opacity to Fixed solved it also for me. No crash for over a week.
#9
I had the same issue without knowing what is was, with “User shell themes” extension disable when resumed. Same as here apparently : https://forum.manjaro.org/t/gnome-screenlocking-issues-after-update/66347
also tried DYNAMIC opacity, but it doesn’t work either. Triying FIXED now.
So there is no way to have the same kind of transparency in the dock as the top panel?
