Steps to reproduce:
1.Click on VPN 1 Settings
2. Select CA cert from /etc/ssl/certs
3. Click on “Anwenden(=Apply)”
4.Click on VPN 1 Settings
5. Return to Step one
Apart from the cert and the protocol the entries are all placeholders. I initially noticed this behaviour, when I tried to re-enter everything after it suddenly failed to connect. Don’t know if this is the same VPN issue that was reported after the last Testing update but “L2TP” doesn’t ring any bell.
inxi:
Kernel: 5.15.35-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: GNOME v: 42.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B350M PRO-VDH (MS-7A38) v: 2.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: A.C0
date: 04/24/2018
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
rev: 2 cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1569 high: 2798 min/max: 1550/3400 boost: enabled
cores: 1: 1960 2: 2798 3: 1544 4: 1476 5: 1481 6: 1327 7: 1381 8: 1370
9: 1376 10: 1371 11: 1377 12: 1370 bogomips: 81617
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 510.60.02
bus-ID: 1f:00.0
Device-2: WaveRider USB Live camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-9:7
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1 driver: X:
loaded: nvidia gpu: nvidia resolution: 1920x1080~60Hz
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 1f:00.1
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 21:00.3
Device-3: C-Media Q9-1 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-1.3:10
Device-4: WaveRider USB Live camera type: USB
Sound Server-1: ALSA v: k5.15.35-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.50 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 1b:00.0
IF: enp27s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 1.85 TiB (67.7%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-1SB102 size: 931.51 GiB
ID-3: /dev/sdc vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
ID-1: / size: 71.37 GiB used: 22.52 GiB (31.5%) fs: ext4 dev: /dev/sdc2
ID-2: /home size: 180.09 GiB used: 60.81 GiB (33.8%) fs: ext4
dev: /dev/sdc3
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 52 C
Processes: 378 Uptime: 8h 18m Memory: 7.78 GiB used: 6.04 GiB (77.7%)
Init: systemd Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1284
Shell: Bash v: 5.1.16 inxi: 3.3.15
